Old 06-07-2010, 12:37 PM   #1
TexasTechZ06
TexasTechZ06's Avatar
Drives: 2010 Chevrolet Camaro
Need Some Help/Advice; Take a look a this picture
Well, I wasn't sure where to post this topic, but since it involves an aftermarket exhaust, I thought it would best fit in this section.
I recently installed Flowmaster's American Thunder Catback Exhaust. The system installed uneventfully and sounds really good...no problems there.
The problem I'm having is that the flowmaster X-Pipe, being a 3" system is now coming in contact with what I can describe as the "Cross Bracket" underneath the car. It occurs when going through a dip or a bump, and creates a "metal hitting metal sound", very annoying.
My friend and I did the install, so we added some additional washers to the bolts that hold the bracket so that we can increase the gap between the bracket and the x-pipe. However, I need to add more washers because they are still coming in contact when going through dips and bumps.
What I was wondering is what purpose does this "cross bracket" serve and can it be removed completely? I was thinking of removing it completely and reinserting the bolts, being that the bolts do hold the heat shield in place. I just don't know if the cross bracket serves some type of purpose for reinforcement. I also wonder if an aftermarket replacement bracket it available, that will allow clearance for an 3" system.
I'm sure that many of you who have installed aftermarket catbacks have run into this problem.
Check out the picture below and chime in!
Thanks
Update:It turns out that the problem all this time was the the clamps on the exhaust section weren't tight enough. This lead to the X-Pipe sagging downward and therefore despite my best efforts to add more space to the bracket, it kept hitting it. So, for all you who install your own catback, make sure you properly tighten your clamps with a torqued wrench or a power wrench. It will save you hours and days of confusion.
TexasTechZ06 is offline   Reply With Quote
Old 06-07-2010, 12:40 PM   #2
KungFuHamster
KungFuHamster's Avatar
Drives: Black SS
id say remove that bracket.
KungFuHamster is offline   Reply With Quote
Old 06-07-2010, 12:46 PM   #3
PAUL SS
The Mark of Excellence
PAUL SS's Avatar
Drives: 2010 ABM 1SS RS LS3
I wouldn't remove that brace, but I might look for longer bolts and a better spacer than stacked washers. Maybe a short piece (1/2") iron pipe in the correct diameter.
Old 06-07-2010, 12:50 PM   #4
KungFuHamster
Drives: Black SS
is this new body style as loose as the old 3rd and 4th gens? (lots of body flex) i just assumed they were pretty stiff from the factory...now if theyre like the older styles...then i agree with you 100%
Old 06-07-2010, 12:53 PM   #5
speedster
SST...
speedster's Avatar
Drives: SST Camaro 2010
GM didn't put the brace in without a valid reason. IMO, space it down and leave it.
Old 06-07-2010, 01:08 PM   #6
Dre2216
Dre2216's Avatar
Drives: 1SS IOM M6
There are a few people on here who sell a replacement brace that works with a 3" exhaust. The only one I can think of at the moment is Barton. Try this and search around here as I know there are others. http://www.bartonindustries.com/BUY-Tunnel-Brace.html
1SS/RS-6M-Inferno Orange
NKKV6J---2G1FS1EW4A9134727
SLP LM II
2/26 - Car Back From Dealer!
Dre2216 is offline   Reply With Quote
Old 06-07-2010, 01:09 PM   #7
caverman
caverman's Avatar
Drives: '69 SS Convertible
There are a couple people selling aftermarket braces that will clear the 3" exhaust.
Barton is one of them. I think BMR has something as well. Roughly $80-$100.
Build Journal
Old 06-07-2010, 01:29 PM   #8
Russell James
Russell James's Avatar
More washers.
Old 06-07-2010, 01:30 PM   #9
fargomike
The Dude Abides
fargomike's Avatar
Drives: Black 2SS M6
Elite Engineering makes one that I can think of .
http://eliteengineeringusa.com/Camaro_Tplate.html
fargomike is offline   Reply With Quote
Old 06-07-2010, 01:49 PM   #10
TexasTechZ06
I guess it does serve a purpose! According to this website, the tunnel bracket adds stiffness and rigidity to the chassis. So...I'll likely go with an aftermarket upgraded bracket.
Thanks everyone for the input so far.
Old 06-07-2010, 04:33 PM   #11
Scrappy Doo
Scrappy Doo's Avatar
Drives: Callaway Rogue
I added a couple washers to mine, no more rattle.
Scrappy Doo is offline   Reply With Quote
Old 06-07-2010, 07:30 PM   #12
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
It definitely has a job and does it pretty well. A good friend removed his for his aftermarket exhaust and could feel the car was flexing more. Only under certain circumstances but could definitely feel it.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 06-07-2010, 08:00 PM   #13
clg_98ta
clg_98ta's Avatar
Drives: 2010 Camaro 2SS
I agree that you need to keep the brace for structural integrity. There are a number of aftermarket options. I know that BMR Fabrication makes one, but I don't know how much extra clearance it buys you. Pretty much anyone running a 3" exhaust has to have one though.
Old 06-08-2010, 07:47 PM   #14
green man
green man's Avatar
Drives: 1SS/RS M6
Pretty sure I read one member loosened his exhaust bolts, put a shim (1 x 2 ) under the cross member and tightened everything up then removed the shim..no more contact.
Gripping the wheel, his knuckles went white with desire! The wheels of his Camaro exploding on the highway like a slug from a .45.
True death: 426 horsepower of maximum performance piercing the night... This is black sunshine.
green man is offline   Reply With Quote
Accepting/Requesting Camaro Picture Submissions! Brangeta 4th Generation Camaros 64 02-07-2012 11:38 AM
SS mail slot grill Picture problem sigma_1966 5th Gen Camaro SS LS LT General Discussions 1 03-19-2010 02:54 PM
Signature Picture wbdinger Site Related Announcements / Suggestions / Feedback / Questions 19 02-06-2010 04:23 PM
HOT ROD POWER TOUR PICTURE TELLS ALL! IROCZJEFF Off-topic Discussions 3 06-12-2009 02:25 PM
Need Help with a Picture ZZcamaro Camaro Photos | Spyshots | Video | Media Gallery 0 04-27-2009 03:36 PM
