07-18-2013, 11:04 AM | #1 |
Drives: 2010 Camaro, 2006 Z06 Join Date: Feb 2009
Autocross and Suspension: First Place Finish
Just wanted to make a quick post and congratulate JDP for their 1st place victory at Sturgis! I've had a lot of PM's asking about his setup, so I thought I would take a few minutes to discuss it.
He currently runs the ZL-Spec Stage 5 package from us. In autocross, its all about grip. That seems simple enough, but what that translates in suspension terms is managing/tuning weight transfer and optimizing the contact patch of the tire with the road. Here is a quick breakdown of what that means to us: Tires Alignment Weight transfer So I don't want to post a bunch of boring stuff, but I think a few things are worth pointing out when talking about tires/alignment/weight transfer. 1. Once you pick your tires, you need to make sure you have the best alignment settings for your course/driving style/car. The thing to remember is that as the rubber bushings on the suspension components get pushed hard, they deflect a tremendous amount. This deflection while somewhat predictable, can lead to inconsistencies on the track. To select an alignment, and have consistent and predictable alignment and thus handling, Jordan is running sphericals on his critical suspension mounting points. This ensures that his alignment is ideal throughout the course, and that his grip isn't being compromised by poor alignment from shifting bushings. Remember, we have to maximize the contact patch of the tire with the road! 2. Next, once your alignment/tire setup is on point, we have to "tame the beast" .These 5th gens are bigger/heavier cars and because of that they have a lot of body roll. The biggest issue with body roll is that it changes the weight distribution on the tires. This is where BOTH coilovers and Swaybars will help you excel. The sway bars aren't there just to reduce body roll (which they do quite well), they are there to properly balance the ratio of roll between the front and the rear. By balancing the body roll, you have a huge effect on the grip between the front and rear tires during turns. This directly translates into correcting an oversteer/understeer situation. Coilovers also have an influence on tire grip between the front to rear. By adjusting the valving, you can control the weight transfer front to rear during braking into a turn, and acceleration out of one, which will optimize the initiation of a turn, and the exit from an apex. The name of the game is grip, and with sways & coilovers you can optimize grip for the various stages of taking a corner at the track/course. There were a lot of really powerful cars out there competing that week, many with much more HP than JDP, but they still couldn't get faster times. Even with the added HP, good tires, and various random suspension upgrades, they couldn't keep up. If the power doesn't make it to the ground, it doesn't mean a thing. By selecting the proper suspension components, and selecting components which are all designed to work with the Camaro to optimize grip, he was able to get the most out of his car and dominate the competition! Its important to point out "work with the Camaro". We don't and won't use generic Chinese valving in a Camaro body, and call it a camaro coilover. Those rates aren't optimal, and won't get the same results. Well, I hope that answers all of the questions I've been getting. Let me know if I can help with anything else, and have some fun! Last edited by PfadtRacing; 07-18-2013 at 12:09 PM. |
07-18-2013, 01:58 PM | #2 |
Love me some Tacos
humm wondering if this is in my future. I have new tires, sway bars, lowering springs... need helmet, then I could see how far I can push my set up. I currently have some R1 slotted rotors with hawk ceramic, but found out ceramic is not the way to go. Wondering if I can just use ceramic for now.. since I have already purchased the pads....
07-18-2013, 03:56 PM | #3 | |
So Cal Race Team
Drives: 2013 Camaro Join Date: Mar 2010
07-18-2013, 04:30 PM | #4 |
MikeNoMaro
Drives: A 2016 Challenger R/T M6 STP Join Date: Sep 2009
It's a beautifull Track Car. I love it.
Track Day Videos: http://www.youtube.com/user/mrgoodman2000/videos Built #83817, Born January 18th, Christened June 11th 2010, Stolen October 3rd 2016. |
07-18-2013, 05:08 PM | #5 |
USAF retired! Thank God!
