Old 06-07-2015, 06:31 PM   #1
Gaddism1
Gaddism1's Avatar
Drives: 2010 SS Inferno Orange MT
Supercharge with 3.91 Gears?
I have heard some folks leave stock gears in their 2010/2011 SS manual once they super charge the car. I cant afforcd the SC now but I do want to swap to the 3.91 gears. Will the 3.91 gears be a problem once I do add the SC? Will the car have too much pull in gear 1 and 2??
Thanks In Advance!
[B][SIZE="3"]Dynatech LT's Ceramic coated / Dynatech Hi Flow Cats / SOLO Mach X CAT Back Exhaust/ CAI / JRE Scoop / Pfadt Springs / Pfadt Sways and Links/ American Racing Mags / Rough Idle Cam upgrade package with dyno tune from Slowhawk Performance.[SIGPIC]
Gaddism1 is offline   Reply With Quote
Old 06-07-2015, 06:40 PM   #2
10aSSee D
10aSSee D's Avatar
Drives: Silver 2010 SS Camaro
I have 3.90 gears in mine and I do spin the tires pretty good but it is a blast to drive and still nice when just rolling around town.
MODS:
Old 06-07-2015, 07:25 PM   #3
SuperchargedStealth
Drives: '11 Camaro Supercharged Convertible
Thanks In Advance!
Part of it depends on what type of S/C you get. With a PD blower, you'll spin for a while before gripping. With a centri, you'll launch like stock unless you are at a higher RPM level. It's one of those things that you'll learn to adapt to. Personally I think that 3.70 or 3.73 is optimal. Good launch with a blower, and lower RPM while cruising.
2011 Triple Black SS convertible, LSX 427, PRC 260cc heads, Callies Ultra Billet Rods, Wiseco -20 cc piston, Callies Dragon Slayer crank, Strange Dana 60 rear w/3.73 gear ratio and driveshaft, Pfadt coilovers, Pfadt sway bars, Pfadt trailing arms, Pfadt tie rods, Pfadt subframe bushings, Vortech YSi with wastegate and twin BOV, Haltech ECU, Mantic 9000 Twin Clutch, ALKY control meth system with dual nozzle, Squash twin fuel pumps, ACS T3 ports, VIS Terminator Hood, Seibon ZL style lip.
SuperchargedStealth is offline   Reply With Quote
Old 06-07-2015, 08:32 PM   #4
silverz28
Drives: 1996 Camaro Z28, 2012 2SS/RS
I have them. It's a blast.
2012 2SS/RS IOM, LS3, Aftermarket Hurst shifter, IOM interior, Borla "S", 1 7/8 Big Flow headers, ADM Race cold air, BMR 1" lowering springs, SLP Supercharger, Custom Comp Cam, Fore Innovations twin pumps, Flex Fuel Sensor
silverz28 is offline   Reply With Quote
Old 06-07-2015, 10:07 PM   #5
Nighthawk89
Nighthawk89's Avatar
Drives: 2011 Camaro 2Ss M6
Im running stock gears. work perfect.
Nighthawk89 is offline   Reply With Quote
Old 06-07-2015, 10:39 PM   #6
43Camaro
43Camaro's Avatar
Drives: [COTW 8/3/15] 2010 Camaro SS L99
3.91 and never look back. Throw your frickin head straight back in the seat...
A Little bit of power. ALL WORK DONE BY ME!
Just added 2021 ZL1 1LE to the Stable!
https://www.camaro5.com/forums/showthread.php?t=418273
43Camaro is offline   Reply With Quote
Old 06-07-2015, 10:50 PM   #7
SuperchargedStealth
Once you hook up though....
Old 06-07-2015, 10:52 PM   #8
43Camaro
43Camaro's Avatar
A good tire is always a plus with this combo, along with some suspension mods. Combo does require a little finesse at times, but I still wouldn't change back or drop down..
Old 06-07-2015, 10:58 PM   #9
SuperchargedStealth
I understand that part too. Having an M6, I can start slowly in 1st, shift to second, and once boost builds up enough, it has that same effect. Granted, we have two different systems, but when I have that 24 lbs. kick in fully, my front end just starts lifting. It's scary, yet exhilarating at the same time. A good tire does play a big role however.
Old 06-08-2015, 06:53 AM   #10
blake2010ss
blake2010ss's Avatar
Drives: 2010 Camaro 2ss/rs
Send a message via AIM to blake2010ss Send a message via MSN to blake2010ss
i got 3.91 with my ecs centri blower. they work great, but i got all the suspension/rear end stuff to keep the traction in tact. I also run a mickey e/t street.
2010 Camaro 2SS/RS LS3
1093/1066
416, AGP 6262, E85, Cam
blake2010ss is offline   Reply With Quote
Old 06-08-2015, 10:13 AM   #11
ilir14
ilir14's Avatar
Drives: Camaro ss 1le
i did Lsa conversion and 1st and 2nd it just spins, but once you hook your gone, and as mention above get some suspension and tires and no problem
ilir14 is offline   Reply With Quote
Old 06-08-2015, 10:22 AM   #12
43Camaro
43Camaro's Avatar
I look at the 3.91 as a force multiplyer. I'm running modest boost, the gears make the car feel like I'm at 700 RWHP with that awesome torq. CMP also tuned the tranny up to work well, nice even smooth shifts.
Old 06-08-2015, 11:53 AM   #13
fourmz
Fourmz
fourmz's Avatar
Drives: 2010 2SS/RS 1968 Firebird 1994 Z28
My setup it a total neck breaker, I love it!!
Black-in-Black/Blue out 2010 2SS/RS LS-3 -Magnacharger TVS2300,OD cog belt drive, 3.4" pulley, Janetty smooth idle blower cam,ID-850 injectors,ZL1 fuel pump,MSD boost a pump, ADM FPCM Janetty custom tune,Doug Thorley long tube headers, Corsa catback,C.A.I. Intake, Roto-Fab Big Gulp Scoop, Monster LT1/SC Clutch assembly,Eibach pro kit plus, BMR cradle/diff bushings, Barton Shifter,JRE 3.91 Eaton Tru-Trac rear diff,Barton Short Throw SHifter, Boss 339 20" wheels,Painted heritage grille, Sparks Restoration Inverted blue/black SS emblems, Seibon BB carbon fiber hood, ZL1 front bumper conversion.
fourmz is offline   Reply With Quote
Old 06-08-2015, 04:53 PM   #14
Reelgrinder
Drives: 2016 SS
Its the cam choice, not the blower choice, Jesus! Bigger gears will make car feel lighter and from dead stop starts talk about easy! It really makes the heavy 5th gen so much easier to drive modded or not..
I'm glad I didn't listen all the peeps say don't do it!
And its only 700 upgrade if change it your self.
2016 SS with Eforce 2300
Borla Headers
Borla Atak
Reelgrinder is offline   Reply With Quote
