12-29-2017, 03:46 PM | #1 |
Drives: 2010 Rally Yellow LS Join Date: Apr 2010
Aftermarket Backup Camera wiring
Good afternoon all,
So I recently received a pioneer mvh-2300 and a new back up camera for the holidays. Got the radio hooked up and running no problem. Now I've run into a road block in trying to wire the camera. I know I need to wire into the reverse lamp wiring and a ground in the rear (front wiring into the head unit isn't an issue) but the reverse lamp wiring is... a bit difficult to get to. Reading from other posts, the easiest thing to do is tap into the rear lamp wiring. There was another thread on here that was great but the photos were no longer available so I took a photo of the driver side rear light connection and am wanting to know which of these wires is the +12v to the reverse lamps. The post mentioned a "teal" wire. Is that the +12v wire to the reverse lamp that the arrow is pointing. The passenger side doesn't have that color wire. I'm pretty sure it is but just needing a second set of eyes to confirm. The black ground wire is easy so no worries there. Thanks for all the help. |
01-01-2018, 05:51 PM | #2 |
Aural Assault Vehicle
Drives: 2010 IBM 2SS/RS, 2015 Sierra Denali Join Date: Jun 2011
That is the correct teal wire, just above the lavender/purple one.
My amplifier pop/click/thump solution thread
Power Mods * K&N Typhoon CAI, Flowmaster American Thunder cat-back exhaust, Hurst Short Throw Shifter Exterior Mods * Black Phantom Grille * 22" T.I.S. 537MS wheels w/ Nitto INVO rubber * OEM body kit Suspension Mods * BC Racing Coilovers * Lakewood Strut Tower Brace Audio Mods * Stinger SPP 2250 Battery * Mosconi 6to8v8 w/ RCD * Pioneer AVH-X7500BT * Scosche Dash Kit * 2 - Mosconi AS200.4 * 2 - JL Audio 13W6v2 * Focal 165KRX2 Power (active) * Mosconi Gladen One 240.2 * Rockford Fosgate Power T1692 |
