Old 03-05-2012, 06:29 PM   #1
toilets
Drives: 2010 camaro
Do you know what ptm mode
I swore I read somewhere that when exiting a turn you can essentially keep your foot planted to the floor and the car will modulate the throttle for the maximum amount of grip and speed.
A. Is this true
B. do you know what mode this is?
Ie, hit you braking point, turn in, hit the apex and let the car do the rest
toilets is offline   Reply With Quote
Old 03-05-2012, 10:04 PM   #2
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
A. Is this true
A. Yes....to a point...
B. PTM 2 is your best bet, here.
PTM is an astounding system in that it can progressively scale back the level of "help" it's providing the driver. From modes 1 - 5, the system allows more power to be used and makes less handling adjustments...
So if you're looking for video-game style performance, PTM 2 should be real close - but keep in mind it will still skip the wheels a little bit if you lay the hammer down TOO hard. But even then, it will always reign in the drama before any trouble happens.
Old 03-06-2012, 08:17 AM   #3
toilets
Drives: 2010 camaro
Thanks Dragoneye. Do you know about mode 5? Is their still intervention? I'd like to have the race setting but I also want some help if I get in over my head
Old 03-06-2012, 09:26 AM   #4
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
I'm still a little confused as well... (thanks toilets )
Is Mode 5 the "OFF" mode, or is there another mode, in addition to 5, that completely turns everything off? That's what I keep thinking I'm reading, but it's still not entirely clear to me.
'20 ZL1 Black "Fury"
Old 03-06-2012, 10:09 AM   #5
GoldenBear
Bear Backer
GoldenBear's Avatar
Drives: 69 Camaro Z/28, 69 Corvette Conv
It is my understanding PTM Mode 5 is not "OFF," as Traction Control is still active in PIM Mode 5, although StabiliTrak is off. The TCS/StabiliTrak system is completely "OFF" when the TCS/StabiliTrak button is pressed and released once after vehicle startup. Pressing and releasing the TCS/StabiliTrak button again turns the system back on.
If the TCS/StabiliTrak button is pressed quickly two times, the system enters PTM mode. The modes (1 - 5) while in PTM are selected by pushing the - TOUR and + SPORT buttons to scroll up or down through the modes. When the TCS/StabiliTrak button is pressed again, the vehicle exits the PTM mode and the TCS and StabiliTrask systems are on.
Current Chevrolets: 1969 Camaro Z/28 -- 1969 427/390 Corvette Convertible -- 1970 350/300 Corvette Convertible -- 2013 Camaro ZL1 Convertible -- CRT / Exposed CF Weave Hood Insert / Suede Package / Polished Wheels / MN6
GoldenBear is offline   Reply With Quote
Old 03-06-2012, 10:11 AM   #6
KKreme15
KKreme15's Avatar
Drives: C6 Z06
Wait, so you aren't by default in 1-5? You can be outside of that scope?
KKreme15 is offline   Reply With Quote
Old 03-06-2012, 10:13 AM   #7
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
That makes more sense.
I keep forgetting I can refer to the Owner's Manual, LOL
Old 03-06-2012, 10:16 AM   #8
ShnOmac
ShnOmac's Avatar
I have faith but Im not sure I have this much faith......
"To experience the performance
benefit of this system, after entering
a curve and at the point where the
driver would normally start to
increase acceleration, the
accelerator pedal can be fully
pressed. The PTM system will
modify the level of engine power for
a smooth and consistent corner exit
9-46 in the owners manual....
ShnOmac is offline   Reply With Quote
Old 03-06-2012, 10:18 AM   #9
GoldenBear
Bear Backer
GoldenBear's Avatar
TCS and StabiliTrack are on, and PTM is off, by default whenever the vehicle is started. To enter PTM Mode the TCS/StabiliTrack button must be pressed quickly two times. Then, PTM Modes 1 to 5 are available.
Old 03-06-2012, 12:42 PM   #10
toilets
Drives: 2010 camaro
Hmmm, this would imply (to me) that aid is not there. Traction control would need to be on in mode 5 as launch control is still enabled in this mode. However it looks as if you start to lose it around a corner then no help is on its way
Old 03-06-2012, 12:44 PM   #11
toilets
Drives: 2010 camaro
OOHHHH snap! Now that is cool and is confirmed!Now to find out what ptm mode this works in...
Old 03-06-2012, 02:16 PM   #12
Janet
Drives: 2015 Z06, 06 Silverado,
It might be kinda hard to teach this old dog some new tricks. Hmmmm
Janet
Janet is offline   Reply With Quote
Old 03-06-2012, 03:52 PM   #13
IcePick06
IcePick06's Avatar
Drives: '12 AGM ZL1 (SOLD); '07 Ducati 1098
a smooth and consistent corner exit"
This is similar to the new traction control systems on sportbikes. It's counterintuitive from years of riding to just hammer the throttle coming out of a turn, but the new traction control systems are THAT good on current sportbikes that it takes some getting used to before you will actually become faster from the technology. I'm sure the ZL1 will take me a couple weeks or so to even get used to the "NO LIFT SHIFT" feature as well as the PTM modes
IcePick06 is offline   Reply With Quote
Diagnostic Trouble Codes (DTCs) for OBD II equipped GM vehicles steeleshark2 Tuning / Diagnostics -- engine and transmission 11 04-08-2020 10:49 PM
Sport Mode vs. Drive Mode vs. Manual Mode Velociraptor Dragstrip and Launch Techniques Discussion 82 10-02-2019 08:23 AM
Push Start button? CG'sSS Camaro DIY & HOW-TO instructions & discussions 158 06-06-2012 07:27 PM
Video: Camaro ZL1 Tears Up Inde Motorsports Track! Aziz Camaro ZL1 Forum - ZL1 Specific Topics 138 02-12-2012 09:02 AM
PTM MODE 3 & 4? 1BADZL1 Camaro ZL1 Forum - ZL1 Specific Topics 8 11-20-2011 05:52 PM
