View Poll Results: did you change your rear differential fluid at 1,500 miles? | |||
yes, i did change my fluid after break in | 62 | 34.25% | |
no, i did not change my fluid after break in; i forgot | 30 | 16.57% | |
no, i did not change my fluid after break in; i don't think i need to | 89 | 49.17% | |
Voters: 181. You may not vote on this poll |
Thread Tools |
12-19-2011, 10:31 PM | #57 |
Drives: 2011 Summit White V6 RS Coupe Join Date: Dec 2011
It's really not a good idea to change your engine oil before the first regular scheduled change. While the old adage may have been true when your dad taught you to change the oil, today there are additives in the oil that come from the manufacturer specifically to aid in the break-in process. By changing the engine oil early, you are defeating the purpose of these additives.
As for the rear diff and tranny, do what you think is best, but imho, it's just a waste of time and money. Now if I was autocrossing or drag racing the car on a regular basis, that would be a different story. For daily driving with the occasional heavy foot, I'll just follow the normal maintenance recommendations. And, when it's time for a change, I'll also replace with GM fluids. I had a bad experience with RP in the rear diff of my 2005 GTO. It got to the point where it would just spin one tire. I replaced it with Torco 75w-90 and a friction modifier, and it solved the issue immediately. And, it wasn't slipping on the factory GM fluid either when I changed it out to the RP. I just bought the line that it was the thing to do. Lesson learned. |
12-24-2011, 10:10 PM | #58 |
Drives: 2010 Camaro 2SS LS3 6 speed IOM/IOM Join Date: Apr 2010
i changed mine at 750 miles with royal purple
01-05-2012, 07:31 PM | #59 |
what page in the manual does it say that you need to change it at 1,500 miles?
01-05-2012, 07:50 PM | #60 |
Retired Navy
Drives: 2010 2SS/RS Join Date: Mar 2011
There isn't a page because it doesn't exist.
Retired Navy... A Husband. A Dad. A Veteran as of 2011. 2010 2SS/RS A6 - FlowMaster CatBack - I'm not a Amsoil dealer and will never be one. I believe in its capabilities from personal use with oil analysis reports backing up my OCI's. Besides, I know more than most cut and paste Amsoil dealers which are at least 95% of them.
01-07-2012, 01:04 PM | #61 | |
Drives: 2011 IBM 1SS/RS L99 Join Date: Mar 2011
The owner's manual doesn't say you need to change it at 1500 miles. However, as previously stated:
01-07-2012, 02:46 PM | #62 |
Retired Navy
Ok, I'll eat crow on that one as I never read the break-in section of the manual. We got the car used/new as a demo. The dealers 50yr old daughter was driving it and only put 2900 miles on it in a year.
01-10-2012, 08:29 AM | #63 |
502 RWHP N/A
What weight do I need to use for an auto, keep in mind I'm not running stock 3:27 gears
factory motor factory trans, Gpi ss4 cam stock heads ported and milled, full exhaust, circle d 5c 4000 triple disk, 3:91 rear end with posi mod, cai, bmr derlin rear diff bushins, bmr derlin cradle bushins, bmr trailing arms, toe rods with bushings, and bmr anti extreme sway bar. Weld rt-s 17x5 fronts and 17X10 rears on mickey thompson et street r's
01-10-2012, 09:11 AM | #64 |
knows 2 facts about ducks
Probably 75w-90. I don't see how different gears would change that.
01-10-2012, 09:30 AM | #65 |
502 RWHP N/A
Thanks
02-02-2012, 01:05 AM | #66 |
I didn't do it at 1,500 miles. I just did it at 10K - it was dirty as..well as dirty can be. It was like a charcoal sludge. Kinda wishing I had done it a bit sooner but it's done.
I'm with just about everyone else..if you haven't done it, go do it. The car 'felt' smoother after it was done, also.
2011 Camaro 2SS w/RS, Imperial Blue Metallic - Toy.
CAI Inc. cold air intake, SOLO axle-back with j-pipes, Kooks 1 7/8" long tube headers with Kooks high flow cats, GPI SS2 VVT cam + engine goodies and dyno tuned by Ryan/Dr. L99/GPI. |
02-02-2012, 07:40 AM | #67 | |
Drives: 2015 Camaro 1SS Join Date: Dec 2011
Similar Threads | ||||
CAMARO WIKI | Tran | Wiki | 66 | 04-22-2024 11:41 AM |
DIY - V8 L99 Automatic Transmission Fluid Change | Goliath | Camaro DIY & HOW-TO instructions & discussions | 76 | 01-13-2023 12:24 AM |
5th Gen Suspension -- The Book | JusticePete | Suspension / Brakes / Chassis | 151 | 05-07-2015 05:52 PM |
Differential Fluid Change FAIL | jagan323 | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 36 | 03-10-2011 05:35 PM |
What is your Ave Fuel per gallon on V8 LS3? | dxy2jbaby | 5th Gen Camaro SS LS LT General Discussions | 61 | 11-17-2010 05:52 PM |
