Old 05-10-2014, 05:04 PM   #1
on3wego
on3wego's Avatar
Drives: 2014 zl1 triple black
Smile zl1 upgrades
Have a 2014 zl1. Looking to do bunch of mods all at once. Trying to get them all together. Best pulley combo. Isolator. Idlers.. cai.. headers. CRANK damper. Already have a cam I think I want. With springs and pushrods. Upgraded heat exchanger. Idk which is best.. fans or no.fans.. just wanna get all together so can get changed and tuned..
Thanks
on3wego is offline   Reply With Quote
Old 05-10-2014, 11:12 PM   #2
SamHouseIII
I Carry!
SamHouseIII's Avatar
Drives: 2013 CRT ZL1
Lots of options out there....I did some research and posted some links out there..and I know I missed a few. I went with JRE for the simple fact of industry expertise and the free tunes upgrades that come with the parts!
http://www.camaro5.com/forums/showpo...7&postcount=15
I am a Modaholic!! Please Help!! Do Not feed my addicition....See build...
http://www.camaro5.com/forums/showthread.php?t=261540
From Oklahoma, Join us on Facebook
https://www.facebook.com/groups/okcamaros/
SamHouseIII is offline   Reply With Quote
Old 05-11-2014, 02:03 AM   #3
on3wego
on3wego's Avatar
Looks good. I like most of them but some stuff I want to do differently...
Been trying figure out what pulley combo like 9.55/2.50 or do 2.38/ 9.55.. or even a 10 lower.. Been also debating on how much of a damper needed.. a 10% or more.. so many variables.. even the cai.. Roto fab or k and n..? Or even cai lol.. idk.which breathe better
Old 05-11-2014, 02:38 AM   #4
BumblebeeQ8
BumblebeeQ8's Avatar
Drives: '14 ZL1 Ashen Gray Metallic
So far i have a Roto-fab (Carbon Fiber) looks awesome and the blower whine is freakin Cool, i also have a Ron Davis HX on the way
and Elite catch can not yet installed
soon i will add a Ron Davis Radiator and D3pe water Tank Reservoir
as far as other mods will hold off for now, as the car has less than 1000Miles
'14 ZL1 AGM-A6 (SOLD)
BumblebeeQ8 is offline   Reply With Quote
Old 05-11-2014, 09:45 AM   #5
white ZL1
Drives: none
This stuff has been posted over, and over, and over....and there is a TON of information on this site if you search for it.
Every question you just asked can be answered, you just need to spend some time doing some research and learning.
white ZL1 is offline   Reply With Quote
Old 05-11-2014, 09:53 AM   #6
wirebender
wirebender's Avatar
Drives: 2017 ZL1, A10, White, sunroof, nav
Perhaps this might help: see attachment
wirebender is offline   Reply With Quote
Old 05-11-2014, 09:56 AM   #7
Baer383
Baer383's Avatar
Drives: 2013 ZL1 Ashen Gray
Thanks
You already know I'm spinning my SC past the recommended speed with a 2.55/9.55 ,make sure you use the Lingenfelter chart and use blower speed vs PSI b/c PSI will change depending exhaust and some other factors.
Check post 11
http://www.camaro5.com/forums/showthread.php?t=346630
I don't have to know everything,I just need to know,what I need to know,when I need to know it!
MODS, a lot of money,a lot of parts,a lot of time,a lot of patience.
754 RWHP 747 RWTQ 93 Octane
http://www.camaro5.com/forums/showthread.php?t=347243
Baer383 is offline   Reply With Quote
Old 05-11-2014, 11:08 AM   #8
ADM PERFORMANCE
Drives: Anything I want
Or just go with what we offer.
We have more to offer in this arena than most companies,we not only manufacturer in house but we also test in house...Not just a bolt on shop.
Andy
ADM PERFORMANCE is offline   Reply With Quote
Old 05-11-2014, 11:38 AM   #9
LuckyZL-1
Ragtop Rocket!!!
LuckyZL-1's Avatar
Drives: Black on Black Convertible
Andy
+1
ADM built 2013 Triple Black ZL-1 Convertible M6
ADM custom cam, LPE stage 2 heads with dual valve springs, LS-3 ported throttle body, LPE 2 piece pulley, LPE overdrive balancer, 10% overdrive pulley, ported supercharger inlet, ADM race intake system, stainless works 1-7/8 headers, Injector Dynamics injectors, ADM heat exchanger, ADM dual fuel pump system, ADM exhaust switch, ADM 3 tunes tuning package.
744rwhp 727rwtq
LuckyZL-1 is offline   Reply With Quote
Old 05-11-2014, 11:42 AM   #10
white ZL1
Drives: none
Andy
My signature agrees with you.
Old 05-11-2014, 12:55 PM   #11
on3wego
on3wego's Avatar
Doing those sized pullies.. can I just change the idler pullies.. 50mm/100mm? Will that help things.
Also how much more are u spinning the blower over the recommendation?
Is it safe to run 14lbs? I think it will make good power there... thoughts??
Old 05-11-2014, 12:57 PM   #12
Baer383
Baer383's Avatar
I'm running 15 lbs and I bought the Lingenfelter relocation bracket and used the stock pulleys.
Old 05-11-2014, 01:17 PM   #13
on3wego
on3wego's Avatar
Andy
I really considering yal. I just trying to do all the engine stuff at once so don't need to do multiple tunes. I also want to use meth kit only thing I have is BTR cam spring and pushrod kit ordered. His stage 3 blower. Everything else I can have yal do. Ported blower. Snout.. 102 mm tb. Pulley swaps. I can also pay cash.. one of the major things is trying to decide to cncd the lsa heads or buy a aftermarket 255
Old 05-11-2014, 01:19 PM   #14
on3wego
on3wego's Avatar
How are you running 14 lbs without pulley swap?
Bare with me I'm trying to learn about blowers. This is my first blower setup. Not my first built car tho
