04-28-2012, 02:32 PM | #1 |
Drives: Black 1SS/RS LS3 M6 "The Toy" Join Date: Dec 2011
What 18" wheels will fit the SS
Looking for some 18" wheels to run drag radials on. Anyone have any suggestions on 18" wheels that will fit the SS/RS
2010 1SS/RS Diablo Sport Trinity JRE Tune OBX headers with Cat delete Borla Cat back Volant PowerCore CAI BMR adjustable trialing arms 4.11 Gears JRE cam package.
04-28-2012, 04:50 PM | #2 |
Forgestar F14 & CF5, TSW Interlagos & Nurburgring, Weld RT-S, or Corvette 18x9.5 (+40 offset). I'm sure there are others, but these are probably the most commonly used.
04-30-2012, 04:27 PM | #3 |
Thanks for the info
05-01-2012, 06:42 AM | #4 |
Drives: 2011 Black RS SS Join Date: Aug 2010
Does anyone know which of those wheels listed above are the lightest?
Thanks, Chris.... |
05-01-2012, 08:42 AM | #5 |
Without verifying the actual numbers, I would probably guess the Weld RT-S wheels are the lightest. They are the only "true" forged wheel out of the listed wheels, but you will also pay the most for them (I think around $600 per wheel for 18"). The Forgestars are "rotary-forged" which means the inner spokes are cast aluminum, and the outer wheel rim is forged, it's kind of a "half-breed", but stronger and lighter than a full cast wheel, and relatively inexpensive (right around $1350 per set of (4) for 18"). I'm not sure on the TSW's, I think they may be rotary-forged as well (probably about $1100 per set of (4) for 18"). And the Corvette wheels whether OEM or replica are cast and probably the heaviest of the bunch, but on the flipside, probably the cheapest.
05-01-2012, 05:36 PM | #6 | |
Drives: 2010 Camaro 2SS/RS Join Date: Mar 2008
The TSW Nurburgrings are "Flow Formed" and weigh around 19 lbs in 18" sizes. |
05-01-2012, 10:09 PM | #7 | |
And you're right, TSW calls their wheels "Flow Formed", and Forgestar calls their wheels "Rotary Forged". After reading Nine Ball's post (linked below), I see these are actually two names for the same process. And I guess I was incorrect to say that the outer wheel rim or hoop is forged....it is not forged, but "flow formed" like you said. Nonetheless, this is a great post from Nine Ball, and very educational (at least for me) http://www.camaro5.com/forums/showthread.php?t=121777 |
05-02-2012, 12:00 AM | #8 |
Quit being a pu$$y
Weld 17x10 is 19.3 lbs
Forgestar F14 18x10 is 21 lbs C6 Z06 18x9.5 21.5 lbs Grand Sport 18x9.5 23 lbs
05-03-2012, 11:37 PM | #9 |
I can't thank you guys enough for the informative responses. This is a big decision and I'm new to the drag wheel stuff. I appreciate all the info.
Chris... |
05-04-2012, 09:05 AM | #10 |
No problem....we were all new to this stuff at one point. Let me know if you have any other questions. Here's a pic of my 17" Welds....
05-04-2012, 11:38 AM | #11 |
Drives: 2011 1lt/rs, 2010 2ss/rs, 2004 GTO Join Date: May 2011
We have a lightweight 18" option you might want to take a look at.
http://www.camaro5.com/forums/showth...tweight+wheels |
05-04-2012, 11:45 AM | #12 |
Drives: Widebody 2013 Mustang GT Join Date: Feb 2012
Location: 1721 E. Lambert Rd. Unit C, La Habra, Ca 90631
It's already been mentioned, but the TSW Nurburgrings work as well as 18" Forgestars which you can find more information about both here
Click below for TSW's: http://www.camaro5.com/forums/showthread.php?t=214680 And here for Forgestars http://www.camaro5.com/forums/showthread.php?t=201357 I hope that helps! |
