Old 06-01-2018, 12:44 PM   #1
Jburnham54
Jburnham54's Avatar
Drives: 2010 Camaro SS
pros and cons. race fuel, meth or e85.
i would prefer just getting a few drums and running race fuel. its a street driven car i just woukd feel safer gaining a little more from race fuel. my concerns are what will it do to the fuel system if it sets in the car. ive heard amazing things about meth and horror stories. never messed with e85. just looking for some input on benefits and cons of these and which one i should go with.
Jburnham54 is offline   Reply With Quote
Old 06-01-2018, 12:52 PM   #2
hou30guy
Drives: 2011 convertible 2ss/rs
E85 definitely cheaper and still 105 - 110 octane roughly
Sent from my SM-N950U using Tapatalk
hou30guy is offline   Reply With Quote
Old 06-01-2018, 12:57 PM   #3
dreksnot
Served USN - Atomic Chimp
dreksnot's Avatar
Drives: 13 Camaro LSX434 TT M6, 21 ZLE A10
*Race Pro:
Higher octane for more timing and power
*Race Con:
Cost
Limited “shelf life”
Additional tune necessary when running if you’re a street car too
*Meth Pro:
Cooler IAT so no timing pulled
Safety margin for FI tune
*Meth Con:
If tune for more power on meth, if fails, could result in detonation
Tank to maintain
Corrosive to blower rotors (or am I thinking nitrous?)
*E85 Pro:
Cost
With FF sensor, car adjusts additional timing with good tune
Camaro fuel system compatible so not corrosive
Motor runs cooler (valve temps - not ECT or IATs though)
*E85 Con:
Availability
Requires fuel system (pump, injectors) for the 30% more fuel required
In excess of 1,000WHP
LSX434 | AGP 65/65 TT | BTR Equalizer Intake | Trickflow 245cc cathedral | BTR custom cam | Cortex EBC | n2mb WOT | ID-1700x | Brisk GR12S | RPM Lv 7 TR6060 | AGP's Triple 525LPH Fore Fuel | Monster LT1-S Triple | 4.11 DSS Proform 9", CF driveshaft, 1400hp axles | Hurst Line Lock | MGW Retro Short Throw w/old skool Hurst T-handle | ADM solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Moreno camber/caster plates
dreksnot is offline   Reply With Quote
Old 06-01-2018, 01:02 PM   #4
hou30guy
Got it down pack and yes the meth part eats the supercharger blade coating over time
Old 06-01-2018, 01:32 PM   #5
rgrmoreira13
rgrmoreira13's Avatar
Drives: 2015 2SS 1LE
is that with the top mounted superchargers or with all of them ????
that is very concerning.
Specs
TSP Stage 2 Boosted Cam 227/235 at 114 LSA
Fore Innovation Triple pump staged (Walbro 342 primary and 2x Walbro 450 secondaries)
Procharger D1x with a 3.85 pulley
ID1050x Injectors
Flex Fuel Sensor
Monster LT1 Twin Disk Clutch
Holley Sniper Efi Intake Manifold
NW 103mm Boosted TB
747rwhp at 12psi on E85
rgrmoreira13 is offline   Reply With Quote
Old 06-01-2018, 03:04 PM   #6
Jburnham54
Jburnham54's Avatar
ive read meth pits blowers, id like to strictly run 100 or 105. i can get street blaze, ms109 and 260gt and gt plus by the drum fairly cheap. so that elinates meth. ican also get e85. my biggest concern is eating up my fuel system while it sits idle for a week or two when im out of town. and i do have a fore innov. dual pump return system with id1050x injectors.
Old 06-01-2018, 03:35 PM   #7
Unavowed
Unavowed's Avatar
Drives: Twin turbo G8 GXP
Originally Posted by dreksnot View Post
*Race Pro:
*Race Con:
Cost
*Meth Pro:
*Meth Con:
Tank to maintain
*E85 Pro:
Cost
*E85 Con:
Availability
I agree with this, but will go on to say that if you have E85 available and either already have or can invest in a robust fuel system, it is the way to go. Flex fuel allows you to run any % of ethanol you want. Mix it with race gas at the track if you want. It is a gift from the race gods.
Unavowed is offline   Reply With Quote
Old 06-01-2018, 04:34 PM   #8
sixty9fordkiller
Donkey Dick Cam Camaro
sixty9fordkiller's Avatar
Drives: 2010 2SS/RS LS3 M6
im gonna do the E85 conversion on my car. gonna do a ZL1 pump and LSA injectors. I daily drive it so race gas wouldn't be too practical
Bone Stock
sixty9fordkiller is offline   Reply With Quote
Old 06-01-2018, 04:44 PM   #9
43Camaro
43Camaro's Avatar
Drives: [COTW 8/3/15] 2010 Camaro SS L99
This has been debated at Nasium with very different opinions. Do some research on current users and mileage they have run Meth with blowers. I’m running it and did a ton of research prior. I moved forward with my decision based on my research. Very happy with my choice..
A Little bit of power. ALL WORK DONE BY ME!
Just added 2021 ZL1 1LE to the Stable!
https://www.camaro5.com/forums/showthread.php?t=418273
43Camaro is offline   Reply With Quote
Old 06-01-2018, 05:52 PM   #10
Jburnham54
Jburnham54's Avatar
set aside race fuel cost, if i just run race fuel will i have to worry about it corroding thibgs when fuel sits in it for a week or two
Old 06-01-2018, 06:39 PM   #11
BiggFoot
BiggFoot's Avatar
Drives: 2010 Camaro (M6) 1000+ HP SBE
Drek broke it down pretty good! Some initial cost for going with E85 to upgrade fuel system, but if it is available in your area it is sooo nice to pull up to a pump and pay ~ $2.50 per gallon for race fuel.
F-1X, Cog Drive, ATI Super Pulley/Sprag ~ 19 psi
Blower Cam
Brodix BP BR 3 Heads
Kooks LT Headers and full 3" exhaust
Fore Triple Pump Fuel System with ID 1700X Injectors - E85 conversion
DSS 9” Conversion (1400 hp axles, driveshaft, pumpkin) & Strange 3.70 gears
McLeod RXT Twin HD Clutch & Upgraded Slave
RPM Level VII
TR6060
BMR Drag Suspension Package w/Strange shocks
Carlyle 15" and M/T ET Street R radials
10.1 @ 143 mph 1/4 mile
BiggFoot is offline   Reply With Quote
Old 06-01-2018, 07:01 PM   #12
dreksnot
dreksnot's Avatar
Dang! I've been bitching about $2.09 a gallon as I was paying $1.69 last year. I guess that's not bad at all for "race gas" with 104-ish octane.
Old 06-01-2018, 08:03 PM   #13
Unavowed
Unavowed's Avatar
So you don't spend money twice, I suggest you go with the V pumps, a Vaporworx controller, a JMS booster and either ID 850 or 1050 injectors. A ZL1 pump and LSA injectors won't do much of anything on E85.
Old 06-01-2018, 11:07 PM   #14
tlamb2
WHPLSH
tlamb2's Avatar
Drives: 2010 SS Maggie,ARH,Meth,AFE Coilove
I have been spraying Meth since 2011 pre Maggie although its not my daily and only 25k miles on car since Meth install just had it retuned for bigger meth nozzle and made 30 hp more than original dyno in 2011, It does not seem to have done any harm, Make sure you get NPT stainless line and not push to connect crap that leaks
tlamb2 is offline   Reply With Quote
