08-16-2015, 05:48 PM | #1 |
Drives: 2011 Camaro 2Ss M6 Join Date: Dec 2011
Tru-Trac What Else While Im in There?
Im thinking about purchasing a Tru-Trac but want to make sure that I am fully aware of any other types of modifications that can be completed while installing this piece. Let me know what you've done!
08-16-2015, 06:17 PM | #2 |
LVL 50 Troll Stomper
Drives: 2010 Camaro Join Date: Feb 2008
Billet main caps for sure, I got a diff cover with reinforcing bolts too
08-16-2015, 06:23 PM | #3 |
08-16-2015, 07:39 PM | #4 |
Drives: cars Join Date: May 2011
LPW is the only one, bolts are integrated into it.
I wouldn't add more gear when PD supercharged unless you enjoy shifting prematurely or purely want a tire melter. There's no point. |
08-16-2015, 08:36 PM | #5 |
Drives: 2010 2ss 6 speed Join Date: Apr 2011
08-16-2015, 09:42 PM | #6 |
08-17-2015, 07:19 PM | #7 |
"Cam Only"
Don't go G-Force Devin. Get DSS.
Seen too many "1000hp" G-force axles snap at 600rw.. Go with the best, first time. DSS. Or just get a ZL1 rear end with 3.73's. $3500 off jegs and it'll be good to 1200rwhp easily.
2013 AGM Camaro 2SS/RS M6 | LSA Blower, 2.5" pulley, 10% lower, FIC1000's, Fore Innovations Twin Pump fuel system w/ Flex Fuel, CMS Custom Grind Cam, Kooks 1 7/8" headers w/ catless off-road pipes, NPP Exhaust, 3.91's, JLT ZL1 Intake, Prospeed Heat Exchanger | Pfadt Suspension, 1LE Sway Bars | DSS 1000hp axles |
Tuned by Ryne @ CMS E85: 734rwhp/636rwtq (mustang dyno) |
08-17-2015, 08:32 PM | #8 | |
Ill check out the 3.73's. Do those have better pickup off the line or am i just going to be running thru my gears? Hard decision going with diff gears or staying stock.. |
08-17-2015, 09:52 PM | #9 |
"Cam Only"
You won't run out of gear in any half mile events.
You'll notice a difference over the stock 3.45's. Strong rear diff and solid axles. You won't have to upgrade anything in the rear end if you go that route and do a stroker and really turn up the boost. So I vote ZL1 rear end.
08-23-2015, 11:26 PM | #10 |
Sarcasm loading --------
I have a tru-trac carrier with 3.70's in it for sale with low miles.
If your interested, let me know.
"The salesman actually told me to stop getting it sideways during the test drive"
2018 MBM ZL1 1LE - 652 rwhp, 588 rwtq SAE 2014 CRT ZL1 574 rwhp, 537 rwtq - SOLD 2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq - SOLD |
08-24-2015, 12:03 AM | #11 |
Drives: 2013 Camaro SS Turbo Join Date: Apr 2014
You can do anything you like to the stock diff but it's still a weak link and not worth putting money into. Do the zl1 upgrade and forget about it
08-24-2015, 12:57 AM | #12 |
What is it going to take for me to upgrade to the ZL1 setup? I will be using aftermarket axles of course and a Tru-trac. Im assuming i will stick with the stock ZL1 gears then?
08-24-2015, 01:05 AM | #13 |
http://www.jegs.com/i/Chevrolet-Perf...59394/10002/-1
Everything gets changed out, nothing for the SS rear works on the zl1
