Old 11-12-2016, 12:38 PM   #1
d454brisson
Drives: 2014 ZL1
Passed emission with Jannetty's tune headers and no cats
I just finished effectively the 125 hp kit with kooks headers, catless mids and a few other slight changes. Right after finished I get my emissions email, hoping I wouldn't have to get catted mids, or a retune ( sometimes emissions places dont like the CAT state) I headed over.
Passed the OBDII test and good for another 2 years. Very happy
d454brisson is offline   Reply With Quote
Old 11-12-2016, 05:53 PM   #2
rvnmaniac
Drives: 2012 M6 ZL1. 2019 Altima.07 FJR1300
Since I'm in Md this is nice to now...
rvnmaniac is offline   Reply With Quote
Old 11-13-2016, 05:10 AM   #3
nighttowl
Sarcasm loading --------
nighttowl's Avatar
Drives: 2018 ZL1 1LE
Sounds like you have very loose emissions standards in your state.
"The salesman actually told me to stop getting it sideways during the test drive"
2018 MBM ZL1 1LE - 652 rwhp, 588 rwtq SAE
2014 CRT ZL1 574 rwhp, 537 rwtq - SOLD
2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq - SOLD
nighttowl is offline   Reply With Quote
Old 11-13-2016, 05:41 AM   #4
deeds
deeds's Avatar
Drives: 2013 zl1
I'm in NJ I know that my state after 07 and later cars they only do a OBDII test. Now that being said, I've been thinking a lot about this when its time for me to get my car inspected. The only part I could see myself failing on are. catless mids and having upstream or downstream o2's off. (I forget what ones are off in the tune) Ted also tuned my car so the o2's that he turned off are going to be the same as yours. Now that I'm thinking about it I'll hook up my scanner to run a drive cycle test. If that passes I'll pass inspection. Also I have high flow cats Ill put on before hand and take off after.
Ted if you could chime in on this on if you had a customer fail inspection for anything in one of the emissions cautious states.
675RWHP 622RWTQ Jannetty Tuned
10.76 @ 131.6 1.6 0-60"
deeds is offline   Reply With Quote
Old 11-13-2016, 08:05 AM   #5
camguynj
camguynj's Avatar
Drives: '13 SS/RS LS3 BRM Cammed NPP
I'm in NJ too. The OBD2 emmission inspection tests only the rear/downstream O2 sensor's readiness status. Those are the ones that get turned off in tunes/set to Ready so you don't throw a CEL. You should be good to go as is. Still be interested in hearing Ted's comment.
camguynj is offline   Reply With Quote
Old 11-13-2016, 08:56 AM   #6
d454brisson
Drives: 2014 ZL1
MD is pretty tight on sniffer but since these cars just need OBD2 its all about the tune and the sensor state. As said before different tunes leave things in diff states and the JTR tune is good enough to pass without resorting to going stock and testing before a cel trips or trying to trick the downstream with extenders or other things to adjust flow rate.
Old 11-13-2016, 10:15 AM   #7
ZO6 Bryan
ZO6 Bryan's Avatar
Drives: 02 Z06, 95 Trans Am, 2012 ZL1
Passing the OBD2 test in Tennessee is no problem with a proper tune. But you would fail the visual test. Because they do look under the car for cats.
Bryan 2018 ZL1 M6
ZO6 Bryan is offline   Reply With Quote
Old 11-13-2016, 07:46 PM   #8
d454brisson
Drives: 2014 ZL1
They looked under mine and I guess seeing the second 02 sensors in tact they passed on by the pipes. It was a saturday and govt employees, just get cars through and collect the fees.
