11-20-2011, 12:18 AM | #1 |
Banned
Drives: 4 Wheels, Gasoline Engine Join Date: Jul 2010
ZL1 Driveshaft
Is the driveshaft on the ZL1 the same two-piece unit used on the SS or will it be a one piece unit? I can't recall it being specifically mentioned but I seem to recall seeing a picture of the undercarriage and thought it showed a two-piece shaft.
11-20-2011, 02:14 AM | #2 |
THE CAMARO KING
Drives: 2012 Camaro ZL1 on order #PZSD7S Join Date: Aug 2006
By looks of things looks like a two piece with a carrier in the middle.
2012 Camaro ZL1 Car Name: Bruce
ZL1, LSA, MN6/MG9, DSX, RTQ, VR, Current Status: 2030 1000 Initial Order 11/11/2011 Chevyland 1100 Order accepted at dealer: 11/11/2011 - PZSD7S 2000 Order accepted by GM: 12/14/2011 3000 Accepted By Production Control: 00/00/2011 - TPW 00/00/2011 3100 Sequenced: 00/00/2011 3300 Scheduled For Production:0/0/2012 3400 Broadcast: 0/0/2012 3800 Produced: 0/0/2012 4000 Available To Ship: 0/0/2012 4200 Shipped: 0/0/2012 5000 Delivered To The Dealer: 0/0/2012 6000 Delivered To Customer:0/0/2012 |
11-20-2011, 12:26 PM | #3 |
Banned
That's what I thought but can't seem to find any underside pics of the ZL1. How well do we think that is going to hold up? I notice most of the higher horsepower modded SS cars tend to go to a one-piece shaft. I'm sure there is a reason.
11-20-2011, 01:53 PM | #4 |
check this pic right from chevy website..
11-20-2011, 01:53 PM | #5 | |
THE CAMARO KING
I have 110% confidence it will hold up. If not, that is what the warranty is for!
11-20-2011, 04:02 PM | #6 |
Cooter
Drives: my wife crazy Join Date: Oct 2011
I believe that pic is of a SS with an LSA engine cover on it. The dual exhaust instead of quad exhaust gives it away. Maybe not thoug..
#1451 - 2012 ZL1 - White, Black Wheels, Manual, Suede Package, and Exposed Hood Insert. Delivered on 6/20/12. Thanks to Jason from Symdon Motors in Evansville, WI.
11-20-2011, 04:06 PM | #7 |
I used to be Dragoneye...
Everything in the ZL1's drivetrain has been upgraded to handle the increased power.
To be honest, I don't know why people upgrade to single-piece driveshafts, I've never looked into it to determine a reason or advantage - I'm sure there is one, though. I do know that two-piece driveshafts tend to have better harmonics, thus better Noise/Vibration/Harshness from a factory-perspective...this is because there isn't a super-long pole wobbling (producing vibrations) at high rpms underneath the car. |
11-20-2011, 04:38 PM | #8 |
Drives: 2013 WRX Sedan Join Date: Aug 2009
11-20-2011, 05:10 PM | #9 |
CaRaHoLiC
Drives: '12 ZL1,67 Cam,68 Biscayne 427 4 sp Join Date: Aug 2011
what's the reason for a two piece driveshaft?. I wonder why they just don't go to a solid enclosed shaft.
11-20-2011, 05:11 PM | #10 |
Wrote something about that above...
11-20-2011, 05:12 PM | #11 |
CaRaHoLiC
So if its just a vibration issue, seems to me a solid shaft would be zero vibration?
11-20-2011, 05:15 PM | #12 | |
I found this neat read...pretty informative. http://www.rodandcustommagazine.com/...h/viewall.html Again - I want to say I'm sure there's a reason some aftermarket builders use solid shafts...I've just never spent any time to look up why. |
11-20-2011, 05:26 PM | #13 | |
'12 ZL1 #742
Drives: his wife crazy Join Date: Nov 2011
11-20-2011, 05:29 PM | #14 |
CaRaHoLiC
Good article, and very informative info about drive shafts..(thank you).. but I`m not talking about a ` driveshaft``per say..I am talking about a ridgid shaft within a housing. There are no u-joints or lateral movement, so the shaft rides in bearings, so there would be no vibration if enough bearings are used for the length. Also clearance in the tunnel would be greatly increased because the shaft would be like 1.25`as opposed to a 3`inch driveshaft. Less spinning weight etc. like a corvette..
Similar Threads | ||||
Shno's House of Z | Number 3 | Camaro Z/28 Forum - Z/28 Specific Topics | 17976 | 12-27-2021 12:07 PM |
Need help with order please | zfuzz | Camaro ZL1 Forum - ZL1 Specific Topics | 7 | 11-22-2011 06:40 AM |
The ZL1 Joins The Dark Side: ZL1 Carbon | Apex Motorsports | Camaro ZL1 Forum - ZL1 Specific Topics | 22 | 11-15-2011 04:18 PM |
Were Initial ZL1 Production Expectations Properly Managed? | GoldenBear | Camaro ZL1 Forum - ZL1 Specific Topics | 31 | 10-26-2011 12:52 AM |
