Old 05-11-2022, 05:31 PM   #1
tlamb2
WHPLSH
tlamb2's Avatar
Drives: 2010 SS Maggie,ARH,Meth,AFE Coilove
Maggie running high flow cats
The car is registered in Arizona with no smog check and 5-year sticker. Should I ditch the cats? or keep them on what are the pros and cons thanks
tlamb2 is offline   Reply With Quote
Old 05-11-2022, 06:31 PM   #2
The SS Godfather
The SS Godfather's Avatar
Drives: 2010 CAMARO RS/SS
I Would ditch them myself - nothing like a breathing easier V8 engine !!
The SS Godfather is offline   Reply With Quote
Old 05-12-2022, 07:10 AM   #3
Bildo
Bildo's Avatar
Drives: 2012 2SS/RS LS3
Gut them and be done
2012 2SS M6, ERL Superdeck 6 427, PRC 255 Heads, Procharger F1A w/ 3.85 pulley, 1300hp intercooler, Squash Dual 450lph, E85, ID1700, RXT Clutch, DSS 1pc driveshaft, GForce axles, Eaton Detroit Trutrac, a bunch of other crap I don't feel like typing.
Bildo is offline   Reply With Quote
Old 05-12-2022, 05:50 PM   #4
cc-rider
Drives: 2010 Camaro SS
Don’t do it. Get rid of those cats ASAP. Read my thread here:
https://www.camaro5.com/forums/showthread.php?t=563071
I didn’t head the warnings of others and paid the price. All that said…there are some who have gotten them to work. Had I had a h-pipe instead of an x-pipe…I may not have taken out my engine. For what its worth, mine were right at the end of my long tube headers. Perhaps mounted further downstream, they may have lasted. Not sure. Problem is that the OEM’s put a lot of testing and research into where they place the cats. A luxury most of us don’t have.
I hate the smell of running without cats…but they don’t hold up to boost well.
cc-rider is online now   Reply With Quote
Old 05-13-2022, 12:47 AM   #5
tlamb2
WHPLSH
tlamb2's Avatar
Ok I am gonna gut them, does it need to be tuned after you gut them? And is the smell that bad? and the engine runs cooler right
Old 05-13-2022, 11:25 AM   #6
BiggFoot
BiggFoot's Avatar
Drives: 2010 Camaro (M6) 1000+ HP SBE
What psi are you running right now?
F-1X, Cog Drive, ATI Super Pulley/Sprag ~ 19 psi
Blower Cam
Brodix BP BR 3 Heads
Kooks LT Headers and full 3" exhaust
Fore Triple Pump Fuel System with ID 1700X Injectors - E85 conversion
DSS 9” Conversion (1400 hp axles, driveshaft, pumpkin) & Strange 3.70 gears
McLeod RXT Twin HD Clutch & Upgraded Slave
RPM Level VII
TR6060
BMR Drag Suspension Package w/Strange shocks
Carlyle 15" and M/T ET Street R radials
10.1 @ 143 mph 1/4 mile
BiggFoot is offline   Reply With Quote
Old 05-13-2022, 04:23 PM   #7
Batmanntexas
Batmanntexas's Avatar
Drives: 2012 Camaro SS (2SS)
Personally, I think the smell is great, as long as you aren't running abnormally rich A/F ratio at idle.
It shouldn't have any effect on engine operating temp...unless they are currently plugged.
I wouldn't think a re-tune would be necessary, as it's not a huge difference in airflow on the intake side.
745RWHP/634RWTQ on 93 @ 10psi
806/676 on E85 @ 10psi
COTW 9/8/14
Batmanntexas is offline   Reply With Quote
Old 05-13-2022, 06:52 PM   #8
tlamb2
WHPLSH
tlamb2's Avatar
I am running 9 PSI and I have boost activated cutouts right behind the cats. And I am running ARH headers and high-flow cats. What I have read is that ARH stuff is better than most other cats.
Old 05-15-2022, 07:14 AM   #9
BiggFoot
BiggFoot's Avatar
Hmmm 9 psi. I agree with the others, if you haven't done it already then gut them. My personal experience was that once I progressed past 7 psi the cat issues began. How are you able to keep AZ plates while living in CA. Seems to me the environmental rules in CA are very restrictive, but if you feel there will be no repercussion then gut away!
Blower Cam
RPM Level VII
TR6060
Old 05-17-2022, 12:10 AM   #10
tlamb2
WHPLSH
tlamb2's Avatar
Cat check
I am gonna get under the car and look thru the cutouts to see what shape they are in. The car only has 50k miles but Maggie is on it for 40K miles. And I have a ranch in Arizona and no smog in the county plus 5-year registration for 200$ every 5 years sure beats Cali plus the car won't pass in Cali. The car is getting aFe coilovers and the whole suspension replaced right now. Should have it back this week. I will report back my findings
