03-05-2014, 06:11 PM | #1 |
Best way to launch a 1LE
From a stop. What's the fastest way? Amateur driver here. 2k rev? 3k? Tc on/off?
2013 SS/RS 1LE VR-Backup System, SOLO Perforsance HF Cats, Muffler Delete, BBK Off-road X-pipe 2002 35th Aniversary SLP SS-Sold |
03-05-2014, 06:28 PM | #2 |
Drives: 2014 2SS 1LE Join Date: Dec 2013
Have you tried launch control??
03-05-2014, 06:49 PM | #3 |
Drives: 2014 Camaro SS/RS 1LE 1967 Camaro Join Date: Oct 2013
A lot of seasoned guys on the forum say that launch control is a little to harsh, at 4000+ rpm and dumping the clutch they are seeing a number of blown axles. To much shock to the rear. They are recommending 2500 to 3000 and slipping the clutch slightly, you will need to play around with it.
03-05-2014, 06:59 PM | #4 |
Drives: 2010 2SS/RS M6 Join Date: Aug 2013
Around 3k slipping the clutch works best for me.
Trail and error, takes a lot of practice.
2010 2SS/RS
03-05-2014, 07:02 PM | #5 |
Captain Gingerbeard
Drives: 2012 IOM RS/SS 6MT Join Date: Feb 2013
I've got the same 285s on the rear of my SS.
I do about 3k and slip it. I've never side-stepped the clutch. That shouldn't even be running through your head. |
03-05-2014, 07:18 PM | #6 |
What you mean by slip? I usually just drop it
03-05-2014, 10:10 PM | #7 |
Captain Gingerbeard
Basically just bring your foot up briskly, but not as fast as you can. You want to put some "feel" in the pedal as you bring it up, so you don't release too quickly that your engine will bog down, or too slowly that you'll just melt your clutch.
03-06-2014, 12:09 AM | #8 |
Drives: 2013 Camaro 2SS 1LE Join Date: Feb 2014
I turn traction control off. Stabilitrak is pretty consistent but I usually leave it all off. When mine was stock I was launching at 25k-27k I put the drag radials on and went to 33k-35k with 17lbs of air. Smooth release of the clutch. I dumped my clutch once and blew my cv axle to hell and the end of the track.
03-06-2014, 09:10 AM | #9 | |
2013 Camaro SS1LECTSVZ28
Drives: 2013 AGM 1SS/1LE Join Date: Nov 2012
Pressure plate = keeps pressure on and sandwiches the friction disc against the flywheel with extremely strong springs (aka fingers) Friction disc= Friction Material between the Pressure plate and Flywheel Flywheel = bolted to the crankshaft, 1/1 relationship with the engine/crank speed When depressed the clutch pedal pushes fluid against a slave cylinder that is attached to the throwout bearing. The throw out bearing is attached to the "fingers"/springs on the pressure plate. Slip means you are using/ controlling the clutch by keeping you foot on the clutch pedal longer when you let the clutch out. You are literally letting the clutch disc slip against the flywheel. By doing this you allow the drive line to "catchup" with the engine speed as it "slips" on the flywheel. When you drop the clutch you going from 0-2500, 3500.... RPM instantly. Picture a merry go round on a playground that is spinning at a high rate of speed. If you reach out, grab it and stop it that is the same as dropping a clutch. It will jar your body and may even hurt. If you are wearing a glove and you put your hand on the rail and allow it to "still" slip some as you slow it down you will feel the heat build as it comes to a stop ....(I hope that makes sense ) Disadvantage to slipping a clutch, you create more heat and the friction material wears. Worse case clutch needs to be replaced. Disadvantage to dropping the clutch: you shock the driveline and most of the time the tires break loose and spin. Worst case is if the tires hook and don't spin you may find the next weakest link on the car...maybe an axle or the ring and pinion. I personally slip and feather the clutch when I drag race as I have only had street cars and bikes and nothing drag race dedicated. (Fastest car ran 11.3) ALL nannies are off. I rev the motor to about 3000 on the 1LE and as I start to let the clutch out I increase the throttle (gas goes down/clutch comes up). If I feel the tires spinning too much I "pedal" the car or lift off the gas slightly and then hit is again (sometimes a couple times in first ....basically acting as my own traction control. The BEST thing to possibly do is get as much seat time as possible at a drag strip and use the 60ft time as your indicator as to what works for you and what doesn't. Here is my first and only time out about 3 weeks after I got the 1LE: http://www.camaro5.com/forums/showthread.php?t=300728 -Matt
03-06-2014, 09:36 AM | #10 | |
Drives: 2013 1SS 1LE Black - Std Exhaust Join Date: Mar 2013
03-06-2014, 09:53 AM | #11 | |
I did run a SLP Blackwing (drop in with the elbow) last fall for a bit but never made it to the drag strip again. I just swapped it for a Roto-Fab that I may be installing later today. I will run that at the track with no other mods and see what happens.......But the motor is also broken in so I would assume it will be quicker either way. For fun I have the 275/40/20 PZero from an SS on wheels...I am going to back to back those with the Supercars to see if there is a difference.
03-06-2014, 10:09 AM | #12 | |
03-06-2014, 10:14 AM | #13 | |
Drives: Black '13 SS 1LE Join Date: Mar 2013
03-06-2014, 10:45 AM | #14 |
Drives: 2014 1LE Join Date: Sep 2013
All this advise is useless IMO. Use common sense and do what you do from a stop light except instead of idle try 2000k rpm and go from there. If you bog, rev higher or release the clutch slower. If you spin, rev lower or release the clutch slower.
Same principle for drag radials, just rev higher. With slicks just dump and pray the tire absorbs enough shock so you don't break something.
2014 Red Hot 1LE |
