Old 08-05-2014, 01:19 AM   #1
Peter-5
Peter-5's Avatar
Drives: 2010 Camaro V6 turbo
PCV barb drilling location???
Hey guys, quick question where is the PCV barb so I can drill it to correct the opening holes?
Pics would be great if possible thanks!
Peter-5 is offline   Reply With Quote
Old 08-05-2014, 05:53 AM   #2
mycamaro2011
mycamaro2011's Avatar
Drives: 2010 Camaro 2LT Victory Red
its in the rear on the passengers side valve cover. just follow the hose. you might have to wiggle it alittle bit but make sure you remvove the connector. Just fyi on my camaro when i drilled the openings bigger i was getting alot of oil sucked into my intake. i went back to non drilled stock barb and no more oil...
mycamaro2011 is offline   Reply With Quote
Old 08-05-2014, 01:49 PM   #3
Peter-5
Peter-5's Avatar
I might just order the newer one from the 13-14 models but I'm still trying to find it lol
Old 08-05-2014, 02:59 PM   #4
Nutbutt
Nutbutt's Avatar
Drives: 2011 RJT 2LT/RS Convertible
Before you drill, take the barb out and see if it is clogged. If not leave alone. I have now been removing and inspecting at every oil change. So far no clogging. The drilling is allowing too much flow. Bottom line keep it clean.
1st IPF Supercharged 2011 2LT/RS RJT Convertible
Nutbutt is offline   Reply With Quote
Old 08-05-2014, 04:16 PM   #5
Peter-5
Peter-5's Avatar
Do you have a pic of where it is?
Old 08-05-2014, 06:43 PM   #6
rtcat600man
having FUN now 13.66@101
rtcat600man's Avatar
Drives: 2010 2LT IOM
This thread will help you out. All good info on the first page. Drilling and location of PCV.
http://www.camaro5.com/forums/showthread.php?t=258202
Old 08-05-2014, 11:23 PM   #7
Peter-5
Peter-5's Avatar
Got it!!! Excatly what I was looking for thanks!
Old 08-13-2014, 06:18 PM   #8
Peter-5
Peter-5's Avatar
Is it me or is there a certain way of removing the PVC barb?
Old 08-13-2014, 08:12 PM   #9
911medic
911medic's Avatar
Drives: 2012 SIM 2LT/1970 Camaro
Pull and twist. Just be careful not to crush it if you use a pliers to grab it.
All bleeding stops eventually -- 2012 2LT Auto w/sunroof -- My journal thread
Roto-Fab Intake & W/W Relocate Kit -- ADM Race Scoop -- Dynomax VT Axle-Back Exhaust -- Vitesse Throttle Controller
RX Catch Can -- Drake Bowtie Delete -- JacFab Radio Face Cover -- LED Fog Lights -- LED Dome/Trunk/Plate Lights -- Gen5DIY Dash ABL -- Diode Dynamics Cupholder Lighting
Wishlist: ACS T5 Splitter -- Hood Vent Mod -- Footwell/Door Pull/Homelink Button Lighting
911medic is offline   Reply With Quote
Old 08-13-2014, 11:48 PM   #10
Peter-5
Peter-5's Avatar
Is it like a lefty lossy type of thing because I pulled pretty hard and I was scared I was going to crush it
Old 08-14-2014, 06:10 AM   #11
911medic
911medic's Avatar
No, it's not threaded. Just friction - fit into the opening.
Old 08-14-2014, 05:48 PM   #12
Eddiefuzz
Eddiefuzz's Avatar
Drives: 2011 RS
AMEN!! I did the drill MOD and got at least 4oz. every 1000 miles in the Catch Can. I bought another one from the dealer, drove a 1500 mile road trip vacation, got back..... NOT EVEN AN OUNCE!!! Don't Do It!!
Eddiefuzz is offline   Reply With Quote
Old 08-14-2014, 08:06 PM   #13
mycamaro2011
Exactly Eddiefuzz. It messed everything up on mine with the drilled barb. When i took my Vararam filter off to clean it i couldnt believe how much oil was in the base of the Vararam filter housing. I thought i blew something.
Old 08-14-2014, 08:18 PM   #14
rtcat600man
Maybe you guys drilled it open to large? I opened up mine, and see the same amount of oil before and after doing it being caught in my RX catch can.
