11-30-2012, 01:33 PM | #1 |
Drives: sold it Join Date: Apr 2009
Just a question
I ran into this problem yesterday, forgive me if it has already been discussed. What do you do when your battery dies on the Camaro and you dont have OnStar? How do you get into the car? the remote doesnt work, the manual key doesnt work. basically you cant get in your car at all. I called the dealer and they couldnt help either. Just want to know for future reference. I actually had Onstar and they had to unlock the car for me. But, a person who doesnt have onstar will be stuck in the middle of nowhere if the battery dies
2010 Camaro 1LT/RS, M6, RJT, gray interior, BA sound system
1100: 2/23/09 2000: 8/7/09 (finally) 3000: 8/11/09 (TPW 9/14) 3300: 9/14/09 3400: 9/14/09 3800: 9/22/09 car # 48156 has been born |
11-30-2012, 01:36 PM | #2 |
Drives: 2014 Summit White 2SS/RS M6 Join Date: Aug 2012
i havent try my self to open the door with the key, but are you sure the key wont open the door?
11-30-2012, 01:37 PM | #3 |
Not about to try that , but i thing that there is a DEFAULT system , that if no ONSTAR the normal key will open the darn thing
11-30-2012, 01:38 PM | #4 |
positive it doesnt work, i called the dealer, even the manual lock is electronic in some way, has something to do with anti theft.
11-30-2012, 01:40 PM | #5 |
Hope you are right about the default system....that is the only flaw i have found in this car the 3 years i have had it
11-30-2012, 01:41 PM | #6 | |
Drives: 2017 2SS Join Date: Mar 2012
So, for those that store their car over the winter and they take the battery out. If they lock the car, they can't get back in? There has to be more to this story.
1996 Corvette - LT4
2017 Camaro 2SS 2019 GMC Sierra 2500 HD 2015 Harley Davidson Ultra Limited |
11-30-2012, 01:45 PM | #7 |
I keep my car garaged at work during the week. I was actually working at another location. My Boss moved my car in the morning, when he went to drive it back in, the battery was dead..he tried the remote, he tried the manual key and the doors would not unlock. This was verified by the dealer..if the battery dies you cant open the car.
11-30-2012, 01:51 PM | #8 |
Drives: ... Join Date: Apr 2012
you can either unlock the door with the key, or go in through the trunk. take your pick.
11-30-2012, 01:53 PM | #9 |
Like I said, the manual key will not work if the battery is dead. The remote wont work either so therefore, you cant open the trunk
11-30-2012, 02:30 PM | #10 |
Drives: 2016 SS Join Date: Jun 2011
OnStar can't work without power either.
Added some links that may help - it appears the blade key works in the door without power: http://www.camaro5.com/forums/showthread.php?t=214574 http://www.camaro5.com/forums/showthread.php?t=51770 http://www.camaro5.com/forums/showthread.php?t=168801 http://www.camaro5.com/forums/showthread.php?t=112713
11-30-2012, 03:21 PM | #11 | |
Only the driver door has a key cylinder. Unlock the door from the outside by turning the key counterclockwise. Lock all doors from the outside by turning the key clockwise. The door lock cylinder turns freely when either the wrong key is used, or the correct key is not fully inserted. The free turning door lock feature prevents the lock from being forced open. To reset the lock, turn it to the vertical position with the correct key fully inserted. Remove the key and insert it again. If this does not reset the lock, turn the key half-way around in the cylinder and repeat the reset procedure. |
11-30-2012, 03:40 PM | #12 | |
11-30-2012, 03:41 PM | #13 | |
11-30-2012, 03:46 PM | #14 |
just to test it because i wasnt here when this happened, and to make sure my boss isnt incompetent. I just disconnected the battery and you can not unlock the doors...manually or remotely...the doors do have power locks so that might be the reason why ..or...my car, out of the thousands and thousands that were made, is the only camaro that this happens to
