04-19-2012, 12:26 PM | #1 |
Logic is dead
Kooks / Steering Column issue?
Hey yo,
Has anyone had an issues with their Kooks long tube stepped headers slightly rubbing against the steering column? I felt some slight grinding in the car after the engine came to temp during certain right turns after driving the car around. I couldn't figure out what the issue was. Well, during my supercharger install, my dumbass finally noticed that there was some slightly rubbing of the steering column against the Kooks headers. Anybody with Kooks long tubes have this issue? I dunno what to do on this one. I dont need a lot of space, but would like to ensure it clears.
2010 Camaro 2SS/RS (LS3)
573 RWHP 498 RWTQ - Vortech V3 Supercharger - Kooks Stepped Headers, Magnaflow 16580 - Suspension by Pfadt, Hotchkis. 2007 Trailblazer SS- Sold 2001 Trans Am WS6 431 RWHP 408 RWTQ - Sold 1994 Camaro Z28 - Sold |
04-19-2012, 12:47 PM | #2 |
04-19-2012, 01:04 PM | #3 |
Drives: 2009 ZR1 Join Date: May 2010
I don't have Kooks headers but I do have 2" primaries and had rubbing issues. I used option 2 because I wasn't aware of option 1 at the time. I also had a small amount of rubbing on the passenger side as well. Option 2 fixed it also.
Option 1 (may or may not work but doesn't hurt to try it first): Based on this thread: http://camaro5.com/forums/showthread.php?t=214701 You can loosen the engine mounts and transmission mounts and see if you can push the engine ever so slightly towards the passenger side to see if you can create the clearance. If you can, double check the passenger side afterwards. If you have clearance on both sides, you obviously are good to go!! Option 2 (will work): Remove the header and dimple it where it is rubbing. Either that, or contact the vendor/Kooks to see if they will do anything for you. Dimpling it will NOT hurt performance and you won't be able to see it anyway. To dimple it, mark the header where it rubs (often it will be scuffed, if not use a sharpie while still installed and make a mark) Use a large socket on its side and lay it on the marked spot, hit it with a hammer until you are satisfied you have created clearance. You don't need to heat the headers. Do it cold. Good Luck!!! |
04-19-2012, 01:11 PM | #4 |
Drives: 2012 ZL1 & 2010 2SS/RS Join Date: Jul 2009
For any issue with Kooks, I would recommend calling their warranty department at 1-866-586-Kook. I have seen this complaint with pretty much every brand, and I am wondering if there is some kind of variance in engine mounting from the factory. For instance, on the GTO, the engine placement in the car could vary by an inch in any direction. It is frustrating because the headers are made in a fixture, so they are basically always the same..however if the car is different, that creates issues.
04-19-2012, 01:15 PM | #5 |
Logic is dead
Thanks guys, Engine mount was my first thought, and your insight is helpful in adjusting this.
04-19-2012, 03:01 PM | #6 |
Drives: Exige, Miata, Ghia Join Date: Jun 2011
There was a brand on here that got so much flack for needing to "dimple" their exhaust in order for them to fit. For the price that you paid for the kooks, they better fit right out of the god damn box.
04-19-2012, 03:30 PM | #7 | |
Drives: 2019 GMC Sierra 1500 AT4 Join Date: Nov 2011
Jeez, this brings me back to middle school when you couldn't be cool without a pair of Tommy Hilfiger's; only it's the JCPenny kids that are loud and obnoxious now.
Summit White 6" Lift, 37x13.50R24's |
04-19-2012, 03:32 PM | #8 |
Drives: 10 2SS/RS Black, 99 Daktota Join Date: Apr 2010
I do have the Kooks stepped headers installed for more than a year now and have absolutely zero rubbing issues... 2010 LS3 if it helps..
Kooks Signature Series Headers 1-3/4 stepped to 1 7/8, Kooks 3" High Flow Cats, Vararam OTR Cold Air Intake, JRE Performance Tune, RX Catch Can, RX Oil Breather, LSR Tri-Ax short throw shifter, AAC Red/White Halos and Fog Rings, AAC Knight Rider Scanner Bar
04-19-2012, 03:43 PM | #9 |
Drives: 2011 2SS L99, 2010 LT RS Join Date: Mar 2010
I had a similar problem. In my case only the rubber boot touched the headers. I decided to cut it off and haven't had any problem since then:
http://www.camaro5.com/forums/showthread.php?t=173342 |
04-19-2012, 03:52 PM | #10 |
Drives: 2011 2SS/RS M6 VR Join Date: Aug 2011
I've got the same Kooks stepped you do and I had read about the issue with the steering boot before the install. But I've got about 3/8" clearance on my 2011. So I would go with the engine mount option to correct it.
04-20-2012, 01:46 AM | #11 |
Drives: 2015 ZL1 Join Date: Aug 2011
Uh oh.
"Want to know whats cooler than your murdered out Honda Civic? ...Any Audi." Daniel Tosh
04-20-2012, 01:58 AM | #12 | |
Because some people were saying that perfect fitment comes with the high price tag blah blah blah and yet we see the same crap as the cheaper headers. |
04-20-2012, 09:49 AM | #13 |
Drives: '15 Z06, '01 NBM SS, '97 SS Join Date: May 2009
It's all in how the motor sits in the cradle/motor mounts and where the steering box sits in reference to the input shaft.
Starting to see more and more headers touch the steering shaft. And it's not just 3 or 4 brands of em, it's damn near all of em. .....took a while, but I've noticed differences of up to 5/8's of an inch in some cases. Not too hard to fix if you move things a bit. You don't need to bang the crap out of your headers to "make em fit." Ivan @ Southwest Speed |
06-19-2012, 10:26 PM | #14 |
Logic is dead
Update:
So we messed around with the engine mounts, moved something's around and shimmed the mount a bit. Since I have the supercharger on, I don't have a lot of play in either direction. Tried driving around and there is still a decent amount of rubbing. I am getting very frusturated. Not sure what other options I have at this point. Suggestions?
