10-08-2012, 04:59 PM | #1 |
Drives: 2011 SS/RS Join Date: May 2012
Header install question
Putting headers on the car Stainless Works brand and they send Aluminumi RTV. It says to coat both sides of the manifold gaskets. I'm having my doubts about this advise please.
Jeff
2011 SS/RS L99.A6, Stainless Works LTs, Pypes Ex, Haltech CAI, NTo5 DRs,JRE Tune. 2012 Concours 14 |
10-08-2012, 05:14 PM | #2 |
Drives: 2018 Camaro ZL1-1LE Join Date: Jul 2012
I don't understand...What are your doubts?
2018 Camaro ZL1/1LE
10-08-2012, 05:27 PM | #3 |
Drives: 2017 SS 1LE Join Date: Sep 2011
Use only the OEM GM gaskets. Just go buy some from your local dealer.
10-08-2012, 05:39 PM | #4 |
I have OE gaskets was just wondering if the goop was needed
Jeff
10-08-2012, 05:41 PM | #5 |
V8 Lounge member #2
Drives: 2001 Ws6 Join Date: Sep 2009
NOOOO no goop needed bud, just install the GM gaskets and your old bolts and torque them down. No locktite of any kind either on the bolts.
10-08-2012, 05:42 PM | #6 | |
CamaroFans.com
^^^and this |
10-08-2012, 05:54 PM | #7 |
OE gaskets are all you need.
10-08-2012, 06:28 PM | #8 |
Thanks that is what I figured!
Jeff
10-08-2012, 10:42 PM | #9 |
Drives: 2012 ZL1 & 2010 2SS/RS Join Date: Jul 2009
I would never put sealent on the heads instead of the gaskets. From a header manufacturer stand point, it is cheaper to stock tubes of sealent than a bunch of different gaskets. Honestly, just reuse your stock ones and you should be fine. If you want new OEM ones, they do not cost much either...we sell them on the site.
10-08-2012, 10:47 PM | #10 |
i reused my oem ones. no leaks at all.
10-08-2012, 10:48 PM | #11 |
Drives: his wife crazy buying mods Join Date: May 2012
Gone But Not Forgotten
10-08-2012, 10:53 PM | #12 |
Drives: 11 Seconds or Faster Join Date: May 2012
I didn't use the goop, pass on the bolts they send too. The OEM hardware is better than aftermarket here . I installed SW myself, and I love the headers, but the hardware isn't as good as OEM. Good choice on headers!
10-09-2012, 12:11 PM | #13 |
Drives: 2011 Chevrolet Camaro SS/RS Join Date: Jul 2010
+1, used stock gasket with Doug Thorley LT's and used NO sealant, drove 160 miles, no leaks whatsoever.
2011 2SS/RS RJT M6.
PCTXHN Ordered 8/4/2010 Built 9/28/2010 |
10-09-2012, 01:44 PM | #14 |
Drives: 2009 ZR1 Join Date: May 2010
Make sure you re-torque them after several heat cycles.
