08-24-2013, 08:54 PM | #1 |
Drives: 2013 Ashen Gray M6 ZL1 Join Date: Sep 2012
Inside Door Trim Lighting
Took the car out for a spin tonight, and noticed that the lit strip along the door panel is very very dim. In my SS I remember the blue light was very bright. In my ZL1 though its barely noticeable. Very very dim, still in that light blue color. I tried dimming the instrument lights and then the door strips faded completely. So then I tried turning the instrument lighting as bright as possible, but that strip along the door panel still stayed very dim. I just seem to remember my SS was way brighter. Just wondering if anyone else has noticed? Thanks
Sent from my iPad using Tapatalk - now Free |
08-24-2013, 09:06 PM | #2 |
Drives: '12 ZL1 #1609 Join Date: Feb 2010
Yes I also noticed, from what I've read there is tape or something behind the panel making it dimmer and is also why it doesn't go all the way up to the dash as well.
Life is too short to drive cars that suck.
My build Thread |
08-24-2013, 09:07 PM | #3 |
I haven't taken mine apart to fix it yet, I'll eventually change it to red though.
My build Thread |
08-24-2013, 09:18 PM | #4 |
Drives: 2012 ZL1 - #670 Join Date: Jun 2009
A lot dimmer than my SS for sure. It seems when I park the ZL1 at night, and open the door the strip gets much brighter ... Kinda weird
08-24-2013, 09:43 PM | #5 |
∞ Smiles per mile
Drives: 2013 ZL1 Summit White A6 Join Date: Jun 2009
I had my ZL1 for about a month before I even knew it was there. Very dim.
Sent from my SAMSUNG-SGH-I317 using Tapatalk 2
2013 ZL1 #4739
'Heisenberg' Color - Walter White Roto-Fab CAI On Reddit? Check out /r/ZL1/ |
08-24-2013, 10:10 PM | #6 |
Drives: 2012 M6 ZL1. 2019 Altima.07 FJR1300 Join Date: Nov 2011
08-24-2013, 11:12 PM | #7 |
Drives: Camaro's, always have, always will. Join Date: Oct 2010
...it's very subtle, and is ambient light reactive I thunk.
08-25-2013, 12:07 AM | #8 |
SpaceAholic
Drives: 2013 Camaro ZL1 Convertible Join Date: Feb 2010
08-25-2013, 07:09 AM | #9 |
Okay, wasn't sure if mine was malfunctioning or what. Last nite I just noticed that it seemed really dim. So I guess it's just the way it is, and sure I like that its subtle, but I'd like to be able to make it just a tad brighter and have it go all the way around from end to end. Someone wrote it has some sort of backing blocking the light, so the question is has anyone tried peeling off the backing? In my opinion the SS looked better, and by dimming the instrument cluster I could also dim the door trim lighting. Thanks to all those who commented.
08-25-2013, 08:01 AM | #10 | |
http://www.camaro5.com/forums/showthread.php?t=47924
My build Thread |
08-25-2013, 04:59 PM | #11 |
Drives: ZL1, Rally Yellow Join Date: Apr 2013
I guess I better drive my carat night and open the door because I never knew it was lit up
08-26-2013, 08:40 AM | #12 |
Drives: 2017 Hyper Blue Metallic ZL1 Join Date: Nov 2011
It's very dim on the 2014 ZL1 as well.
08-26-2013, 11:15 AM | #13 |
Where am I?
Drives: Zoe the ZL1, 2012 Frontier Join Date: Apr 2011
From what the guys over in the DIY sub forum think it is because of the black paint that the panels are painted and that there was most likely some over spray into the light pipe channel. All it takes is a very very light sanding, after removing the light pipe, with automotive sand paper (like 2500 [yes, 2500] grit sand paper) and it should improve the brightness.
Other guys haven't bothered with sanding and added a secondary LED at the bottom of the light pipe to increase the brightness. Both mods are quick and very easy. Search "ZL1 ABL" and you'll find a topic with that exact title and you'll see some pictures.
FOR SALE: 2013 ZL1 Message me if interested |
08-26-2013, 12:12 PM | #14 | |
Drives: 2017 2SS 50th Anv, 1972 RS Join Date: Mar 2009
http://www.oznium.com/prewired-leds BTW - I also changed my window and door lock switches to red LED - that is a pain but looks great. |
