06-12-2010, 12:23 PM | #1 |
Drives: Camaro Join Date: Apr 2010
Vibration from 58-68.
I believe my Camaro has this issue (see below) and GM is saying this is a normal condition of all Camaros. I would appreciate knowing if your Camaro does or does not have this issue please.
__________________________________________________ _______________ #PIE0058: EI10067 - Engineering Information - Shake/Vibration in Steering Wheel/Body or Seat of Vehicle While Driving at Highway Speeds on Smooth Roads - (Mar 19, 2010) Subject:EI10067 -- Engineering Information -- Shake/Vibration in Steering Wheel/Body or Seat of Vehicle While Driving at Highway Speeds on Smooth Roads Models:2010 Chevrolet Camaro Attention: Proceed with this PI ONLY if the customer has commented about this concern AND the EI number is listed in GMVIS. If the customer has not commented about this condition or the EI does not show in GMVIS, disregard the PI and proceed with diagnostics found in published service information. THIS IS NOT A RECALL -- refer to Service Bulletin 04-00-89-053C for more details on the use of Engineering Information PIs. <A href="http://gsi.xw.gm.com/si/showDoc.do?docSyskey=2421444&from=bcpi#ss1-2421444">Condition Important: If the customer did not bring their vehicle in for this concern, DO NOT proceed with this PI. Some customers may comment on shaking/vibration feeling while driving at highway speeds (typically between 55-70 mph (88-112 km/h)) on smooth roads. Vibrations in the steering wheel may also be accompanied by vibration in the body and/or seat but may be more obvious to the driver due to contact with the steering wheel. When the steering wheel is held loosely on smooth roads, driving straight ahead, slight steering wheel oscillation may be visible. <A href="http://gsi.xw.gm.com/si/showDoc.do?docSyskey=2421444&from=bcpi#ss2-2421444">Cause GM Engineering is attempting to determine the root cause of the vibration. Engineering has a need to gather information on vehicles PRIOR to repair that may exhibit this condition. As a result, this information will be used to "root cause" the customer's concern and develop/validate a field fix. <A href="http://gsi.xw.gm.com/si/showDoc.do?docSyskey=2421444&from=bcpi#ss3-2421444">Instructions Road Testing In order to provide the best diagnostic information, a road test with an EVA (Electronic Vibration Analyzer) or equivalent should be conducted. Convenient locations for the magnetic transducer are the steering column, the driver front seat track and the trunk floor pan over the rear of the propshaft. If possible, you should record your readings in each location between 50-70 mph (80-112 km/h). Important: If the vehicle has been sitting for an extended period of time, you should drive the vehicle for at least 10 miles (16 km) to remove any tire flat-spotting. Important: Be sure tire pressure is set to the placard values. Visually inspect the tires and the wheels. Inspect for evidence of the following conditions: If the vibration source is determined to be the tire/wheel assemblies, perform the following:Wheel and Tire Assembly Balance & Road Force Variation Check Missing balance weights Bent rim flange Irregular tire wear Incomplete bead seating Tire irregularities (including pressure settings) Mud/ice build-up in wheel Stones in the tire tread Verify that aftermarket wheels and/or tires are not in use. Road test the vehicle using the EVA essential tool while driving for a sufficient distance on a known, smooth road surface to duplicate the condition. Determine if the vehicle is sensitive to brake apply. If the brakes are applied lightly and the pulsation felt in the steering wheel increases, discontinue this EI and refer to the Brakes section of SI that deals with brake-induced pulsation. Next, record the Hertz (Hz) reading as displayed by the EVA. This should be done after a tire break-in period of at least 10 miles (16 km) at 45 mph (72 km/h) or greater, in order to eliminate any possible tire flat-spotting. This reading confirms what the vehicle vibration frequency is prior to vehicle service and documents the amount of improvement occurring as the result of the various steps taken to repair. If the EVA indicates a 45-55 Hz propshaft vibration, discontinue this EI and follow normal diagnostics in SI for driveline vibrations. If the vibration smooths out during the road test, tire flat-spotting is the cause. Provide the explanation to the customer. The vibration is due to the vehicle being parked for long periods of time and that it's the nature of the tire to take a set. You may find additional information by referring to Corporate Bulletin Number 03-03-10-007E: Information on Tire/Wheel Characteristics (Vibration, Balance, Shake, Flat Spotting) of GM Original Equipment Tires.
Once again road test the vehicle and record the EVA values. Note if there was not an improvement in the vibration concern. Contact the engineer below with your collected data. The engineer will advise the proper corrective action at that time. |
06-13-2010, 10:35 AM | #2 |
Drives: 2010 F150 Lariat, Candy Red Join Date: Aug 2009
Well double posting won't help.
See replies to your first post. |
Similar Threads | ||||
trunk lid vibration | honeybucket99 | Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum | 76 | 10-15-2014 03:30 PM |
Annoying Vibration with After Market Exhaust | cshaw2049 | Camaro V6 LLT Engine, Exhaust, and Bolt-Ons | 33 | 09-12-2010 03:14 AM |
Low frequency vibration from 58 mph-68 mph | Basenji | 5th Gen Camaro SS LS LT General Discussions | 5 | 05-06-2010 11:06 PM |
Help with Vibration | Cruzintexas | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 7 | 09-18-2009 01:53 PM |
Wheel Vibration | tmc | Wheels and Tires Talk Sponsored by The Tire Rack | 39 | 08-20-2009 09:14 PM |
