01-03-2016, 11:19 PM | #43 | |
Drives: 2014 Chevrolet Camaro SS Join Date: May 2015
I've left my plugged I and didn't start my car for two days and it started right up. I've heard of you go several days that it can run your battery down. If you are going to park car for extended time, just unplug it. It works great. I got it on sale Black Friday from auto anything.com for $149. Sent from my iPhone using Tapatalk |
01-04-2016, 01:22 PM | #44 |
Drives: 2013 2SS/RS A6 Join Date: Sep 2014
I have nothing but problems from the range.
2013 Camaro RS/SS, L99, Vmax PTB, Z-28 CAI
1966 Chevelle Malibu, 355, 4-Speed |
01-05-2016, 01:20 AM | #45 |
Drives: 2016 2SS coupe 2015 3LT Stingray Join Date: Aug 2012
Dude did you look at my sig Im running the solo axelback the jpipes cut out drone not the afm farting sound
Ported intake manifold and throttle body kooks 2" headers no cats
01-05-2016, 06:13 PM | #46 |
Drives: Camaro SS Join Date: Feb 2014
I used the Range device and it works great
Only issue I had was forgetting it plugged, drained the battery overnight |
01-05-2016, 08:40 PM | #47 |
Moonshiner
Drives: Holden SS-V L77 flex fuel Join Date: May 2012
can we turn afm on/off? or delete it??
OP of course you do whatever you like, but it would make sense to simply tune the AFM to kick in when you want it, if at all.
It can be anything from very discreet and quiet in certain gears / conditions or left stock likely loud and pervasive. BTW those who tell you the new Delphi deac lifters are dodgy, are not comparing LS lifter failure across the board. Perpetuating a fault with Eton lifters rectified MY11. I had over 130k miles on my last AFM lifters and cam, now get 610 HP and 27 MPG with AFM and VVT. NPP bimodal cans effectively take care of the Luftwaffe out the back.
Compression is King.
Naturally as-pirated, all-motor, all alcohol. |
01-05-2016, 11:39 PM | #48 |
I bought a Range Device, after about a week my car started to freak out so I returned it.
I don't think that it did anything anyway. I'll probably get the tune eventually.
Cai Intake, Pacesetter Ceramic Coated 1 7/8 Long Tube Headers and Legato axel back exhaust.
01-06-2016, 01:54 AM | #49 | |
Drives: SUMMIT WHITE 2SS/RS CAMARO Join Date: Feb 2008
your exhaust that's causing your drone. Like I said mine is completely stock except for the Solos. And no, I never look at someones signature, only what's posted. I think the only way to eliminate your drone is to go back to stock exhaust except for your solos.
01-16-2016, 12:00 AM | #50 |
Drives: 2011 Camaro 2SS Synergy Green Join Date: Dec 2015
I got the Hyper Tech 2.0 this week, installed easily Premium Tune, and disabled AFM. My car is totally a new car. I now love my new car, thanks to Hyper Tech. No more sluggish responses ,when cutting to four mode. Now it stays in V8 mode all the time. It's a pleasure to drive now. Thanks Gobby
01-16-2016, 03:20 AM | #51 |
Drives: 2006 F150 Lariat Join Date: May 2010
No, drone is the low, bass heavy resonating sound waves from the exhaust. The grotesque ricer fart can sound he's referring to is the 4 cylinder mode, specifically. It sounds horrible. Only way to get rid of the AFM sound is to tune it out, that Range thing, or stay stock.
Also, reading those posts from 2008... People were actually defending AFM lol. |
01-16-2016, 08:34 AM | #52 | ||
Good explanation of the "drone" sound:
Good explanation of exhaust theory: |
02-08-2016, 05:40 PM | #53 |
Drives: 2014 Camaro 2SS convertible - black Join Date: Jan 2016
I'm glad I found this. I got my SS about three weeks ago, and I was wondering why the exhaust note changed noticeably at times. It's usually when I'm doing around 35 to 40 steady under low power. I thought there were flaps moving in the exhaust, but I have Corsas on it so that didn't seem to make sense. I had no idea it was the AFM until now. Makes sense now. It's going back and forth from 4 to 8. It's definitely noticeable with the Corsa mufflers amplifying the sound.
Similar Threads | ||||
AFM v8 Engine | The80sman | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 23 | 06-13-2008 10:19 AM |
Camaro ls3 news...true or false? | Dark Knight | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 74 | 06-05-2008 05:29 PM |
