Old 02-13-2013, 12:57 PM   #1
Bello
Drives: 2013 2SS 1LE on order
alarm problem
So here is the thing i have an alarm installed by my dealer when i first picked up my car. just recently installed an item on my 2013 2ss that i wired directly to the battery. when i reconnected the battery the alarm starts blasting and i was no longer able to use my key fob to turn it off. so is there a way to reprogram the key fod to once again be able to turn the alarm both on and off
Bello is offline   Reply With Quote
Old 02-13-2013, 01:01 PM   #2
darkrider01
Aural Assault Vehicle
darkrider01's Avatar
Drives: 2010 IBM 2SS/RS, 2015 Sierra Denali
We'll need a bit more information to be able to help. What brand and model is the alarm?
My amplifier pop/click/thump solution thread
Power Mods * K&N Typhoon CAI, Flowmaster American Thunder cat-back exhaust, Hurst Short Throw Shifter Exterior Mods * Black Phantom Grille * 22" T.I.S. 537MS wheels w/ Nitto INVO rubber * OEM body kit Suspension Mods * BC Racing Coilovers * Lakewood Strut Tower Brace Audio Mods * Stinger SPP 2250 Battery * Mosconi 6to8v8 w/ RCD * Pioneer AVH-X7500BT * Scosche Dash Kit * 2 - Mosconi AS200.4 * 2 - JL Audio 13W6v2 * Focal 165KRX2 Power (active) * Mosconi Gladen One 240.2 * Rockford Fosgate Power T1692
darkrider01 is offline   Reply With Quote
Old 02-13-2013, 02:28 PM   #3
Bello
i really dont know what brand and model the alarm is. its not crazy like the viper system just when ever chevy puts in the cars. if thats not enough info then i guess im out of luck thanks anyway
Old 02-13-2013, 03:41 PM   #4
darkrider01
Yeah, if it's an aftermarket alarm (i.e. not a factory alarm) then you will have to deal with the dealership that installed the alarm.
Old 02-13-2013, 03:51 PM   #5
Bello
lets say it is a factory alarm what should i do in that case?
Old 02-13-2013, 11:39 PM   #6
darkrider01
If it is a factory alarm, call OnStar or GM. Your car should be under warranty still, correct?
Old 02-14-2013, 06:44 AM   #7
Sir Nuke
Master of All Things
Sir Nuke's Avatar
Drives: '20 Corvette Stingray
since your dealer installed it.....this is easy, drive DIRECTLY TO YOUR DEALER.
