05-26-2011, 02:15 AM | #1 |
Drives: 2085 Trans AM COBRA Join Date: Jan 2011
1998 ls1 low oil pressure
This had been bugging me. ill just explain whats going on. when i start up the car when its cold the pressure is a hair below 40psi. when its hot and driving around 45mph its at 35psi.. I was using castrol 5w-30 oil so then i changed it to castrol 10w-30 today and it's doing the same thing. I thought the thicker oil would help with the oil pressure. My dad keeps telling me its fine. he has a 99 trans am. But it never used to be like this.
05-26-2011, 04:45 AM | #2 |
Drives: 2010 ABM 1SS M6 NON RS Join Date: May 2010
I have a 99 TA as well, the factory guage is horrible. Mine does the same thing well kinda... start up to normal op temps a hair below 40psi cruising is a about 35 to 38 , WOT 50 to 60 ... for what I've seen this is pretty normal atleast on the factory guages
2010 Aqua Blue 1SS
KWC 3pc forged, Seibon hood, ZL front end, MGW, ARH full exhaust w/ Doug Thorley axle back, BTR4, Roto-fab, LSXR 102, NW 102, 3.91s 2018 GMC Sierra (Stone Blue metallic) 2016 Streetglide (Crushed Ice Pearl) 2018 Indian Scout (Bronze Smoke) |
05-26-2011, 05:40 AM | #3 |
oil pressure always drops some once engine is warm, normal.
05-26-2011, 06:04 AM | #4 |
its normal. dont worry about it, its time to worry about it if it drops below 25.
05-26-2011, 06:18 AM | #5 |
Drives: 99 Camaro SS, 79 z28, 70 GTX Join Date: Oct 2009
agreed, sounds normal
05-30-2011, 01:19 AM | #6 |
well then. guess I dont have to worry. thanks (:
Thread Tools | |
Similar Threads | ||||
A Look at GM's Oil Life Monitoring System | franknbeans | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 166 | 05-23-2014 06:31 PM |
best synthetic oil to use | hollywoodjose | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 130 | 01-26-2014 08:51 AM |
Oil Changes | Dave McFly | Off-topic Discussions | 6 | 05-18-2010 04:50 PM |
LOW OIL PRESSURE | tonymendoza | 5th Gen Camaro SS LS LT General Discussions | 4 | 10-22-2009 04:36 PM |
