Old 08-25-2010, 03:22 PM   #1
martin_2010
martin_2010's Avatar
Drives: 2010 Camaro 1ss/Rs package
WHATS BETTER?!!!
ceramic coated headers or stainless steel headers?
martin_2010 is offline   Reply With Quote
Old 08-25-2010, 03:26 PM   #2
orange-prince
QATAR 2022
orange-prince's Avatar
Drives: black cts-V coupe a6
go with ceramic coated
orange-prince is offline   Reply With Quote
Old 08-25-2010, 03:34 PM   #3
Mblock66
Mblock66's Avatar
Drives: 2005 Subaru Legacy GT
Don't bother with coated headers. They are intended to keep the heat in the pipe so that you don't heat soak the engine and the hotter the molecules are the faster they move. But the difference in the performance you get isn't worth the coating costs.
The only time this "could" be beneficial is when you have a top mounted intercooler on a turbo application and the heat from the headers helps to spool the tubine and keep the intercooler from heat soaking which at a stop. But its still debatable
Mblock66 is offline   Reply With Quote
Old 08-25-2010, 03:41 PM   #4
DSteck
Drives: 2006 Corvette Z06
Get something that's stainless to begin with. Coating can be nice because it improves the look of the headers (they will change color and look nasty over time) but also allows them to cool off a LOT faster, which is nice if you're changing plugs or have to fish around in the engine bay for some reason.
DSteck is offline   Reply With Quote
Old 08-25-2010, 04:04 PM   #5
toehead93
Drives: 2014 2SS/1LE
It isn't really needed as stated above. I have non-coated now and my last car I had non-coated originally. I ended up coating them because I needed to have the collectors welded. I basically coated them to look nice.
http://www.camaro5.com/forums/showthread.php?t=344754
Summit White 2014 2SS 1LE
Recaros, NPP exhaust, Nav
2010 2SS A6 - sold.
toehead93 is offline   Reply With Quote
Old 08-25-2010, 04:30 PM   #6
LSX-80MM
Ghostly Unknown
LSX-80MM's Avatar
Drives: Silver Ice 2010 SS/RS A6
Or you could do both,ceramic coat the stainless,That's what I did. I wanted it to look good,and not have any corrosion problem,as I've had in the past with mild steel tubing that was coated by a well known vender that I want mention
TS416,GMPPLSX-LS3 6 Bolt Heads,Custom 80mmComp Turbo,ID850 Injectors, Lonnies Twin Pump Setup,Level 3 4L80E,DSS,3in Magnaflow Exhaust,CoolingMist Meth,RX Dual Catch Can,InnovateWB,Aeroforce Interceptor,AEM Truboost Controller,matte black CF5 Forgestars.700rwhp/712rwtrq
LSX-80MM is offline   Reply With Quote
Old 08-25-2010, 08:52 PM   #7
martin_2010
the reason i ask is because i want to get some for my L99 ss
but i was not sure if i should go with doug thorley headers offered here http://www.camaro5.com/forums/showth...stall%2Freview
or the ones that texas speed offers here http://www.texas-speed.com/shop/item...=1083&catid=45
idk guys give me your opinions? thank you for your replies
Old 08-25-2010, 09:25 PM   #8
CamaroFTW
CamaroFTW's Avatar
Drives: 2010 Camaro 2SS/RS-Rally Yellow
Send a message via MSN to CamaroFTW
Coating is primarily to prevent heat soak in the engine compartment and then cosmetic secondary (not many people look under you car when you show it off).
I have coated and think it is the way to go. Stainless would not necessarily be faster.
CamaroFTW is offline   Reply With Quote
Old 08-25-2010, 10:55 PM   #9
MoranoRacing
Drives: 2005 GTO, 1973 Camaro
I like stainless steel. It wont rust or peel like some ceramic coating does. I have the american racing headers which are stainless steel and they look great.
MoranoRacing is offline   Reply With Quote
Old 08-26-2010, 07:27 AM   #10
flyby
Drives: 2010 Silver SS
If you are worried about heat soak, especially with a supercharger, you can coat the headers or use wrap. Heat soak on a supercharger does make a difference.
flyby is offline   Reply With Quote
Old 08-26-2010, 08:16 AM   #11
Mblock66
Mblock66's Avatar
Again there is no real HP gain from coated anything. It is so minimal if at all that you will never feel the difference. Unless you are running FI on the car it is like burning your hard earned money.
If you really want the looks for whatever reason then go for it but thats all it is going to do for you, so make sure you open the hood and lay down next to the car to get a good look at those coated headers often so you get your money's worth
Old 08-26-2010, 10:38 AM   #12
ddavis
boostalicious
ddavis's Avatar
Drives: Blown Ls3
+1, heatsoak on the the maggies are awful. Ive seen so many inconsistent pulls with heatsoak taking over that I do everything I can to prevent this. Coated kooks + meth for me to help this. And im not exactly in a hot location, San Francisco
*Powered by Maggie**553rwhp 541rwtq*
ddavis is offline   Reply With Quote
Old 08-26-2010, 11:01 AM   #13
Slowhawk
Drives: 1999 Trans Am
I agree. Coated headers rust up here in time.
Slowhawk is offline   Reply With Quote
Old 08-26-2010, 11:14 AM   #14
JANNETTYRACING
JANNETTYRACING's Avatar
Ceramic Coated Stainless is the BEST.
Ceramic coating mild steel just delays the inevitable RUST, it will happen sooner or later.
Ted.
www.jannettyracing.com
Celebrating 37 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705
email tedj@jannettyracing.com
