Old 07-26-2010, 11:13 PM   #1
d-ball2ss
d-ball2ss's Avatar
Drives: red jewel 2010 camro 2ss/rs
cam?????
ok i want a cam for my l99 but will this make the car less dependable now and in the long run??? and what dose something like that cost all said and done.
d-ball2ss is offline   Reply With Quote
Old 07-26-2010, 11:42 PM   #2
l99camaro
Drives: silver
A shop I know told me because the l99 has the vvt & dod a cam swap costs around 2500-3300 dollars. The size of the cam will dictate how dependable it is.
l99camaro is offline   Reply With Quote
Old 07-27-2010, 12:41 AM   #3
wow, that's expensive, guess I will not be doing a cam in mine anytime soon.
Old 07-27-2010, 10:49 AM   #4
toehead93
Drives: 2014 2SS/1LE
It is the same price for for both LS3 and L99 camswaps as long as you keep the L99 lifters. If you want to replace the lifters then yes, it gets expensive because you need to pull the heads. So you can get a mild to medium cam no problem, if you want a wild cam then the price jumps significantly.
Exactly what type of cam do they wat to install?
http://www.camaro5.com/forums/showthread.php?t=344754
Summit White 2014 2SS 1LE
Recaros, NPP exhaust, Nav
2010 2SS A6 - sold.
toehead93 is offline   Reply With Quote
Old 07-27-2010, 11:10 AM   #5
1 BAD RS 2 SS
1 BAD RS 2 SS's Avatar
Drives: 2010 RS 2 SS
all my parts to do afm / dod delete was right at $1750 , them a 3200 stall was $750 . you will also need a tune to take full adv. of parts .. labor rates very from shop to shop so use someone reliable
1 BAD RS 2 SS is offline   Reply With Quote
Old 07-27-2010, 12:33 PM   #6
lexlueger
lexlueger's Avatar
Drives: V10 BMW M5, Supercharged 2SS/RS
Wow.. DOD delete is about $300 bucks at thunder and a VVT cam runs about 650 - 740 with valve springs and phaser. I was quoted less than 1300 installed.
MAST 416 STROKER: STAGE 3 TVS 2300
CUSTOM CAM
TPIS 102 TB
IW 8 RIB PULLEY W/ OD COG REARS
NX EXPRESS/NANO KIT
KDI HEAT EXCHANGER/ROTOFAB RESERVOIR
CIRCLE D 2800 TC/FLEX PLATE/ADM TRANS COOLER
DSS DRIVESHAFT/1400 HP AXLES
EATON TRUETRAC -LPE 3.27 GEARS
DYNATECH HEADERS/MAGNAFLOW EXHAUST
SQUASH RETURN STYLE FS ID 850's E85/ FLEXFUEL
BMR/EIBACH SUSPENSION
KILL MODE, ON.
lexlueger is offline   Reply With Quote
Old 07-27-2010, 01:43 PM   #7
Bonemaro
Drives: 2010 RJT 1SS M6
Send a message via AIM to Bonemaro
A good bet would be to contact Kirk@VectorMotorSports with your cam durability questions. They have a good thing going with their cam swaps, i absolutely enjoy mine and it's considered a mild streetable cam. I beg to differ she sounds sweet and the performance you get for the cost is well worth it. My specs are in my sig. Here's a link to a nice cam idea http://www.camaro5.com/forums/showthread.php?t=73140
Bonemaro is offline   Reply With Quote
Old 07-27-2010, 02:02 PM   #8
toehead93
Installation is less if you keep DOD.
To the OP, how much power do you want to make and how much are you willing to spend?
2010 2SS A6 - sold.
Old 07-27-2010, 03:36 PM   #9
spike347
Drives: 10 Camaro 2SS,RS,SIM, 6.2L , LS3
????? that is the question I guess???
spike347 is offline   Reply With Quote
Old 07-29-2010, 12:41 PM   #10
1 BAD RS 2 SS
many more parts needed to get rid of the vvt , witch is also what i did . ls3 timing cover and gaskets , mild cam and lifters , 3 bolt cam gear , valley tray , new head bolts and all the gaskets , lifter trays . thats all i can think of for now . so yes it sounds like but you get what you want and fits your needs , i got what i wanted and a procharger this winter . hope every thing works out for all of our needs .. have fun dyno video
Cam basics CamaroSpike23 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 76 11-25-2015 12:42 PM
Going Cam Only (cam experts help!) SS 376 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 7 05-01-2010 11:00 PM
New Cam!!! getarz4u15ster Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 36 04-27-2010 07:40 AM
Camshaft Basics Milk 1027 Wiki 1 12-09-2009 01:00 AM
L99 TVS 1900 + Cam Dyno #'s ARE IN pharmd Forced Induction - V8 35 09-07-2009 05:36 AM
