02-21-2012, 08:43 PM | #1 |
Drives: 2013 Fiat 500 Abarth Grigio Join Date: Apr 2011
Small issue not super important.
When in manual mode for the automatic camaros V6 and V8 to go back to sport mode u hold down the + button on the back for several seconds and its supposed to go back to sport mode but my car doesnt it stays the same in M mode what could be wrong?
02-21-2012, 08:45 PM | #2 |
I used to be Dragoneye...
Unless something's changed, my understanding was that you needed to slide the shifter from M to D, back to M to give shifting control back to the car.
02-22-2012, 04:27 PM | #3 |
When i had my V6 auto that is what i did i just held down the + button for 5 to 10 seconds and it when back into sport more now i dunno if 2010 auto is different from 2011 or V8 or V6 is different just was wondering if it is normal.
02-22-2012, 04:30 PM | #4 |
Booooosted.
I'm totally confused here.
Are you talking about sport mode, or manual mode? They are two different things and really have nothing to do with each other. |
02-22-2012, 04:43 PM | #5 |
Drives: CGM 2SS/RS, 1987 & 2014 Silverado Join Date: Oct 2010
Owners manual section 9-32
When in Tap Shift mode with a V8 model, the driver can exit Tap Shift by holding the right (upshift) control for two seconds. The transmission will return to automatic shifting. On V8 models, the driver may choose to briefly enter Tap Shift mode while in D (Drive). Tapping either the upshift or downshift control will place the transmission in Tap Shift mode. The driver may then exit Tap Shift mode by holding the upshift control for two seconds. The system will return to automatic shifting after 10 seconds of cruising at a steady speed, or when the vehicle comes to a stop.
02-22-2012, 05:08 PM | #6 |
Look at that....learn something new every day!
Thanks for posting, MMC! |
02-22-2012, 05:10 PM | #7 |
Booooosted.
So then just manual mode and not sport mode?
02-22-2012, 05:12 PM | #8 |
OP was asking how to go from manual mode back to sport mode.
02-22-2012, 05:16 PM | #9 | |
Booooosted.
OMG,,,, I was looking for previous posts describing sport mode, Manual mode, and competition mode etc. and I found this nearly 3 year old gem from yours truly.
I'm not as funny as I used to be. LMAO Quote:
02-22-2012, 05:28 PM | #10 |
02-22-2012, 07:07 PM | #11 |
I know how to go from sport mode to manual mode the problem is, That when i hold the upshift to go back to sport mode from manual mode it doesnt work It stays in manual mode ive held for aslong as ten seconds with no result/upshift
02-22-2012, 07:52 PM | #12 |
Drives: 10 1LT SIM; 91 B4C sleeper Z Join Date: Aug 2009
I thought people had problems with a clutch!?!? This is confusing.
02-23-2012, 12:18 PM | #13 |
What year car? 2010 cars may have been different, this information was from a 2011 manual. I do not see this line in the 2010 manual. (below)
Manual Mode Tap Shift Tap Shift allows the driver to manually control the automatic transmission. To use Tap Shift, the shift lever must be in M (Manual Mode). Vehicles with this feature have flags on the top of the steering wheel to indicate to the driver the location of the switches on the back of the steering wheel. Tap the left switch to downshift, and the right switch to upshift. A display in the Driver Information Center will show which gear the vehicle is in. See Driver Information Center (DIC) on page 4-27 for more information.
While using the Tap Shift feature, surfacesthe vehicle will have firmer, quicker shifting for increased performance. You can use this for sport driving or when climbing or descending hills, to stay in gear longer, or to down shift for more power or engine braking. The transmission will only allow you to shift into gears appropriate for the vehicle speed and engine Revolutions Per Minute (RPM). The transmission will not automatically shift to the next higher gear if the engine RPM is too high. If shifting is prevented for any reason, the message Shift Denied will appear in the DIC, indicating that the transmission has not shifted gears. While in the Tap Shift mode, the transmission will not automatically downshift on hard acceleration. When coasting to a stop, the V6 transmission will automatically downshift to 1 (First) gear, and the V8 transmission will automatically downshift to 2 (Second) gear. A 1 (first) gear start can be selected using the Tap Shift controls on V8 models When accelerating from a stop the transmissions will hold these gears until the driver manually selects higher gears using the Tap Shift controls. When accelerating the vehicle from a stop in snowy and icy conditions, you may want to shift into second gear. A higher gear ratio allows you to gain more traction on slippery
02-23-2012, 06:15 PM | #14 |
Its a 2010 so maybe it isnt for the 2010's and added it to 2011 thanks for the Info MMC
Similar Threads | ||||
PWA 3: Dark of the Lounge | CamaroSpike23 | Off-topic Discussions | 159786 | 08-09-2012 03:51 PM |
Small Paint issue is now a huge mess... | hercamaro | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 28 | 12-11-2011 01:57 PM |
Fifth Generation Promises a Leaner and Meaner Small Block | LOWDOWN | General Automotive + Other Cars Discussion | 6 | 12-01-2011 01:00 PM |
2008 Shelby GT Super Snake (600-725 HP) | .Hack | General Automotive + Other Cars Discussion | 15 | 03-21-2008 06:54 PM |
Shelby Super Snake | KILLER74Z28 | General Automotive + Other Cars Discussion | 18 | 07-23-2007 07:12 PM |
