08-20-2011, 12:48 AM | #1541 |
LordVader
Drives: 2011 RS 2SS 99 BMW 328i 96 K1500 Join Date: Aug 2011
Has it been definitively determined if the fuse pull works with the LS3 or do you have to disconnect the battery?
08-20-2011, 05:04 PM | #1542 |
Drives: 2010 Camaro 2SS/RS L99 Join Date: Jul 2011
I tried this yesterday, I had put 87 oct on accident like 6 months ago, I wish I would have read this back Then, it totally worked, Very awesome, Car runs alof Smoother now, all I can say is thanks to everyone .. .
:flag2:
08-20-2011, 05:37 PM | #1543 |
Booooosted.
That's one of those 'tuner' things that they never will verify to us. But the ones I talked to said yes. So I can't say every tuner but it seems that way. I've only heard it confirmed. I've never heard it denied. For whatever that's worth. LOL
08-20-2011, 05:38 PM | #1544 |
Booooosted.
I can't imagine why it would be different.
08-21-2011, 12:06 AM | #1545 |
LordVader
I can't either but I have read a few times here that you have to disconnect the battery on the LS3; not just pull the fuses.
My stock (3 week old) 2SS RS can spin the tires if I ring it out from a rolling start and turn a corner but it cannot do it in a straight line. I haven't dumped the clutch to do a burnout as I just have nightmares of breaking the tranny. I keep reading where people can do a burnout from a 5MPH start and that it's easy to do just by mashing the gas. Makes me think my car is not generating all the HP that others are. I've done the fuse pull and it seemed to give it some more guts but I'm still not rippin' the hides off.......... |
08-22-2011, 09:12 AM | #1546 |
Senior Camaro Fanatic
Drives: 2011 SS/RS manual - White Join Date: Aug 2010
I've done the pull 3 or 4 times now on my LS3. Each time it "seems" to be noticably better. However, it is always in the morning when cool and then later in the day I decide it did nothing
So as PQ suggested, I did some 0-60mph runs All were right at 7 seconds +- 2 tenths. BUT, I forgot to turn off the A/C...and it was 98 degrees. None of the runs were perfect, but they were not "try agains". Slight missed shift on one, a little laydown bog on another and a pretty clean one with some tire spin. I will try again on a cooler morning and see what I have. I think my car is going back to the low octane table soon after pulling the fuses and/or my knock sensors are detecting the weird noise in my engine or exhaust that I spoke to in another thread. |
08-22-2011, 08:16 PM | #1547 |
I pulled my fuses for 5 hours, but once I put them backing I did not start the Car for another 15 hours. This definitely made a difference on my L99 motor.
I had put 87 octane in the car like be months ago. Again all I can say is thanks, and wish I had read this sooner.
:flag2:
08-27-2011, 05:33 PM | #1548 |
Drives: 2011 Camaro SS Join Date: Aug 2011
So, I read this thread this morning. I pulled the fuses, waited for a few hours and re-installed them.
What a huge difference! All this time, it felt like something was quite not right. So it was the low octane causing the lack of performance. I've been using 91 (California) in my car from the get-go. The dealer that I bought the Camaro from must have put 87 and tricked the sensors. Dang! I almost have 6K on my 2011 SS. I wish I knew about this fix 4 months ago. Thanks for posting! |
08-27-2011, 06:52 PM | #1549 | |
Never enough time
Drives: 2010 Camaro SS 6-spd Join Date: Jun 2011
Personally, if I'm tuning any GM that supports dual octane tables, I tune based upon the octane range the customer will be running. An 87/91 dual octane tune will require fewer changes to the low octane table than, say, a 91/93 tune. But blindly copying the high table over the low table isn't doing the customer any favors. Strangely, the "LS1"-style PCMs (2006 and before) had no problems with adjusting for octane: Fill up with more than 6 gallons of fuel, and the PCM reset itself to read from the high octane spark table, adjusting for knock events after startup. Works very reliably. The E38 computer in our vehicles *should* operate the same way (otherwise, the ECM would never adjust for octane changes), but it doesn't appear to do so. Whether it's a quirk in the GM programming or a deliberate change remains to be seen, as I've not seen any GM engineers step forward with an explanation (and I doubt they will). I've done back-to-back pulls on my dyno and it does appear the ECM seems to "lock in" to the low octane table, requiring a fuse pull to reset to the high octane table. Maybe GM will fix this in a future calibration update.
Personal mission: Killing the Dynojet vs. Mustang hype
09-01-2011, 01:16 AM | #1550 |
Drives: 2015 ZL1 Join Date: Aug 2011
Tried it and it worked. LS3 car.
09-01-2011, 07:53 AM | #1551 | |
09-01-2011, 10:54 AM | #1552 |
Drives: jeep Join Date: Sep 2011
how did I miss this thread? Like it
09-01-2011, 01:30 PM | #1553 | |||||
Booooosted.
Remember, too, that in the cooler morning air your car is gonna naturally run better. So it sounds normal. Quote:
Thank you for your input. Sounds like you know your stuff. And another confirmation of the fuse pulls benefit. Do you think that most tuners will understand the need to address this? Or is it plausible that there are people needing to pull the fuses even after a tune should they get low octane in it? Thank you for posting. First post too. Awesome. Enjoy the car. |
09-01-2011, 01:39 PM | #1554 |
I had a passenger too...she was using the iPhone stopwatch. Four days off starting now, so I will do some morning runs and report back. 7 seconds.. horrible....that's my fr.ckin point of all my posts and threads.....and now somebody posts that the no catch can deal can pull timing...and another posts the KS retard tables have been found screwed up on brand new untouched cars.........go figure....no, I'm figuring that I'll eventually figure this out. Dealer say "normal" Thanks PQ
Similar Threads | ||||
2010 Camaro PCM Pin-out Description and Wire Colors (LS3 & L99) | raptor | Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum | 14 | 06-02-2020 12:51 PM |
What kind of gas are you filling up with in your '10 Camaro? | JewelZ | 5th Gen Camaro SS LS LT General Discussions | 42 | 08-02-2009 09:31 AM |
Check your Order here | bvonscott | Camaro Price | Ordering | Tracking | Dealers Discussions | 665 | 06-29-2009 01:00 PM |
