![]() Drives: 2010 SS Join Date: Nov 2009
Breathless Intake
Thought i'd pass this on if anyone hasnt seen it. Pretty much same design as other comapnies, besides how filter is designed. Gains look good and dyno vid to show difference vs stock. Anyone running this? Opinions?
http://breathlessperformance.com/pro...tionSystem.asp |
Search Ninja
Drives: 2010 Black 2SS/RS A6 Join Date: Oct 2009
How exactly does it get RAM air? It's behind the headlight and isn't directly open to the airflow off the front of the car. We won't even go into the affects of ram air at speeds that the Camaro is capable of. It's funny to see them post NO PLASTIC PARTS, LIKE OUR COMPETITORS, like that's a good thing. I guess they haven't read about the thermal properties of aluminum.
Halltech CF 102 fed GPI modded intake manifold Bo (knows) White ported TB Kooks LT's/ Dynomax VT Pfadted (springs/sways) Dyno tuned by Rhino and GPI I once parallel parked a train. |
I think they call it ram air due to the design of the air filter possibly.. ? Not sure, but im no genius on thermal properties of plastic vs aluminum myself but if you do look at most competitors including: C.A.I and ADM they both seem to be the most popular choices amongst most forum members and both yielded the best results in Jannettys intake test and both use aluminum elbows.
#4 | |
Go Blue!!!!!
Drives: 2012 Cruze LT Join Date: Mar 2009
#6 |
Go Blue!!!!!
#7 |
![]() Drives: 2010 Camaro SS Join Date: May 2010
HP KILLER, HEAT SOAK CITY
SOLD
2010 Camaro 1SS/A6 12.59@111.31 Magnaflow Magnapack Axleback & Resonated X-Pipe/OBX LT Headers/Airaid Cold Air Kit/Injection Connection Tuned |
#8 | |
Search Ninja
Not sure what filter they use but i've never heard of a filter that caused a RAM affect. I don't think it's physically impossible for a filter to produce a RAM affect. It has to be in the open air to get increased velocity air into it, which theirs isn't. Even then it's been proven to be worthless until you get up into the VERY high speeds, of which the Camaro won't do without a bit of engine and aero modding.
#9 |
We have tested parts over the yrs and aluminum tube type intakes are NOT the way to go...
Stick with plastic or ceramic coated before SS or regular AL.....
SOLD
| **K&N TYPHOON and AIRCHARGER Intake kits ~ 18+ HP! ~ Lowest Prices!** | Circuit Motorsports | V8 Bolt-Ons & Tunes | 81 | 05-24-2010 05:21 PM |
