Old 07-16-2014, 10:33 PM   #1
Demon War Horse
War Horse Pilot
Demon War Horse's Avatar
Drives: 2017 NFG 1SS 1LE
Homemade CAI?
Looking at turbo tubes and pipe to make my own intake tube without the silencers on it.
Anyone tried it? Looking for low cost options to start. If I can make one versus spending hundreds, I will stay out of the dog house.
Thoughts?
COTW 09/07/2015 - 2014 AGM 2SS/RS - RIP 6/01/17
2017 Nightfall Gray Metallic 1SS 1LE Born 5/17/17 - Click Sig Pic below for for Demon War Horse 02 Build Thread
SigPic by Hazman
Demon War Horse is offline   Reply With Quote
Old 07-16-2014, 10:42 PM   #2
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
If you just want something to dress up the engine bay, there are cheap options that eliminate the OEM tube with silencers on it. If you're thinking it's going to give you any performance gains, you'd be wrong. While the inlet tube itself does have places to improve upon, the bigger restriction is in the OEM box.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 07-17-2014, 09:35 AM   #3
Demon War Horse
War Horse Pilot
really looking to get rid of the silencers for now. I have my eyes on a CAI box down the road in a few months. But I have to spread the mods out to stay out of the doghouse with the wife unit.
SigPic by Hazman
Old 07-17-2014, 09:39 AM   #4
thahemp
Geek
thahemp's Avatar
Drives: 2012 Black LS3
I think Airaid sells individual pieces you can use to make a custom intake.
01000111011011110110111101100100001000000110110001 11010101100011011010110010000001110111011010010111 01000110100000100000011101000110100001101001011100 110010000001101111011011100110010100100001
x = ac97968bd3df8f968c8cd3df998a9c94d3df9c8a918bd3df9c 909c94df8c8a9c949a8dd3df92908b979a8ddf998a9c949a8d d3df8b968b8cd1
x = ~x
thahemp is offline   Reply With Quote
Old 07-17-2014, 09:41 AM   #5
thahemp
Geek
thahemp's Avatar
https://www.airaid.com/U-Build-It_intake_systems.aspx
x = ~x
Old 07-17-2014, 02:08 PM   #6
Demon War Horse
War Horse Pilot
Thanks!
SigPic by Hazman
Old 07-18-2014, 11:13 PM   #7
TECADON
TECADON's Avatar
Drives: 2011 Camaro 1SS/RS
I made my own link in my signature. I talk about the Airaid pipe a little too but I now have my tube wrapped with reflective gold tape, looks pretty nice and keeps upper pipe cool thats all i need lol.
2011 SS/RS Homemade CAI, Doug Thorley Muffler Delete, Burns Stainless X-pipe and Dynomax Race Bullets, 8k HIDS and Fogs with harness, Tuned by Me on HPTuners
Yes its quick...quicker then you think!!!
TECADON is offline   Reply With Quote
Old 07-18-2014, 11:33 PM   #8
Demon War Horse
War Horse Pilot
I don't plan on tuning as an option right now... Why did it require one for the MAF? Placement change?
Great write up! Thanks for sharing.
SigPic by Hazman
Old 07-19-2014, 01:43 AM   #9
TECADON
TECADON's Avatar
Actually yes few reasons. To get the most out of any modification of air/fuel in or out a tune is recommended, for intakes in most cases they are not needed. In my case, the larger diameter pipe (4 inch) where the MAF is located is larger than the factory and most aftermarket tubes, so the tables in MAF have to be corrected. Technically you could go with a pipe matching the factory tube and have a better outcome and less need and more of a want to tune. Also the placement move that I did moving the MAF closer to cold air and also filter changes some dynamics like temperature and flow and turbulence through the sensor. Just remember this too, I did a a V-Max throttle body and I needed some tweaks too.
I found I had much cooler temps and and leaner A/F ratio which tells me more air is going in for sure, so the car would not ever stay running after start without assist so tunning was mandatory, but now better than its ever been.
In your case maybe look at an after tube to just replace the factory factory upper and get a nice drop in filter (EDIT Just saw you have drop in already) You could make one kinda like I did but would be too much to do for just that if it can be purchased.
Id look at New Era 2010+ Camaro SS Intake Pipe Kit and maybe wrap the pipe its like $100 and a nice filter is like $40-$70
Old 07-19-2014, 08:18 AM   #10
Demon War Horse
War Horse Pilot
Checked out the New Era pipe... Definately what I am looking for. Also found a G5CR one that was nice looking.
A tune is a bit out for me. Thanks for the detailed replies. I appreciate it. I have been out of the hot rod game a while. Had a 99 Formula years ago that put down 385RW in 2000 with headers, homemade ram air, cam, ported MAF and ported TB. No headwork or real tune. She ran rich vs lean which was nice and safe.
SigPic by Hazman
Old 07-19-2014, 07:59 PM   #11
axis
Search Ninja
axis's Avatar
Just know that while it does clean up the engine bay a little, it will add next to nothing in performance. I'd save my $$ for a proper CAI.
Halltech CF 102 fed
Old 07-20-2014, 03:54 PM   #12
TECADON
TECADON's Avatar
Agreed. nice set headers and tune, and leave it there. The drop in you have made more difference I bet then the tube will, well besides small amount of sound maybe.
I can say one thing I already had HPTuners for many many years and when the car was stock I put wideband in and did street and dyno tuning and the car drove way different and more consistent.
