06-06-2013, 08:11 PM | #1 |
Russ
Any pics of installed nitrous systems?
I am going to install a nitrous system in my M6 SS. Does anyone have pics they can post of their set up so that I can pick which one I like best?
Russ |
06-06-2013, 08:13 PM | #2 |
Drives: 2010 Camaro Join Date: Feb 2010
It's going to be in the trunk and there are only so many way you can mount the bottles.
Mine is mounted to the cage behind the passenger seat but I'm assuming your car doesn't have a roll cage. |
06-06-2013, 08:47 PM | #3 |
Master ASE, GM, LSX Tech.
Drives: 2010 Camaro SS Join Date: Oct 2012
I have the Nitrous Express kit specific for the Gen5 Camaro. Bottle is mounted in trunk with brackets that I made. The NX Progressive 4 controller is mounted down with the batteries. I got the switch plate that fits in the center console from Nitrous Outlet. It's a nice piece, all switches are hidden and it fits right into the console with no modifications.
06-06-2013, 09:11 PM | #4 |
Russ
Thanks for posting! Russ |
06-06-2013, 09:33 PM | #5 |
Drives: 2006 Crownline Join Date: May 2012
06-06-2013, 09:33 PM | #6 |
06-06-2013, 09:35 PM | #7 |
06-06-2013, 10:38 PM | #8 | |
Hasbin of Stock Bottom HP
Here's Mine:
06-07-2013, 12:29 AM | #9 |
GrINned & JUICEd
Drives: 15STI, 10Expy, 10 2SS/RS M6, 47KB1 Join Date: Nov 2009
http://www.camaro5.com/forums/showthread.php?t=217103
Heater hoses have been relocated since these photos.
GPI SS3 Cam & stuff,N.O. Plate(dedicated fuel tank,progressive,fuel hose upgrade,remote opener,heater,console switches),LNC2000,CTAP,ARH 1 7/8" LTs/gutted cats/X pipe/mufflers,Jet Hot coated LTs,GPI HPT Tune,CAI, Scoop,Rx Catch Can,Gates heater hose relocation, Remote clutch & auto brake res,Metco loop,Momentum Tunnel Brace,TSW Nurb 18",555 & 05,Pfadt trailing arms & toe rods,Autometer WB,Fesler Pillar Pod,LED strips (int),Lloyds floor & trunk mats,LED DRL/front turn & license plate,DRL harness,VLEDs tail lights,Plasticoat Bowties. Ord: Oct 5, 2009 Rec: Nov 19, 2009 13.17@112.6 stock
06-07-2013, 01:36 AM | #10 |
Russ
Do you have to remove the engine cover with
nitrous? |
06-07-2013, 07:03 AM | #11 |
GrINned & JUICEd
Mine did not fit. I believe if you trim it, it will fit on the N.O. system. Never tried trimming it though.
06-07-2013, 01:59 PM | #12 |
chevy pride
ive changed a few lil things but here is what it did look like looks a lil diff now.
check out ky speeds fb page https://www.facebook.com/kyspeed |
06-07-2013, 02:42 PM | #13 |
GrINned & JUICEd
Your foam pad is stuck to the hood on the passenger side. Near the hinge. Had to rtv my driver's side.
06-07-2013, 03:14 PM | #14 |
chevy pride
ya after this pic it fell on the header and got crispy . where were u at the day after the pic lol.
but ya got to us something to hold them in they seem to do that alot.
