Member Car Journals Want to keep a long term Camaro project journal to share with the community? Use this forum to create a single thread which you can update over time to document the progress.
Old 07-03-2012, 03:27 PM   #1
2SS45th
2SS45th's Avatar
Drives: 2012 45th SS, 2006 Dodge Cummins
This is the build thread for my 2012 Camaro 45th Anniversary SS Coupe, it was purchased with an M6 transmission and the hurst shifter (the only option). Overall, the goal for the build is to become one of the few 9 second Camaros here. To get there, I plan on using the Magnacharger TVS2300 with an LSX motor and a little nitrous . I will be keeping the clutch pedal for a bit, but a TH400 is already in the works. Here goes nothing!
I picked up the car on 1 June, 2012; here it is once I got it home!
Special Thanks to:
Stevinson Chevrolet
USA Performance Engines
Texas Speed and Performance
Jessika at Supercharger Connection
Jannety Racing
Nitrous Express
Hendrix Engineering
Tire Rack
Summit Racing
Fuel Injector Connection
Vivid Racing
Modulare Wheels
Mods to Date:
Engine:
LSX Short Deck Block
Callies Compstar 4.000" Stroke Crank
Callies Compstar I Beam 6.125 Connecting Rods
Wiseco 9.0:1 4.065 Bore Pistons
ARP Main Stud Kit
LS3-LSX 6 Bolt Heads
ARP 6 Bolt Head Stud Kit
Custom TSP Blower Cam (undecided)
PRC .675 Dual Valve Springs with Titanium Retainers
Melling High Volume Oil Pump
Cometic Head gaskets
Nick Williams 102mm Throttle Body
RX Dual Valve Monster Catch Can
Lingenfelter 10 rib 6% Overdrive Kit
Power Adders:
Magnuson TVS2300 with OD Cogs, Ported Snout, and Ported Tub
Nitrous Outlet Single Nozzle Wet Kit
Exhaust:
Stainless Works 2" Primary Headers
Magnaflow Competition Series 3" Center Exit
Fuel System:
LPE Dual Fuel Pump
FIC 80lb Injectors
Drivetrain:
Spec Stage 3+ Clutch
DSS 1000hp Axles
Eaton TrueTrac Differential
JRE Billet Main Caps
Coming Soon: TH400
Suspension:
Eibach R2 External Reservoir Coilovers
Eibach 29mm Sway Bars, Front and Back
BMR Fabrication Complete Pro Bushing kit
Pfadt Rear Toe rods
Pfadt Rear Trailing Arms
Lakewood Subframe Connectors
Hotchkis Strut Tower Brace
Exterior:
Plasti dipped Bowties
Interior:
45th Anniversary Mats
Wheels:
Modulare M2s: 22x9.5 and 22x11 wrapped in PZero Neros
Exhaust Clips:
Walk through:
Idle Clip:
Revving:
2SS45th is offline   Reply With Quote
Old 07-30-2012, 01:03 AM   #2
YoungCamaroSS
YoungCamaroSS's Avatar
Drives: 2010 Regency Avalanche LTZ 5.3L
its about time somebody puts on the center outlet diffuser,looks sick man!! great job. make a revving video,i want to hear that monster!
YoungCamaroSS is offline   Reply With Quote
Old 07-30-2012, 01:31 AM   #3
pierre777
HT5 COTW 9/3/2012
pierre777's Avatar
Drives: Cyber Bullet
car sounds sick man and i like the center exhaust idea ,good work .
Old 08-07-2012, 04:14 PM   #4
2SS45th
2SS45th's Avatar
Thanks for the compliments guys! Gotta find someone willing to stand back there for the vid
LSX416 Blown & Sprayed, hunting for 9s! Build below:
Old 08-18-2012, 09:59 PM   #5
audiomikej
audiomikej's Avatar
Drives: the wife crazy talking Camaros
Nice! thanks for sharing.
audiomikej is offline   Reply With Quote
Old 08-20-2012, 11:10 PM   #6
2SS45th
2SS45th's Avatar
Got my new wheels today, hopefully get them on the car tomorrow, so stay tuned for pics!
Old 08-31-2012, 03:46 PM   #7
IPT
Drives: '02 Trailblazer, '12 Camaro 2SS/RS
cars sounds good. You should post up the pics of your new wheels! So on a scale of 0-10 how much louder would you say the new exhaust is vs the stock one? Personally I am not looking for much louder but just "better" and headers with Magnaflow is up there on the list of options.
