Old 05-28-2015, 03:12 AM   #1
2010_camaro
2010_camaro's Avatar
Drives: 2014 Camaro SS
anyone upgrade the fuel pump?
Who all has upgraded their fuel pump? What did you go with?
MODS 6.0 forged iron block, TH400, B&M shifter, DSS axles & driveshaft, Viking / BMR suspension, Full custom fuel system with cell, Twin 76mm teriyaki tornados on 24lbs.
https://www.instagram.com/whoopa_ss/
2010_camaro is offline   Reply With Quote
Old 05-28-2015, 08:25 AM   #2
Sakudog
Sakudog's Avatar
Drives: 2019 ZL1 1LE A10
My car required a bit of pump for my desire to run E85 whenever i wanted....
http://www.foreinnovations.com/Produ...uctCode=43-503
Options I selected:
-8 feed / -8 return PTFE line
Flex Fuel Sensor
The big TI pumps
Relay setup (the nice one)
Filter & Bracket
Ryker #29
2019 ZL1 1LE A10
2015 Z/28 #809
Sakudog is offline   Reply With Quote
Old 05-28-2015, 09:27 PM   #3
revobasher
revobasher's Avatar
Drives: 2013 ZL1
I have the fore setup. Highly recommend! Running Dual 400s with E85 and ID1000 injectors. Didn't do flex fuel sensor as my car is not a DD and there's no shortage of corn in MN. If you go worst the sensor go with DSX.
Remember the FPCM needs to be plugged back in when you bypass the stock pump. As it's part of CANBUS network.
2013 ZL1 - Blue Ray Metallic
JDP 850 Package
740hp/700tq @14lbs on E85
Build Thread
revobasher is offline   Reply With Quote
Old 05-28-2015, 10:07 PM   #4
prdi
Drives: CTS-V
Options I selected:
Flex Fuel Sensor
The big TI pumps
Filter & Bracket
fore does not include the flex fuel sensor.. The interceptor kit is just the AN fittings needed to install the sensor. but not the sensor or the connector for it
prdi is offline   Reply With Quote
Old 05-30-2015, 03:35 PM   #5
Sakudog
Sakudog's Avatar
Glad you clarified that, yup the sensor is an additional component that must be purchased. AMP installed the setup so I wasn't sure what they ordered for the the sensor specifically
Ryker #29
2019 ZL1 1LE A10
2015 Z/28 #809
Old 06-05-2015, 09:10 PM   #6
2010_camaro
I was looking at picking up a stock zl1 pump second hand for a side project.
Old 06-05-2015, 09:33 PM   #7
Rico
Flying da helicopter
Rico's Avatar
Drives: Black SS/RS
I have the LPE dual fuel pump for my setup. No lack of fuel pressure here.
Rico is offline   Reply With Quote