Drives: 2011 1SS, 1LT red,1LT/RS SGM 98Z28 Join Date: Jul 2011
Congrats! Are you guys still running the CTS-V conversion? If so, what pads? Rotors? Inquiring minds want to know
HKE LSX427(Mast blk lbl 305 6bolt LS7heads, PatG231/246 blower cam, RWHP/TQ: 1281/1133 SNL Performance Custom Twin PT6766 BB turbos 4 to 25psi selectable on the Boost Leash controller, Squash dual 400LPH/ID2000s, ALKY 4 gal meth, Autometer AFR/Bst/oilpres/oiltemp/fuelpress gauges, Pedders Justice road crs pkg: All HD bushes, supercar 12kg coil overs, supercar ZL1 sways, camber plates all setup by JusticePete! :Gforce 9" 35spline S-Trac, 1500hp Outlaw axles, 3.5"alum DS, Monster Triple disc; 4xForgeline 19x10.5 4xBridgestone 305/30R19 RE-11, CTS-v calipers/rotors/Cobalt friction XR1/3 pads
07-19-2013, 05:29 AM | #6 |
Drives: Camaro Justice Join Date: Jun 2007
Well done Jordan!
07-19-2013, 10:30 AM | #7 | |||
Drives: 2011 Camaro SS/ 2016 Camaro SS Join Date: Jun 2009
This has been a good month for us with our Camaro Performers feature and the win in Sturgis! We're running the Pfadt Stage V ZL Spec Package with the exception of the trailing arms and toe links which are Spohn Del-Sphere pieces. The stopping power comes from our CTS-V Stage 2 Package with ZL1 Rotors, Hawk DTC-30 F and Hawk HP Plus rear pads. We're currently making 480 RWHP and 442 RWTQ with our N/A Cam Package, Roto-Fab intake, VMAX TB w/velocity ring, FAST 102mm, KOOKS 1-7/8" LT's w/cats, Magnaflow 3" cat-back and a JDP dyno tune. We have Pfadt engine mounts along with a DSS drive shaft and DSS RR Axles. Next up will be our Stage II head package and we're looking to break 500 RWHP on the stock bottom end using 91 octane fuel. The important thing to remember is I drive this car everyday set up exactly as it is when I run at the track a side from a few small damping changes... It is a full weight car and when the coilovers are set on the softer side it is a pleasure to drive. The responsiveness and overall balance of the car is perfect. Thanks again for making such great chassis components. Quote:
It's a street car that we take to the track but it does look pretty sporty! I appreciate it. Quote:
I appreciate it, Pete! Kind regards, Jordan Priestley 888.308.6007 |
07-19-2013, 10:42 AM | #8 |
Unleash the Beast!
Great runs Jordan, well after the 4th!
I'm commin to getcha now!
Summit White 2SS delivered 12-11-2015
07-19-2013, 10:57 AM | #9 |
07-19-2013, 11:01 AM | #10 |
That is one sick car!!! Love watching it go around the track at Miller Motorsports Park!!! Nice job Jordan!!
AirAid CAI; VMAX TB; Kooks 1 7/8" LT's w/cats; JDP Tune; 418 RWHP 408 RWTQ
07-19-2013, 11:03 AM | #11 |
Drives: pleather and Chiclets Join Date: Mar 2012
Way to muscle that heavy chevy around! SIM is such a beautiful color on these cars. Title really should be "Driver gets workout muscling 2 tons of car and wins first!"
07-19-2013, 12:38 PM | #12 | |
Unleash the Beast!
Doing a halo install this weekend for ya too! See you guys in a few weeks!
07-19-2013, 01:28 PM | #13 | |||
SIM is hands down my favorite color. Quote:
Awesome!! Sounds excellent! I'm not sure what our plan is so far as the Fest goes yet but we'll be there one way or another. See you down there! Kind regards, Jordan Priestley 888.308.6007 |
07-19-2013, 09:52 PM | #14 |
Love me some Tacos
I guess its time to contact the place and see if I can do a trade. Thank you for taking the time to answer my question.
