04-04-2012, 02:15 PM | #1 |
Drives: 2011 Camaro 1LT Join Date: Oct 2011
Subwoofer install on stock stereo
I have a powered subwoofer from an old car and since it's almost brand new, I figured I'd try to install it in my camaro. Does anyone know if it's possible to do that with just the stock stereo? I wasn't sure if there were any pre-outs to plug into and I didn't want to pull the stereo out just to look at the back. Any info would be great. Thanks!
Ben |
04-04-2012, 02:26 PM | #2 |
Drives: Too many to list Join Date: Dec 2011
If you have the Boston Acoustics sound system, your amp is located in the trunk. You can connect a LOC (line out converter) for your subwoofer input from the amp. Then you basically need to power & ground it.
If you have the non-BA system, connect the line out converter to a speaker in the rear deck. Then power & ground the powered sub. It isn't too complicated. |
04-04-2012, 03:06 PM | #3 |
I have the non BA system so I guess I'd go that route. Cool. The sub has been in my garage for almost a year so I'm glad it won't go to waste. Thanks!
Ben |
04-06-2012, 12:30 PM | #4 |
Ecko04,
it sounds simple, but just to clarify if possible. I have the red and white "line in" on the amp. So I just need to plug into there then splice that line into one of the lines going into one of the rear speakers and after running my power line and grounding it, I'm good to go? Sorry for the extra question, I've done a lot of speakers and head units before but never with an amp involved. The closest thing was one of those sound boosting equalizers back in the 80's . Thanks. Ben |
04-10-2012, 12:29 PM | #5 |
Chevy Ridin' High
How can you tell what system you have in your Camaro? I am not sure..
2012 Camaro RS - EXTERIOR: Plasti-Dipped Rims, Blacked Out Lights/Emblems, MRT V1 Exhausts, with more to come. INTERIOR: Red FootWell Lights, One 12" KICKER CVR W/1200 Watt HYPHONICS Amplifier, with more to come.
04-10-2012, 04:06 PM | #6 |
Biggz
Drives: 2010 Camaro 2SS L99 Rally Yellow Join Date: Jul 2011
If you have the BA system use the ******** harness.
04-10-2012, 05:42 PM | #7 |
04-10-2012, 08:26 PM | #8 |
Biggz
04-10-2012, 08:39 PM | #9 |
GM fix my PAINT U suck!
Drives: 2010 Black 1SS/RS 6Spd Join Date: Sep 2009
I did the BA sub mod with some old RCA's why would you need a converter or special harness? Mine has been flawless.
04-10-2012, 09:27 PM | #10 |
Aural Assault Vehicle
Drives: 2010 IBM 2SS/RS, 2015 Sierra Denali Join Date: Jun 2011
If you're running anything other than a strictly class D amp, you'll need more than just the RCA mod. My amp is a class bd and I get a thump every time the amp turns off. I purchased an AudioControl LC6i that I plan on placing between my radio and BA amp.
My amplifier pop/click/thump solution thread
Power Mods * K&N Typhoon CAI, Flowmaster American Thunder cat-back exhaust, Hurst Short Throw Shifter Exterior Mods * Black Phantom Grille * 22" T.I.S. 537MS wheels w/ Nitto INVO rubber * OEM body kit Suspension Mods * BC Racing Coilovers * Lakewood Strut Tower Brace Audio Mods * Stinger SPP 2250 Battery * Mosconi 6to8v8 w/ RCD * Pioneer AVH-X7500BT * Scosche Dash Kit * 2 - Mosconi AS200.4 * 2 - JL Audio 13W6v2 * Focal 165KRX2 Power (active) * Mosconi Gladen One 240.2 * Rockford Fosgate Power T1692 |
04-12-2012, 01:32 AM | #11 |
Chevy Ridin' High
Please HELP!
I am having a little trouble.. I want to hook up my sub and amp to my factory radio (non BA system). So I have some Q's..
1. Do I need to pull the whole head unit out for the RA wire? (wire that makes amp turn on when radio is turned on) 2. What is the best way to run the power cord for the amp? (from battery to trunk) 3. What all would I need to accomplish this? Any help would be awesome. Thanks.
04-12-2012, 11:38 AM | #12 |
My other thread has more info in it, but what I've found so far is to run a remote wire from the amp to the cigarette lighter so the amp will turn off when the car is off. The power line is easy since the battery is in the trunk anyway, just need to have a fuse in it so you don't fry the amp. I'm getting a line out converter to tap into the rear speakers to go to the amp. I'm not sure if the head unit has RCA outputs and I don't feel like pulling it out to check. I'm going to look into an amp kit which should have everything I need to get it done. Everyone's been helpful so far which is good since I've never done an amp before. Good luck!
Ben |
04-12-2012, 11:48 AM | #13 | |
Chevy Ridin' High
04-12-2012, 12:48 PM | #14 |
Similar Threads | ||||
DIY: LS3 Camshaft Install (a lot of pictures, may take a moment to load) | robertway | Camaro DIY & HOW-TO instructions & discussions | 313 | 12-16-2023 06:53 PM |
First Ever DOUBLE DIN (monitor / screen) NO LONGER AVAILABLE**** | Hess RS | Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum | 992 | 06-12-2013 11:13 PM |
Over 230 Satisfied 2010 Camaro Customers! Paddock Chevrolet has 40 in stock NOW | camarojoe | Dealer Camaros for Sale | 2 | 05-24-2010 05:58 PM |
ALL Our Camaros are GM Prefer Pricing (old Supplier Pricing) at MacMulkin Chevrolet! | MacMulkin | Dealer Camaros for Sale | 0 | 01-20-2010 06:40 PM |