IPT is offline   Reply With Quote
Old 09-02-2012, 02:40 PM   #8
2SS45th
2SS45th's Avatar
Here's my scale: 1 is stock, and 10 is a full on drag car. It's probably a Seven without a cam. And I'll post wheels pics right now!
Old 09-03-2012, 06:12 PM   #9
Boost6924
Drives: 2SS/RS
Very nice!
438cid IPS Twin Turbo.
Boost6924 is offline   Reply With Quote
Old 09-09-2012, 02:36 PM   #10
IPT
more wheel pictures .... Just kidding, , but I would like to see some more pics though. I'm looking at the Modulare wheel myself. What's your impression going from the 20's to 22's?
So the headers and Magnaflow (and headers) exhaust really bumped up the sound levels? I heard the Magnaflow wasn't too loud. I want the power, but not all the noise. I was thinking magnaflow was the answer.
Old 09-11-2012, 05:31 PM   #11
2SS45th
2SS45th's Avatar
Magnaflow is defintely the answer, just not the 3" center exit system. That system is currently the only 3" they have without mufflers. I will get better pics of the wheels soon too. Going to the 22s was different, and the ride isn't as solid. Can't say anything bad about Modulare, just didn't really want to spend 8k, but I liked them a lot!
Update: Ordered a Complete Suspension set up, will be installing within the next week! Eibach R2 External reservoir coilovers, Eibach Sways, BMR complete bushings, Lakewood subframe brace, Hotchkis strut tower brace, and Pfadt rear to and trailing arms!
Old 10-08-2012, 04:04 PM   #12
2SS45th
2SS45th's Avatar
Supercharger will be here tomorrow! Pics to follow, hoping to be installed by end of the month.
Old 10-10-2012, 04:42 PM   #13
2SS45th
2SS45th's Avatar
Project Officially Started:
Old 10-10-2012, 10:28 PM   #14
BlownChevy
Drives: Depends on the day of the week.
Wow
10060 Canoga Ave Unit A Chatsworth, CA 91311
818-998-1975
brian@superchargerconnection.com
www.superchargerconnection.com
www.superchargersonline.com
BlownChevy is offline   Reply With Quote
Old 10-14-2012, 09:45 AM   #15
2SS45th
2SS45th's Avatar
Another picture of the wheels, won't be long until she's put away for the winter!
Old 10-20-2012, 12:18 PM   #16
2SS45th
2SS45th's Avatar
I'm running out of room in the garage, better get started soon!
Old 10-20-2012, 12:38 PM   #17
willhe64
willhe64's Avatar
Drives: 2012 45th Vert, 2011 4x4, 9sec Vega
Nice build! Can we see some more pics of the back of the car with that exhaust? Looks trick.
I feel it only fair to warn you, I have a black belt in CAPS LOCK.
willhe64 is offline   Reply With Quote
Old 10-20-2012, 12:44 PM   #18
2SS45th
2SS45th's Avatar
Yeah, I can go snap a few now, I'll have to polish the tips though
Old 10-20-2012, 12:46 PM   #19
willhe64
willhe64's Avatar
Old 10-20-2012, 12:51 PM   #20
parkerss
Drives: 2013 Camaro
Very nice...keep posting your build..
parkerss is offline   Reply With Quote
Old 10-20-2012, 01:01 PM   #21
2SS45th
2SS45th's Avatar
That's the best they've ever looked, Mother's Billet works pretty well on Stainless so you guys know.
Old 10-20-2012, 01:38 PM   #22
willhe64
willhe64's Avatar
Me like! Very cool, thanks for the pics.
Old 10-20-2012, 01:42 PM   #23
2SS45th
2SS45th's Avatar
Thanks! Definitely, glad to get pics of anything if someone wants one. I will keep adding more pics as I go, how's the 45th Vert?
Old 10-20-2012, 06:08 PM   #24
willhe64
willhe64's Avatar
Love the vert. Putting it away for the winter tomorrow too. sigh. Only mod so far is the heritage grill. Going to put drop springs and some suspension upgrades in it this winter I think.
Old 10-20-2012, 06:28 PM   #25
2SS45th
2SS45th's Avatar
Very nice, I know the feeling, I hate the idea of having to put mine away for the winter. But, better than having them out in all the snow and ice. I'll let you know what I think of my Eibach stuff, it looks real high quality.
