Old 05-29-2009, 08:45 PM   #1
ADM PERFORMANCE
Drives: Anything I want
ADM GETS 372RWHP AND 363 RWTQ-THEN WE MOVE UP AND HOW
So I posted earlier how we got a cam with stock tune,stock airbox,stock pulleys.Then I posted an exta 26-28rwhp and torque with stock manifolds and stock catback exhaust and the above mods...
Well here is how we did it - ADM 2.5" STAINLESS STEEL OFFROAD DOWNPIPES
PLEASE USE HIGH QUALITY HEADPHONES WHEN LISTENING TO THIS CAR
6 SPEED MANUAL DYNO VIDEO
6 speed manual install-
6 SPEED AUTO DYNO
6 SPEED AUTO INSTALL
Minimum gains of 18 rwhp and torque have been observed on both automatic camaro ss and manual shift ls3 ss.The system is 22 lbs lighter than the factory cat system.20 MINUTE INSTALL ON A LIFT.30 minute install on the ground.Tools required-3/8 Rachet,24"3/8" extension,15mm swivel socket,15mm deep socket,7/8 or 22 mm 02 sensor wrench and small jackstands,1 can of penetrating lubricant,preferably a cool engine bay.Total bolt to loosen and remove is 8.Slip fit rear and 2 bolts on each side from up top.
This system is not emmisions legal and should only be installed at the track or at dyno events.Your warranty could be voided if you run these on your car.ADM is not responsible for any damage,codes or warranties voided by the install of these downpipes.The buyer accepts all terms of sale when purchasing from ADM PERFORMANCE website.
Kit includes mandrel bent stainless pipes,flanges,gaskets,bolts,dual o2 sensor bungs.Cat effiecency codes will be present when using these,the tune will also lean out .6-.8 gaining you power.
ADM PERFORMANCE is offline   Reply With Quote
Old 05-29-2009, 09:44 PM   #2
Kyle2k
LVL 50 Troll Stomper
Kyle2k's Avatar
Drives: 2010 Camaro
So the downpipe is basically a cat delete? Sounds pretty good to me
Kyle2k is offline   Reply With Quote
Old 05-29-2009, 10:05 PM   #3
LDGn63
LDGn63's Avatar
Drives: WNABEE
wow those cats make some mighty good mufflers!
sounds great without.
Why oh Why?
Windshield=10" vertical
mirror= 3 7/8" (that's almost 4") vertical
that means that the mirror is 38.75% the size of the vertical windshield...
it sure seems like the ratio could be better... just sayin....
our collective MIRROR patch:
http://www.camaro5.com/forums/showthread.php?t=24612
LDGn63 is offline   Reply With Quote
Old 05-29-2009, 10:31 PM   #4
ADM PERFORMANCE
On all SS platform vehicles that I work on(trailblazer ss,camaro ss,hhr ss) they use a straight through design muffler,in other words no baffles.
We have many in the shop to show this.Gm uses the cats to reduce most of the sound in these cars,hence having 4 cats and 2 presilencers on the ss 6 spd manual and 4 cats and a center muffler on the 6 speed auto.
This is why Nick at american racing said the factory mufflers sound great with headers,they really do..Per our dyno.
Old 05-30-2009, 12:37 AM   #5
THE EVIL TW1N
Banned
Drives: 2003 Cobra Convertible
How come you guys didn't run it to 6200 rpm?
Nice gains. Is this the first automatic (L99) SS dyno'ed?
THE EVIL TW1N is offline   Reply With Quote
Old 05-30-2009, 06:16 AM   #6
ADM PERFORMANCE
I will have to go back and look,Probably a speed limiter.
Andy
Old 05-30-2009, 09:46 PM   #7
ADM PERFORMANCE
Andy
It was forced scaling turned off when I printed it.Woops...does not make the numbers any different.
