04-14-2014, 03:17 PM | #22822 |
[COTW 4/13/15]
Drives: Supercharged LLT Join Date: Jul 2010
I dont know honestly, (fsp) Matt tuned Zabeast's car...so hopefully he'll post up.
04-14-2014, 03:28 PM | #22823 |
Drives: 2011 CGM Camaro LS A6 Join Date: Jan 2011
On yea, I thought u had heard something. I really want to see what can be done. Especially since Matt pulled more power out of an LFX car with HP over IPF
04-14-2014, 09:51 PM | #22824 |
Drives: 2018 Hot Red ZL1 Join Date: Nov 2010
Question, I feel like my car is still in need of an alignment because I need to make little corrections to keep the car straight. Is this normal or no? It doesn't pull its just that I feel like the road makes the car move to the sides? Is this cuz Its lowered? My alignment result shows its spot on factory specs.. Maybe its me? More aware of steering?
Sent from my XT1080 using Tapatalk
04-14-2014, 09:52 PM | #22825 |
COTW 9/16/13
Drives: 2011 2LT/RS Camaro IOM Join Date: Jan 2012
Your springs may have settled a little bit and an alignment adjustment may be needed. It never hurts to bring it to a place to get it checked for free so you can know if you really need one or not.
04-14-2014, 10:38 PM | #22826 |
Well I kinda have felt that way since the beginning
04-14-2014, 10:42 PM | #22827 |
I just drove the wifes car and it feels the same. Like small adjustment needed
04-14-2014, 10:59 PM | #22828 |
I think that it might be normal and it is me that is making things more of a big deal now that I am more aware of the steering wheel. Its like all I do when I drive is see if the car goes keeps straight if I hold the wheel straight with both hands. and for most part it does but then it start going to one or the other side. now this is probably cuz of the road makes it move or the road is not straight always.. does this happen to you all? like if you hold the steering wheel centered with both hands at 11 and 2, will the car keep going straight for as long as you are driving in a "straight street"? or will you still have to make some adjustments are you drive to keep it centered? I think im going crazy !!!!
04-14-2014, 11:18 PM | #22829 |
Drives: 2011 IOM Camaro Join Date: Jul 2010
Is it only swaying towards one side more than the other, or both sides equally? Typically, lowering springs are stiffer than stock, so you will feel more feedback from the road, which translates to you noticing more bumps and road imperfections and the car following those imperfections somewhat. But like Kevin said, take the car to get the alignment checked. It may have settled some more. Pretty sure alignments come with some kind of warranty (mine was 3 months/ 3,600 miles I think).
04-14-2014, 11:21 PM | #22830 | |
04-14-2014, 11:46 PM | #22831 |
Its both sides equally. I think that's what it is. That Now I can feel more imperfections and the car follows them. Cuz in my wifes car I also have to correct steering but I don't feel so much movement in the car. I just feel like the car moves more. Like every small correction I can feel it so I think that's what is making me be more aware/worried. Bet its normal and I'm crazy
04-15-2014, 09:05 AM | #22832 | |
04-15-2014, 10:49 AM | #22833 | ||
Emerald Coast Camaros
Drives: 2017 2SS A8 50th Anniversary Join Date: Sep 2011
I imagine that the stiffer suspension just makes this more noticable for you. Nothing to worry about but a quick alignment check never hurts for peace of mind.
Current: 2017 2SS 50th Anniversary (#350)- 12.22 @ 115mph
- MX0 8-speed automatic, CF5 power sunroof Former: 2012 1LT/RS A6 - 14.11 @ 99.75mph Order: TMFF65 1100 - 5/19/16 | 2000 - 5/26/16 | 3000 - 6/1/16 3100 - 6/6/16 (TPW 6/20) | 3300 - 6/9/16 3400 - 6/10/16 | 4200 - 6/23/16 | 4300 - 6/28/16 5000 - 6/30/16 | 6000 - 7/1/16 Club F1FTY |
04-15-2014, 03:41 PM | #22834 |
Yeah I mean it doesn't pull like it did before the alignment. Its nore that now I have to correct more often which makes me feel all the imperfections.. However, sometimes Im going straight and look at my steering wheel and it is slightly off center which makes me more conscious. Other member said she is experiencing the same with the steering wheel after alignment. Any of you guys experienced this? I will have to go talk to the alignment shop. I really don't want to put it up in the lift again as the car barely clear the ramps..
