| Camaro DIY & HOW-TO instructions & discussions All DIY projects & discussions |
Thread Tools |
#1 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: . Join Date: Jan 2008
Here it is folks.... a complete guide on ABL installation using EL wire, and aquarium 3/16" diameter tube.
Rickray, and myself completed this yesterday.... we had a great time doing this, while our wives went shopping ![]() See the attached photos ( with comments ) that should answer most, if not all your questions. Here's the bill of materials: - Green-Blue EL Wire 2.2mm : $0.99 ft - get 10 feet http://elwireonline.com/inc/sdetail/187 - Two ( 2 ) four way splitters: $1.50 ea. http://elwireonline.com/inc/sdetail/146 - One ( 1 ) female connector : $1.75 ea. http://elwireonline.com/inc/sdetail/120 - Three ( 3 ) male connectors : $ 1.75 ea. http://elwireonline.com/inc/sdetail/108 - EL Driver for 12VDC ( 0-4 ft length ) : $4.99 http://elwireonline.com/inc/sdetail/296 - 2 x Aquarium rigid acrylic air tube ( 3/16" diameter, approx 40" long ) : $1.99 x 2 = $3.98 - Super glue. - Approximately 5' of standard Stereo wire ( 20 or 22 gage ) -How to solder EL wire: Last edited by camarorick; 04-10-2013 at 09:57 AM. |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: My new Jetta/chauffered by 2010 2ss Join Date: Oct 2009
Awesome! The best! Excellent!......of course!
Don't Feed the Troll
Drives: 2010 Camaro 2LT/RS & 1999 Corvette Join Date: Jun 2009
Nicely done guys, and a great detailed description on how to do it.
My wire should be in tomorrow and I have the sanding done or so I thought. I didn't go the extra 1/16 - 3/32 below the angle, is it need to get the light to show through properly? I may also be able to do it without drilling a hole. The wire side connectors I will be using may fit right through the rectangle holes without messing them up.
![]() Drives: 2010 Camaro SS/1967 Camaro SS Join Date: Jul 2008
Very nice write up!!
Thanks,
thecamaroguy 2010 Camaro 2SS - CGM 1967 Camaro SS350 - Primer Proud to say I have always owned a Camaro! A Camaro has been my Daily driver since I started driving! |
#5 | |
Absolutely, we tried to do it directly on the corner of the angle, and the light was very faint...... we then retaped, and continued to sand ![]() Thank you dear ![]() Thanks !! |
#6 |
Drives: 2010 F150 Lariat, Candy Red Join Date: Aug 2009
That's real nice!
Heck I just got tired reading it. |
#7 |
Whipped
Does it dim with the dash lights?
looks great.
Magnaflow Cat back / ROTO-FAB Intake / Whipple Kit / RDP Tune.
580hp - 650Tq |
#8 |
#9 |
looks great they got any orange/red
#10 |
INJACC
Drives: 2010 CGM 2LT/RS AUTO Join Date: Jan 2009
#11 |
ZEUSS
Looks great. This way looks easier than the digi-key tube. Is this kit dimmable?
#12 |
![]() ![]() ![]() Drives: 2010 2SS/RS Black Join Date: Mar 2009
Absolutely awesome tutorial on the ABL guys, really hit it on the head with this one.
Thanks for taking the time and being detailed with both the description and the pictures, going to make it real easy for the rest of us. You guys ROCK!!!!!
Understeer, Oversteer, Wheel Alignment (Camber etc), Torque, Horsepower, Camaro
Fold for team 11108 to help find a cure! Folding@home Stanford's Research DC Program. |
#13 | |
My hats off to these guys.
#14 |
![]() ![]() ![]() Drives: 2SS SIM Join Date: Apr 2009
bravo and good work looks really good still gonna go with leds but DAMN fine job guys Damn fine
![]() ![]() ![]() and i really love the write up
2SS RS SIM gray leather stick shift ground FX
![]() thank you gary richards @ classic chevy in sugarland welcome home 1100 4-27-09 6000 6-27-09 ![]() yes i got to the dance late don't hate me |
#15 |
they both dim with the lights i think
#16 |
:chevy:
Drives: 2LT/RS Join Date: Jun 2008
Great detailed write up. Still deciding on which one to do. All three types look great, have you guys seen the light tape thread yet in cosmetics?
These all look great. Great job! |
#17 |
ZEUSS
Just ordered mine!
![]() Question - I guess when I go to install my kit I might answer my own question,..... but why didn't you drill the hole for the passenger side closer to the gauge cluster so you didn't have to fish the wire so far? |
#18 |
why do you have four connectors and only use 2 of them? Also couldn't you just use 2 drivers and connect the other one behind the gauge cluster?
#19 |
![]() Drives: EXT Join Date: Nov 2008
Great job!
#20 | |||
Yes, they dim perfectly with the doors, and your speedometer cluster
)...... Again, we didn't want to touch anything in the cluster, so the one power source is all that's required ( less touched, less chance of things breaking ).....
#21 |
![]() Drives: 2010 CGM Camaro SS\RS Join Date: Apr 2009
What did you use the stereo wire for? I tried to look in the photos but the best I can make out is maybe used it to pull wire from driver to passenger side?
I think I see what you did, you put a plug on each end to extend the EL wire. I just realized how short you connector wire was coming off each piece. Why not make it a continuous wire when soldering? Can't you solder the speaker or some other wire to the EL and then put just one connector at the end?
2SS CGM, IO Interior
BAD 2SS West Chester, PA Last edited by CASTIG 2010SS; 10-19-2009 at 08:16 AM. |
#22 | ||
#23 |
Thanks. Good idea about having the extra connection so you don't have to pull the wire all the way everytime.
Why 2 4-way splitters? Did you use them both? The best I can figure is you put a small lead on both lights with a male plug. The stereo wire had a female plug on one end and a male plug on the other. The drivers side EL wire plugged right into the 4 way splitter and the stereo wire plug into the passenger side wire and them ran under dash and then plugged into the splitter. Is that correct? Just seems like you ordered more parts that required? Thanks for the info.
BAD 2SS West Chester, PA |
#24 |
just can't seem to leave
wow. that looks awesome! great job & great write-up!
#25 | |
You got it, Exactly as you wrote. The reason I have all these connections was for ease of dismantling, and / or future expansions, besides, these connectors are really cheap @ $1.50 each.... I'm thinking of putting this EL wire under the dash too ( why pay $200 for G.M. floor lighting ).
| Thread Tools | |
