Old 05-23-2011, 05:57 AM   #1
jhyland87
Drives: 2011 2ss rs, black
Going the cheap route for now.. Cutt off the mufflers, and/or cat?..
hey guys, so I def want to get the borla exhaust system, but for now, I think I might be going the cheap route.
Has anyone tried to just replace the cat and/or muffler with just a straight pipe? I see some stock setups on craigslist with this done, but I dont know what it sounds like..
Anyone got a video of it? Will it set off my check engine light?
Thanks.
jhyland87 is offline   Reply With Quote
Old 05-23-2011, 05:58 AM   #2
jhyland87
P.S. Obviously right now, I just want it to sound mean.. I doubt it will get much of a power gain, but in the same respect, I dont want it to lose power either..
Old 05-23-2011, 08:06 AM   #3
CamaroCowboy
CamaroCowboy's Avatar
Drives: 2013 Chevy Truck
Here is mine when I had the muffler delete...I had headers also though so it is a little bit louder than just muffler delete. If your sensative to drone then i wouldn't recommend it until you ride with someone who has it done.
Texas speed LT Headers and High Flow Cats, Magnaflow 3 inch cat-back Exhaust, SNL V2 Comp CAM, Texas Speed Underdrive Pully, G5CR CAI, Hurst Short Throw Shifter, JetFlo Mass Air Sensor, Custom Grill, Amber AAC Headlight and Fog Light Halo, Amber footwell Lighting, Amber under hood lighting, RK Sport Ram Air /Heat Extractor Hood and ADM Racing Scoop. 447.9 RWHP 428 TQ
My car is exactly that, No one has to like it but me!
CamaroCowboy is offline   Reply With Quote
Old 05-23-2011, 08:23 AM   #4
Skidpuppy
ACE5
Skidpuppy's Avatar
Drives: 2010 2SS/RS LS3
Go with a muffler delete. Cutting off your cats will throw a CEL.
Muff delete thread.
http://www.camaro5.com/forums/showthread.php?t=24815
SIM 2SS/RS LS3, Vararam, RX Catch Can, SOLO HF Cats, Flowmaster AT Catback, Skip-Shift Eliminator. 404HP/414TQ
Skidpuppy is offline   Reply With Quote
Old 05-23-2011, 08:26 AM   #5
Juiced1
Drives: 2012 2SS CAMARO 45th
If you can handle the drone then the old muffler delete works great. As far as chopping out your cats goes its pretty illegal. So your run of the mill exhaust shop won't do it. A good cheap options is Solo axlebacks. They sound great, pretty loud and have no drone! But if you don't drive on the highway much and can handle the drone by all means... chop them mufflers.
Juiced1 is offline   Reply With Quote
Old 05-23-2011, 08:28 AM   #6
caverman
caverman's Avatar
Drives: '69 SS Convertible
Here is what I did when I first got my car. Muffler delete, resonated x-pipe, and rear cat delete. This got me by for a while until I got the money together for header and exhaust. I then sold this setup to a guy with a 2LT for $300 so ulitmately it did really cost me much at all.
http://www.camaro5.com/forums/showthread.php?t=64964
Build Journal
Old 05-23-2011, 09:05 AM   #7
dvargo
Derek
dvargo's Avatar
Drives: 2010 camaro ss 1977 corvette
Send a message via AIM to dvargo
I just did a muffler delete last week and it sounds great. I guess I was use to the drone since when I did the exhaust on our corvette it has it, but you get use to it. I had a shop do mine for $120 and just used the stock tips. Its alot cheaper then buying the slp kit which is the same thing.
dvargo is offline   Reply With Quote
Old 06-02-2011, 12:12 AM   #8
jhyland87
Did anyone remove the resonator AND muffler? too loud?
Old 06-02-2011, 12:29 AM   #9
mikeSS
mikeSS's Avatar
Drives: 2015 c7
headers add more than a little bit.
Old 06-02-2011, 12:44 AM   #10
Inferno2SS
Inferno2SS's Avatar
Drives: 2010 IOM 2SS/RS
You may want to consider adding mid pipes with high flow cats while you are at. You can pick up some decent HP without needing a tune and they definitely improve the sound quality at the same time.
Inferno2SS is offline   Reply With Quote
