07-27-2012, 07:59 PM | #1793 |
Drives: '10 CGM 2SS/RS 6M Join Date: Oct 2009
I am not talking about the weight of the engine and really don't care. The ZL1 is heavier than the GT500 and has less HP and it can still hang. It's all about getting it to the ground and keeping it there in turns. The weight of the car itself matters and if the BOSS weighs X amount less than the Camaro, than the Camaro needs Y amount of more horsepower and the right gears to even it out. Like I said before, if they can sqeeze out 444hp from 5 liters, GM should try to squeeze 480HP from the 5.3 DI and make it a drivers race, and not about who's is bigger.
07-27-2012, 07:59 PM | #1794 |
Drives: Camaro's, always have, always will. Join Date: Oct 2010
...remember when they thought the world was flat???? Just sayin........FYI, the 5.5L rumor is not totally dead...a little birdie told me....wheres Carnac when you need him....
07-27-2012, 08:00 PM | #1795 |
07-27-2012, 08:30 PM | #1796 |
corner barstool sitter
Drives: 08 Mustang GT, 19 WRX Join Date: Jul 2012
Assuming that any new Chevy 5.3-ish motor is still a pushrod design, is less than a 10% displacement advantage enough to cover for 4 valves/cylinder and variable valve timing (and the midrange and emissions advantages that likely go along with it)?
While fully realizing the historical significance of 5.3L (aka "327"), I'm not entirely convinced it'd be quite enough. Norm |
07-27-2012, 08:38 PM | #1797 |
Hope this thread isn't goin' like the ZL1 pee'ing matches....just sayin you new guys. We been comin' here for along time to talk and hang out without all that BS. Let's keep it chill....ok?
07-27-2012, 08:43 PM | #1798 |
Too Many Great Choices
Drives: Grand Sport/Z07 Join Date: Jun 2009
In some things nostalgia shouldn't get in the way, ie. a Z28 5.0.
The Gen1 Z28 was a "race car" built for the street/track. One of the best all around packages available for the time. So using a Gen5 Camaro what combination of available parts would create the best possible Camaro "race car" for the street/track today? |
07-27-2012, 08:46 PM | #1799 |
Remember the Charleston 9
Drives: 2004 KME PREDATOR, 2014 2SS/RS/1LE Join Date: Nov 2008
We still know very little about the gen V SBC. GM can just about make whatever they want right now, just a question of what they want. Also, when did the first model year for the sixth gen Camaro get announced? Did I miss it? I see a lot of people stating the same thing like its fact.
2002 V-6 5 speed rally red (current camaro) Also driven:1992 Z-28 305 auto Red w/ black stripes (anniversary), 2001 V-6 auto light pewter metallic,1991 RS V-6 auto Black |
07-27-2012, 09:02 PM | #1800 |
Old School I guess your post got deleted. I was responding to Norm and was saying that i have faith that the new v-8s shouldn't have any trouble standing up to the competition. Also, like most on this thread I believe that GM is capable of building a Z28 that would do us proud no matter the engine. (it better have 8 cylinders).
07-27-2012, 09:06 PM | #1801 | |
Drives: GMC Acadia, Chevrolet Camaro Join Date: Jan 2009
2024 Camaro 2SS
07-27-2012, 09:15 PM | #1802 |
This is by no means a pissing contest..all just speculation and point of view...I refer back to the comment that says GM won't build a "one off" engine just for the Z/28..engines are all about heads and cams, I am SURE they can get 480hp out of a GenV 5.3, and why wouldn't they do a "one off"? FORD did. Since all of this is speculation anyway cause as was previously pointed out, we know jack about the GenV motors anyway. Let's just say its possible, GM doesn't have to do anything to this mystery engine when the 6th gen rolls around 3-4 years from now and the car is already lets say 400lbs lighter..the stats for the 6th gen would best the 5th gen just for that one reason.
07-27-2012, 09:29 PM | #1803 |
I deleted the post. I get it guys, it'a all passion, but, let's just stay within the lines. We haven't had any issues here....for the longest time, and this is the last bastion of level headed decent discusion we have on the C5 board is the Z28 section....Thats all.....no biggie. If this goes to pot then we are S out of luck.
07-27-2012, 09:43 PM | #1804 |
Bottom line is a DI would be cool in a Gen5 Z28. I just don't see that happening.
07-27-2012, 09:43 PM | #1805 |
Drives: 2015 SS 1LE Red Hot, 1970 Chevelle Join Date: Apr 2012
Because the two engines are totally different. If the current push rod 6.2 makes 426 and the current DOHC 302 makes 444, do you really expect the next 5.3 push rod to make as much?
07-27-2012, 09:47 PM | #1806 |
Tags |
700 hp z/28 in 2014, the greatest camaro |
Similar Threads | ||||
Transcript of Camaro ZL1 Q&A Webchat with Chevrolet | Tran | Camaro ZL1 Forum - ZL1 Specific Topics | 42 | 12-22-2017 04:42 AM |
BREAKING: 2012 CAMARO ZL1 - 6.2L LSA Supercharged - 6MT Revealed! | Tran | Camaro ZL1 Forum - ZL1 Specific Topics | 756 | 05-01-2013 06:22 AM |
Installation Camaro Needed for Manual for a Justice Install Package in SF Bay Area | Info@PeddersUSA.com | USA - California | 6 | 04-30-2010 08:02 PM |
The DEFINITIVE EXPLANATION OF CAMARO SUSPENSION, ISSUES, AND UPGRADES | Info@PeddersUSA.com | Suspension / Brakes / Chassis | 106 | 10-19-2009 06:08 PM |
