Old 04-05-2014, 03:09 PM   #1
smokum
smokum's Avatar
Drives: 2010 2ssrs
Tall deck lsx build anyone?
Just wondering if anyone has done a tall deck lsx build in a fifth gen. What size? Thought about building a tall deck 4.25 stroke 4.185 bore long rod combo. Basically a 467ci. Stuffing a couple big turbos on it and go. Or maybe a big whipple or new maggie heartbeat and have some serious low end grunt. With a small shot of juice. Anyone seen a builds like this out there i can check out.
smokum is offline   Reply With Quote
Old 04-05-2014, 04:11 PM   #2
H-E
Drives: 2010 zr1 Camaro 2011 vert
I have a 454 lsx Maggie now and it's a ball...I wouldn't go any bigger tho..makes over 800 rear wheel on 93 no meth
H-E is offline   Reply With Quote
Old 04-05-2014, 04:43 PM   #3
smokum
smokum's Avatar
Drives: 2010 2ssrs
Auto or manual? My current setup is 700rwhp with 417 with maggie on race gas with auto and 3200 stall. Im looking for much more if i build something new.
Old 04-05-2014, 06:03 PM   #4
old motorhead
Drives: Maggie blown LS3 vette
The Heartbeat is going to limit you somewhat unless you get a bigger crank pulley. It's a front drive and a 3.2" pulley is your smallest pulley option. I like mine, but feel it's more at home under 700 at the wheel. Much above that and you probably need a bigger blower.
I'd bet it would take some type of spacers/adaptors to mate any top mount supercharger to a tall deck LS motor.
old motorhead is offline   Reply With Quote
Old 04-05-2014, 07:53 PM   #5
smokum
smokum's Avatar
Drives: 2010 2ssrs
Thats not a problem. I have already designed pulleys and a 10 rib setup for the new heartbeat lsa drive. Whatever combo is needed i can make it. I have already built a 2.7 upper and a 9.73 lower combo. It made 835rwhp and 900+ rwtq on a 417 with a set of lpe ported heads and stage 3 tooley cam with a manual. I was thinking of going for more cubes for the torque. 1000rwtq maybe 850-900rwhp. I would like to run in the nines and be able to run 200 at the texas mile. Maybe need some nitrous later for that.
Old 04-05-2014, 09:39 PM   #6
2SS45th
2SS45th's Avatar
Drives: 11 Seconds or Faster
If you're building a mile car the long stroke isn't the way to go, I'd go 416 with more boost so you can keep the top end.
I Ain't About That Stock Life.
2SS45th is offline   Reply With Quote
Old 04-05-2014, 09:51 PM   #7
Trackman
Trackman's Avatar
Drives: 67RS Camaro ,Black 2013 ZL1
I think a 427 is the biggest ya want to go if your adding boost. Bigger ci for a naturally aspirated set up.
Trackman is offline   Reply With Quote
Old 04-06-2014, 04:48 PM   #8
smokum
smokum's Avatar
Drives: 2010 2ssrs
Nelson always builds big ci twin turbo cars. I thought these lsx blocks were good to 2500hp. Im only looking for around 90-1000 rwhp. Im thinking its going to be a 4.185 bore with 4.000 stroke with the best internals. Callies dragon slayer oliver rods diamond pistons etc. I want 900-1000 lb ft of torque at 3000 -3500 rpm not 5000+ to get this heavy turd out the hole. With 3.73 gear and 3200 stall and my 15 inch 275/60/15 mickey pro x drag radials and skinnies my coilover adjustability it should go pretty good i would think.
Old 04-06-2014, 05:04 PM   #9
H-E
Sounds like you have all the answers let us know how it turns out.I would really like to see what you come up with.What cr will you have?
Old 04-06-2014, 06:14 PM   #10
smokum
smokum's Avatar
Drives: 2010 2ssrs
I dont have all the answers. I just have a direction i would like to try. I think compression will be around 9.5-9.75. Andy at adm will be doing the build for me when its time. He knows best. I just want something a little different. I love the stump pulling torque of a maggie. So thats what i would like to capitalize on. Heavy cars need torque to get them to move. My 417 maggie combo runs hard. Just not hard enough. But does it ever.
Old 04-06-2014, 06:19 PM   #11
old motorhead
That's spinning that poor TVS 21,600 rpm at 6000 engine rpm. What are you doing to semi control IAT's?
Old 04-06-2014, 06:29 PM   #12
smokum
smokum's Avatar
Drives: 2010 2ssrs
That was adm performance ctsv with the new heartbeat lsa supercharger. He used a huge ice tank/ pump system in the trunk that kept iat's down low. That system works great with the way he designed it. Car was nothing less than amazingly impressive.
Old 04-06-2014, 07:22 PM   #13
H-E
Imo with a lot of cubes you need about 11-1cr.That will fall off like a rock about 5500 rpm maybe even sooner.
Old 04-06-2014, 09:04 PM   #14
smokum
smokum's Avatar
Drives: 2010 2ssrs
We will see what andy thinks on that one. Lol. I know its going to be a short deck. Only 440 cubic inches. With trick flows or brodix heads. Plus the lsa drive and the new heartbeat blower. How much compression is your 454lsx H-E. Is it the crate engine with a maggie.
