![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '69 SS Convertible Join Date: May 2009
My ½ price version of the Magnaflow 2.5” Comp Series exhaust
This is the documentation of my ½ price version of the Magnaflow 2.5” Comp Series axle-back system. Although it won’t be 100% as good it should be real close at approximately ½ the cost or less. Plus, I have read in a few threads how the factory exhaust seems to be very efficient but quiet so using our factory pipes should work well enough.
This is what I’ll be attempting to replicate. If you shop around you can pick up this system for about $945. http://www.magnaflow.com/02product/s...one=all&id=126 This is also very similar to the SOLO Mach-X system which is $750 delivered. I was on the fence with just buying the SOLO system but I figured I could save myself the cost of the Hurst Shifter I plan on getting. Again…I know that the SOLO system would ultimately be better but I’m limited on $$$ and if this works out I’m going to feel better about getting it done at such a reasonable price. I’ve ordered an LS3 but the same can be done on an L99. Here is the plan: -Remove factory H-Pipe and replace with Magnaflow resonated X-pipe (#1386) -Remove the factory resonators -Do a muffler delete using the 4” Magnaflow tips (#35121) I asked members on this forum in the TX sub-group about muffler shops and I eventually found one that quoted a muffler delete for $80 and X-pipe install for about $100 depending on needed pipe. I’m going to be conservative and say $150+$80+tax for ~$250 to install. I ordered my parts from JDP Motorsports and got a great deal. So far I have $173 in parts to my door. With the estimated $250 install I should be able to get this done for about $425 or possibly less. I really like the looks of the Magnaflow tips but I could have saved myself almost $100 if I wanted to use the factory tips. IMO I think the Maganaflow tips look a lot better and it’s worth the extra money for these. The parts came in today and I’m really excited to get my car now. I should be picking it up in about a week and I plan on going to the muffler shop the day I get it or maybe the next day. The tips were larger looking than I expected. I can only imagine how big the 5” must look on Magnaflow’s axle-back system. Here are some pics to start with and I plan on documenting everything along the way and will eventually get some sounds clips to go with it as well. The pics of the inside of the #1386 didn’t come out as well as I liked but I can definitely see the X inside the muffler and from the pics you can see how it is perforated.
Build Journal ![]() |
![]() ![]() ![]() ![]() ![]() Drives: 2010 IOM 2ss/RS Join Date: Sep 2009
yep, thats what i am gonna do too, except i used stock tips, and will be using the non resonated xpipe (i think) - see how it all works out
#3 | |
Also....the way I looked at it is that Magnaflow could've used any X-pipe they wanted with the muffler delete and they chose the #11386. I think it's actually a little bit cheaper as well.
formerly "wh0rsep0wer"
Drives: 2016 1SS Summit White Join Date: Oct 2008
2010 1SS/RS - CGM/Gray Interior - M6 (SOLD) Kooks 1 7/8" headers, Solo Mach-X, Vararam.
2012 2LS - Black A6 (SOLD) 2016 1SS Summit White A8 |
Awesome idea
#6 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: RSSS Join Date: Dec 2009
I'm glad you FINALLY made your decision!
#7 |
![]() If you think I was wishy washy about the exhaust you should've read some of my emails on deciding if I should even get the car or not. Now....if the car will just get here and this stupid COLD weather would finally go away I might be able to finally get this done! My freakin window was frozen shut this morning. ![]()
#8 | |
![]() Just hope that since we're actually have a cold winter we'll get a few years of the warm ones we're accustomed to! ![]() |
#9 |
Drives: 2011 Camaro SS/ 2016 Camaro SS Join Date: Jun 2009
Nice!!! I'm looking forward to seeing how it turns out as well as the sound!!! Please feel free to call, email or PM me anytime with questions!! We appreciate your business and have a great day!!!
![]() Kind regards, |
#10 |
Search Ninja
Drives: 2010 Black 2SS/RS A6 Join Date: Oct 2009
Replacing a pair of mufflers with a resonated X-pipe is bound to be pretty loud. I guess we'll see just how loud.
Halltech CF 102 fed GPI modded intake manifold Bo (knows) White ported TB Kooks LT's/ Dynomax VT Pfadted (springs/sways) Dyno tuned by Rhino and GPI I once parallel parked a train. |
#11 |
You're right, that set up is pretty much exactly the same (including tips) as the SOLO and the SOLO sounds great. You've got some work to do but if it means saving cash, it's worth it. Anyway post a sound clip when you can.
#12 |
"Go on the last yellow.."
Drives: 2010 2SS/RS L99 CGM Join Date: Jan 2010
I DIDi mine yesterday.We used the exact same MagnaFFlow part and deleted the same parts as pictured above only used the muffler guys pipes and used the stock tips.$200. We expected it to be much louder but it was not. The sound is much deeper and sounds like it looks. We are very happy.
#13 | ||
#14 |
Nice write up. Same thing I'm doing!
http://www.camaro5.com/forums/showthread.php?t=344754 Summit White 2014 2SS 1LE Recaros, NPP exhaust, Nav 2010 2SS A6 - sold. |
OK...I'm starting a better V6 exhaust examples thread!! | KMPrenger | Camaro V6 LLT Engine, Exhaust, and Bolt-Ons | 612 | 09-06-2024 08:00 AM |
Magnaflow Comp Series | Slow1 | V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment | 21 | 12-29-2009 12:44 AM |
New Billy Boat 2010 Camaro Exhaust | Ragin Racin | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 11 | 10-20-2009 06:09 PM |
Magnaflow Comp Series Exhaust Pics | RedJewel2SS | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 49 | 09-02-2009 10:17 AM |
Magnaflow Exhaust in stock | Herron Performance | V8 Bolt-Ons & Tunes | 1 | 08-04-2009 03:19 PM |
