03-18-2011, 03:47 PM | #1 |
Drives: Supercharged 2010 Camaro 2SS/RS Join Date: Aug 2010
I think something is wrong... please help!
Well im going to try and make this short but any help is appreciated. I have the car in my signature and something feels wrong. I went out the other night and everything was fine. I got down on it 1 good time and everything was fine. When i got to my buddies house i stayed there for a while but when i went to leave i cranked it up and it seemed like it was idling really low and my car was shaking like an old muscle car. I switched my Aeroforce gauge to read RPMs and they were jumping from around 450 to around 650. So i get out and i hear a ticking sound that has no rythm its just constant. I searched threads on here about the ticking and alot of people noticed the same thing and said it was normal. I just dont remember ever hearing it before and dont know if i only noticed it then because i was searching for a problem. The ticking is coming from what sounds like the lower part of the engine bay but i can also hear it in my exhaust from the back of the car. I have no idea and am scared to drive it hard right now until i can have it looked at. So i guess im asking if anyone knows what might be ticking or if im just blowing this out of proportion.
2010 Camaro 2SS/RS L99, Maggie TVS2300, 1:1 COG drive setup, 3.6 pulley, Kooks LT's, Corsa exhaust with X-pipe and no cats, AFE intake, p/p throttle body, 516RWHP-530RWTQ
03-18-2011, 03:52 PM | #2 | |
Boosted Moderator
Horsepower is how fast you hit the wall. Torque is how far you take the wall with you. “If everything seems under control, you're just not going fast enough.” Mario Andretti If you can turn, you ain't going fast enough... |
03-18-2011, 04:41 PM | #3 |
'69 Owned Since '79
Drives: '69 Z/28 LeMans Blue w/White Join Date: Oct 2008
Lifter broke or valve drop? Onstar you a tow truck and do not run it.
Good Luck! -Mark. |
03-18-2011, 05:51 PM | #4 |
The internals are totally stock. No LS3 conversion. Any more input?
03-18-2011, 06:03 PM | #5 |
Drives: ex-wife's car Join Date: Jan 2011
Is the check engine light on or flashing? I'm wondering if it isn't missing on a cylinder??? Could be a lifter but I'm wondering if you broke a valve spring.
03-18-2011, 06:32 PM | #6 |
Drives: everyone crazy... Join Date: May 2009
As the posters said, sounds like lifter or valve. That happened to me once when I reved it too high and as I was coming home in a 30 mile zone, I could hear the ticking sound.
How far are you from ADM? Best thing to consult with Andy to see if you should even drive it or not before having it checked out. Last edited by Z_Rocks; 03-18-2011 at 08:17 PM. |
03-18-2011, 06:32 PM | #7 |
ConceptZer0
Drives: 68 427 Camaro, 11 2SS/RS, 13 ZL1 Join Date: Jul 2010
check this out and maybe he can help you.
http://www.camaro5.com/forums/showthread.php?t=132873 best to have it looked at and just go form there like you said Last edited by BigBlock427; 03-18-2011 at 06:44 PM. |
03-18-2011, 07:03 PM | #8 |
Black Thunder
Drives: 2010 Camaro 2SS/RS Join Date: Oct 2009
I had the same exact scenario happen to me. Turned out to be the top ring land on the number seven piston broke. I would not drive the car untill you get it checked out.
JRE 416 9:1 Forged Stroker Package
Edlebrock E-Force Super Charger JRE Blower Cam package Cooling Mist Water/Meth 3.25 blower pulley FAST 65 lb. hr. injectors JRE Edelbrock fuel system upgrade GM ZR-1 Clutch Roto Fab CAI Kooks Headers Jet Hot Coated Kooks High Flow Cats 3" Magnaflow Stainless Steel Exhaust Barton Short Throw Shifter JRE Dyno Tune |
03-18-2011, 08:08 PM | #9 |
Drives: 2010 Join Date: Jul 2009
L99's that were S/C'd - some of them have had a lifter collapse.
It's either that, or a piston. I would talk to Andy at ADM if i were you.. he is in TX. and knows a lot about these cars. |
03-18-2011, 09:47 PM | #10 |
Drives: 2010 Camaro SS Join Date: Oct 2008
I wouldn't even start it up...
I would tow it to your tuner that did the work or someone else and let them look at it... If there is a problem you may can save not having to replace the motor which would be 8k or better.... |
03-18-2011, 10:21 PM | #11 |
Well thanks for all the input guys... Ive contacted my tuner just waiting on a responce. Worst part is this is my daily driver. If its a lifter or something like that can it just be replaced with new lifters or is there probably more damage?
03-18-2011, 10:33 PM | #12 |
NOW CAMMED & SUPERCHARGED
Drives: 2010 Camaro 2SS/RS Black w/ IOM Join Date: Oct 2008
May I ask who performed your work? Tune?
Livernois Motorsports: Maggie 2300 7psi, Livernois 2C cam/L99 to LS3 Conversion, Ported TB, Rotofab w/adm race scoop, adm trans cooler,Kooks headers no cats, Kooks 3" exhaust. METCO breather. Precision 2400 Vigilante TC. Eibach Lowering Springs & Swaybars. BMR Trailing arms, BMR Rear Cradle Bushings, BMR Toe Rods, BMR Differential bushings. Vossen CV3 20's w/ 305 Mickey Thompson @25psi. Zl1 front bumper. OE Zl1 Hood and matte black insert. 556RWHP/500RWTQ L99
03-19-2011, 09:17 AM | #13 |
Boosted Moderator
I'm curious about that one as well... Close friend of mine used a tuner builder in that area... Not ADM...
03-20-2011, 07:37 AM | #14 |
could be lots of things from wiring being chewed on by mice (maf), broken lifter, broken valve spring (better hope not), bent valve stem, bad fuel, etc. must have it diagnosed. Good Luck.
Similar Threads | ||||
what is REALLY wrong with women | Sir Nuke | Off-topic Discussions | 43 | 02-09-2010 09:41 PM |
Is this wrong? and New era? | MikeL | 5th Gen Camaro SS LS LT General Discussions | 12 | 02-06-2010 06:59 PM |
