![]() ![]() ![]() Drives: 2010 Camaro SS Join Date: Dec 2006
Engine down. Bent a rod. Time for a new short block
I think I finally took out my stock LS3 with the Kenne Bell huffing into it. Was rowing through the gears doing a burnout and at high rpm in 2nd gear it lurched hard and then started running rough with a little vibration. I was at least able to drive it home about 30 miles. Started it the next day and I have a distinct knock that is coming from the bottom of my engine and not the valve train. I’ll try to have my son upload the video to YouTube and post it.
So. Time for a new forged short block which is what I wanted anyway so I can turn up the boost. Open to recommendations on a good place to get a forged short block.. |
Trouble_SM
Drives: 17' Summit White ZL1 Join Date: Jan 2015
Thompson Motorsports 388 or 427 iron shortblock should do it.
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 12 camaro ss, 72 chevelle, 91camaro Join Date: Dec 2013
Venom racing engines has pretty good pricing for short blocks as well.
Dan
Drives: 2010 Camaro 2SS IOM Join Date: Nov 2013
Any updates? What direction have you decided on?
Dan
2010 IOM SS YSI-B, Pat G Cam, Ported CTS-V Heads, ARH LTs MBRP 3" exhaust http://www.camaro5.com/forums/showth...&highlight=ysi |
Finally got to my blown Camaro after it sitting in the barn for 2 years. Took off my exhaust and I can see exactly what took out my engine. Guts of the high flow cats let loose and lodged in my x pipe and...kaboom! Still haven’t dug into the engine to confirm bent rods yet. But I’m pretty sure that’s it. Will update. Got the forged rotating assembly on order!
Chalk me up for another boosted engine owner who didn’t follow the advice that no cats will hold up under boost. Lesson learned. But looking forward to my new forged LS3 and what it can do (catless!!!!) |
#6 |
![]() ![]() ![]() ![]() Drives: 2011ss/rs camaro Join Date: Sep 2011
Wow
#7 |
![]() ![]() ![]() ![]() ![]() Drives: 2014 Camaro SS 1Le Join Date: Feb 2016
CC… where’s you get your engine from?
2014 SS 1LE Money Pit/ Forged 402
CAM 22X/24X, .619/.617, 113 LSA/ LS9 Heads FIC 1200cc/DSX Aux Pump//McLeod RXT Clutch 730whp: 630Trq |
#8 |
I ordered a forged rotating assembly from cnc-motorsports out of South Dakota. Local engine shop to do the machine work. Going to build it myself. Hopefully can still use my block. We’ll see when I tear into it.
#9 |
GrINned & JUICEd
Drives: 15STI, 10Expy, 10 2SS/RS M6, 47KB1 Join Date: Nov 2009
Yeah, my cats blew out with a little shot of nitrous. Driver's side waded up in the cat, passenger side made it to the rear diff .
GPI SS3 Cam & stuff,N.O. Plate(dedicated fuel tank,progressive,fuel hose upgrade,remote opener,heater,console switches),LNC2000,CTAP,ARH 1 7/8" LTs/gutted cats/X pipe/mufflers,Jet Hot coated LTs,GPI HPT Tune,CAI, Scoop,Rx Catch Can,Gates heater hose relocation, Remote clutch & auto brake res,Metco loop,Momentum Tunnel Brace,TSW Nurb 18",555 & 05,Pfadt trailing arms & toe rods,Autometer WB,Fesler Pillar Pod,LED strips (int),Lloyds floor & trunk mats,LED DRL/front turn & license plate,DRL harness,VLEDs tail lights,Plasticoat Bowties. Ord: Oct 5, 2009 Rec: Nov 19, 2009 13.17@112.6 stock
#10 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 Camaro 2SS LS3 Whipple Join Date: May 2019
This is the only reason I don't want to run cats. Its a bit loud... well a lot loud... but I don't have to worry about this! Now you get to built it better though!
#11 |
![]() Drives: 2010 Camaro 2SS M6 - Intake/Exhaust Join Date: Sep 2014
yup... lessons learned for everyone else. Looking forward to the build thread!
#12 |
![]() ![]() ![]() ![]() Drives: 2010 Camaro (M6) 1000+ HP SBE Join Date: Jun 2011
Yeah the guts of my Kooks "green" cats are somewhere on Texas Hwy 3, lol.
F-1X, Cog Drive, ATI Super Pulley/Sprag ~ 19 psi
Blower Cam Brodix BP BR 3 Heads Kooks LT Headers and full 3" exhaust Fore Triple Pump Fuel System with ID 1700X Injectors - E85 conversion DSS 9” Conversion (1400 hp axles, driveshaft, pumpkin) & Strange 3.70 gears McLeod RXT Twin HD Clutch & Upgraded Slave RPM Level VII TR6060 BMR Drag Suspension Package w/Strange shocks Carlyle 15" and M/T ET Street R radials 10.1 @ 143 mph 1/4 mile |
#13 |
#14 |
Yeah. Damn cats. You’d think someone could build one to hold up to boost abuse. But it doesn’t seem so.
I think the real problem with aftermarket cats isn’t exactly the aftermarket cat…I think they need to be placed at exactly the right place down stream in the exhaust. Here I put 9 psi of boost at the engine, long tube headers, and the cats are right there. Probably way too much heat…or something. I bet if someone had the R&D money that Chevy has, they could find an aftermarket cat that would work with a blower and long tube headers. After all…the ZL1 does just fine with it. But we all slap them on together and have no idea just how the heat and flow works at that location. Again…lesson learned for me. But going to start tearing into the engine this week. Should be a fun build. |
