02-27-2014, 08:30 AM | #1 |
Racing Brake 2-piece rotors
I had these on my 2010 SS for a bit before I sold it. They have been in the garage since and I am planning to upgrade to the CTS-V kit this summer with ZL1 rotors. I will get pics and more measurements this weekend because they are hard to get to. I took a quick measurement of 29mm which is half of the recommended thickness of 28mm-30mm. This weekend I will make several measurements to each and post the data.
Part Number: 2138 / Size: 355x32mm / Rotor Wt (lbs.): 20.5 Replacement Ring: D403-06-381 Replacement Fasteners Product Code: FK1-10 Replacement Hats: H801-26 The complete set new is $895.00. Replacement rotor rings are $524.11, and replacement hats are ($225.00 each) $550.00, and new fasteners are $83.64. I am asking $450 plus shipping (which is about $175 for the hats and $275 rotor rings). I am open to offers. The rotor rings obviously have a limited life span but the hats can be used forever. These hats fit the front SS rotor rings and front ZL1 rotor rings.
http://www.camaro5.com/forums/showthread.php?t=344754 Summit White 2014 2SS 1LE Recaros, NPP exhaust, Nav 2010 2SS A6 - sold. Last edited by toehead93; 12-08-2014 at 03:11 PM. |
03-06-2014, 09:09 PM | #2 |
Up, pics coming this weekend.
http://www.camaro5.com/forums/showthread.php?t=344754 Summit White 2014 2SS 1LE Recaros, NPP exhaust, Nav 2010 2SS A6 - sold. |
03-10-2014, 08:47 AM | #3 |
pics...
03-13-2014, 02:12 PM | #4 |
Open to offers.
03-19-2014, 06:34 PM | #5 |
still available.
03-19-2014, 06:37 PM | #6 |
Drives: ( . )( . ) Join Date: Feb 2010
Cant tell from the pic because they are wet, but are those hot spots on the rotors?
03-29-2014, 08:21 PM | #7 |
Just saw your post, I had just cleaned them so they were wet as you noted. I will look at them in the morning and see if I can take better pics.
04-03-2014, 07:03 PM | #8 |
Drives: 2011 Camaro SS Join Date: Apr 2012
Still.available?
04-18-2014, 02:43 PM | #9 |
Yes, still for sale. I was waiting to confirm if the discoloration was from hot sport and Racing Brake just confirmed via email that they are not hot spots.
From Racing Brake: "Hawk HP+ is not a race pad, so you can see those pad deposits on the rotor surface but they are not hot spots and shall disappear once you use them again with correct race pad after the rotor gets heated up."
05-04-2014, 08:29 PM | #10 |
Had a buyer that backed out.
05-17-2014, 07:57 PM | #11 |
up
06-01-2014, 09:56 PM | #12 |
Up
07-21-2014, 11:41 AM | #13 |
Drives: 2012 1SS/RS Join Date: Jun 2013
Hey toehead I am interested in these rotors. For some reason I can't PM you however (maybe your inbox is full?). Shoot me a PM if you still have these available.
Thanks
"Driving is the only thing I love about f1."
(Kimi Raikkonen) |
08-03-2014, 06:14 AM | #14 |
Drives: 2014 Spring Edition SS Join Date: May 2014
Have these been sold?
