11-02-2013, 12:49 PM | #1 |
Drives: '11 VR 2LT HHr Join Date: May 2011
I need help with GM 4 Pak guages.
:edit:
I want to say Sorry to Ofer and Gen45Diy I did go back to your website was looking again at the gm4pak and right there is the install pdf link right under my nose .............................. :facepalm......................................... ..................... I ordered the Gm 4 pak guages from Ofer @ Gen5 Diy. Putting this here just for some help. Not aggervated just stuck. . I recieved a wiring harness that am not sure how to plug in. I understand the long white wire as there is just one plug in on the back of the guages ( wiring harness pic below ) I understand the other part of the harness you plug it in the middle. I just dont see any where to plug it The wiring is basically the only thing keeping it from being done. Got the traction button and lighter done. Pic below is what i see up under the my link
2011 Hhr
Formerly known as Silver85IrocZ !! Last edited by DwRed1LTV6; 11-10-2013 at 06:49 PM. |
11-02-2013, 01:04 PM | #2 |
Todd
im almost positive the place where you ahve to connect it is on the passengers side of the car. i think you have to remove the little plastic door sill plate right next to the seat and i think its in there. try to google 4 pack gauges install for a 2013
11-02-2013, 01:12 PM | #3 |
There is a great. . ..write up on it... by a member.
just doesnt show how to do the connections and they werent doing it with a 2013. And didnt show the connections http://www.camaro5.com/forums/showthread.php?t=151439. May go out later. . and look at the front of the console again. Thanks Tmick5jr i mainly didnt want to rip some thing apart and screw it up. . . ~
2011 Hhr
Formerly known as Silver85IrocZ !! |
11-02-2013, 01:59 PM | #4 |
Drives: 2014 Z/28 #82+#192, 18ZLE 66Nova Join Date: Oct 2008
was out of town, but here you go a link to the install,
P.S. its on the site http://www.gen5diy.com/image/data/PD...%20harness.pdf |
11-02-2013, 05:36 PM | #5 |
Thank you Ofer !!!
now it make sense .!! will have to wait til tomorrow light going away.! :edit 1st post
2011 Hhr
Formerly known as Silver85IrocZ !! Last edited by DwRed1LTV6; 11-10-2013 at 06:45 PM. |
