05-10-2019, 12:54 PM | #1 |
Drives: 2010 Black 2ss Camaro SS Join Date: May 2010
repairing curber spillter
I curbed the driver corner of my ACS T4 splitter. Nothing major, but enough to crack it to the resin weave. hat material would i use to fill it?
thanks
ZL1 10 spokes,Dart 388,ECS Supercharger 2200x, E85 Flex Fuel sensor, Dart 388 , B&M Tranny Cooler, Vigilante 4000 Triple Disc TC,Katech Ported Heads, Texas Speed Sheet Metal Intake, ECS Big Blower Cam,ID 1700s, Fore Triple Pumps, E85,ATI Super Dampner, KW V3 Coilovers, Pfadt front and rear sway bars,Pfadt Trailing arms and toe rods,ZL1 Rear Diff, RPM 6l90e level 10 Tranny, SW Long Tubes no cats,Nick Williams Boosted 102mm TB, Dr Phil Tune,Borla Atak
05-10-2019, 01:20 PM | #2 |
Drives: 2015 Z/22 Join Date: Aug 2015
Some sort of body filler is what you need. 3M makes all kinds. You'll find this at most auto parts type stores. Clean then sand then clean again the area around the damage and then apply filler as instructed. Once dry you can sand and shape to the splitter, and then clean, prime, paint. Plenty of You Tube videos out there on using the stuff (and how to paint) that are much more detailed than what I just said. Good luck!
05-10-2019, 01:49 PM | #3 |
Drives: 2011 1LT/RS A6 RJT SuperCharged Join Date: Mar 2011
Depends, is it plastic or fiberglass?
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan EZ Streets, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ |
05-10-2019, 02:10 PM | #4 |
05-10-2019, 02:42 PM | #5 |
05-10-2019, 03:05 PM | #6 |
Drives: 2012 Camaro 2LT RS Join Date: Oct 2013
Looks like some form of plastic to me, maybe just sand smooth to make it look alot better?
Edit: Nevermind i see the little fibers now. I have no idea how to go about repairing that by oneself |
05-10-2019, 06:37 PM | #7 |
Drives: Camaro V6 Join Date: Oct 2016
Since it'll probably happen again, I suggest using that door molding trim stuff to protect the bottom edge.
05-11-2019, 03:06 PM | #8 |
Drives: 2015 Camaro 2ss Join Date: Apr 2017
I had my splitter crack about 4 inches when I first got it. I used JB Weld Plastic Bonder and it worked awesome. You can then sand it and I just painted mine with rattle paint. To really cover it up I used Plasti Dip the first time but didn't really like the texture.
05-12-2019, 06:57 PM | #9 |
Drives: '15 SS Join Date: Sep 2012
This is why i bought a cheap ebay splitter. Havent had issues with it yet
Follow My Car on INSTAGRAMhttp://www.instagram.com/forb1dd3n_ss
05-12-2019, 08:14 PM | #10 |
Evil Genius of Chevrolet
Drives: 2017 Z06, 2019 XTS, 2013 SS Join Date: Feb 2017
Something that small can be fixed with just a couple brush strokes of resin. Then use body filler to shape it. Prime and paint. It's not that bad at all.
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
