Old 04-24-2010, 07:59 PM   #1
55Designs
Drives: 2010
The Infamous Neck Chopper ( Seatbelt) Tried everything and got pulled over today
It slices into my neck no matter what I do. its the most horrible location. All of my other cars have the shoulder belt inches lower.
Is there any TSB on this or a real solution?
I am about to redrill the mounting hold in the side pillar because its that bothersome. I just dont want to risk my safety or the SRS system. I might even have to weld in a threaded bong for the bolt to make it work. Royal pain in the butt.
I got pulled over today and told the cop and he laughed but when i showed him he said you better get that fixed.
55Designs is offline   Reply With Quote
Old 04-24-2010, 08:00 PM   #2
ahart04
most bang for your buck
ahart04's Avatar
Drives: 2010 2SS/RS CGM/BLK RALLYS
Try lowering the seat?
2G1FT1EW8A9142133 Delivered to me 09/22/09!
ahart04 is offline   Reply With Quote
Old 04-24-2010, 08:06 PM   #3
jagan323
I have no life
jagan323's Avatar
Drives: 06' Subaru STI, ex-Camaro V6 LLT
How tall are you? I have never been in a car where the seatbelt chops my neck, except when i was 10 years old. o_O
jagan323 is offline   Reply With Quote
Old 04-24-2010, 08:11 PM   #4
myold88
myold88's Avatar
The same problem for me. I just finished a 3400 mile trip (including camaro5fest) and found the belt cut into my neck no matter what I tried. A shirt with a collar helps but it's still a pain in the neck. At times I put the belt under my left shoulder but I think that defeats the purpose of the belt. Some kind of a padded wrap around that part of the belt would help.
Old 04-24-2010, 08:11 PM   #5
SlingShot
SlingShot's Avatar
Drives: 2012 ZL1 - #670
AutoZone stocks nice belt pads made by Bell ... I've put them in both cars front and rear, and no more problems ...
Old 04-24-2010, 08:16 PM   #6
JoeP@TeamBeckyD
JoeP@TeamBeckyD's Avatar
This came up not too long ago. Your dealers parts department can order a seat belt extension for you. It's 6" long, I believe, and it fits into the buckle and allows that belt to move a little farther to the left. It was actually designed for heavy people who couldn't fasten the belt because they were too big. But I have several customers who request them on their cars for the same problem you are having. The best part is that it's free. Call your parts dept and have them order one for you and see if it helps. Better to try that before you start redrilling things. Good luck and let us know how it works out.
Old 04-24-2010, 08:22 PM   #7
daphatgrant
June '10
daphatgrant's Avatar
Drives: '10 2SS/RS RJT
RJT, 2SS/RS, M6, Black Int, Sunroof.
daphatgrant is offline   Reply With Quote
Old 04-24-2010, 10:12 PM   #8
Havok1327
Havok1327's Avatar
Drives: 2010 Camaro IOM 2SS/RS
I have this problem as well. I'll look into order the seat belt extension, thanks Becky.
Havok1327 is offline   Reply With Quote
Old 04-24-2010, 10:30 PM   #9
BOBSS
Outlaw
BOBSS's Avatar
Drives: 2010SS
great tip thank you!
i have a heavy black paper clip on the belt
i position it so it jams the belt in the upper mount with just a little slack
it means it wont reel in so i just lay the belt along side the seat
the TBSS Has the same issue
BOBSS is offline   Reply With Quote
Old 04-24-2010, 10:33 PM   #10
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
I dunno what height you are...but I've never experienced this...and I've been waiting for it...
(I'm 6', by the way)
I have seen (courtesy Killer74Z28) these sleeves that fit over the belt to keep it off you...but that belt extension seems promising.
Old 04-24-2010, 11:28 PM   #11
Moorepheus
Drives: 2013 Dodge Charge R/T Plus AWD
I will be ordering 2, one for my seat and one for my passenger seat.
Moorepheus is offline   Reply With Quote
Old 04-25-2010, 03:57 AM   #12
DGthe3
Moderator.ca
DGthe3's Avatar
Drives: 05 Grand Am GT
I (mostly) fixed this problem in my car (not a Camaro) by raising the seat and sitting a bit more vertical. It puts more pressure on the shoulder rather than letting it slide across to the neck.
........and HE WOULD KNOW!!!!
Camaro Fest sub-forum
Old 04-25-2010, 04:15 AM   #13
AlSuwaidi
AlSuwaidi's Avatar
Drives: BLACK LS3 GCC-Spec
not really a prob for me
AlSuwaidi is offline   Reply With Quote
Old 04-25-2010, 04:38 AM   #14
Black_2SS
Black_2SS's Avatar
Drives: 2018 Camaro SS HotWheels Edition
I have the same problem. A shirt or jacket w/ a collar does help but its still annoying. I was thinking of putting a clip on the lap and sholder belt to hook then together. That would pull it to your left more. However I think that extension may basically do the same thing. And for that price, I think I'll give it a shot. Thanks for the info!
Black_2SS is offline   Reply With Quote
