05-07-2012, 07:36 PM | #1 |
Love me some Tacos
Garaging a Camaro
When I arrived at home my engine temp was 201 F. I then parked my car inside the garage. My question is, do you let your car sit outside cool down then park it in the garage. Is there a benifit to waiting?
05-07-2012, 07:56 PM | #2 |
Drives: Camaro Join Date: Feb 2012
no
05-07-2012, 08:07 PM | #3 |
Drives: 2011 SGM Camaro 2SS/RS Join Date: Jun 2011
x2
05-07-2012, 08:13 PM | #4 |
It is better in my opinion. Keeps the sun off it so it can cool faster. Also, my garage is climate controlled. If my car is too hot, I pop the hood and let it breath in the nice cool air.
05-07-2012, 08:15 PM | #5 |
EMERALD COAST CAMAROS
Drives: 2lt summit white dk gray int Join Date: Jul 2009
nope, just pull in turn it off close the door and say" goodnight Bertha!!"
Big Bertha!
2010 summit white 2Lt cgm rally stripes,hot pink pin stripes,doug thorley shorties,pink bowties,led side markers,sequetial led tail lights,NLP spoiler,magnaflow axel back exhaust, AIRAID CAI(soon to be Vararam) Last edited by jkelly; 05-07-2012 at 08:17 PM. Reason: wrong word |
05-08-2012, 12:15 AM | #6 |
LS3 Black Widow
Drives: 2012 45th 2SS LS3 and 1968 Mustang Join Date: Nov 2011
No it won't make a difference. Pop your hood in your garage if you're really that concerned.
05-08-2012, 01:31 PM | #7 |
Drives: Sold: 2011 2SS/RS Join Date: Dec 2010
Do you mean water temp or oil temp?
Either way, it doesn't really matter unless you're running a turbo. If you run a turbo car hard, it's not good to shut off a turbo (and all oil circulation) if it's just been run hard. Newer vehicles have an automatic cooling pump for the turbo that runs after the car is shut off to aid in cooling it down (older turbos...usually you let the car idle for 30 seconds or so before shutting it off) If you need to cool the engine quicker (like if you're going to change the oil relatively soon), pop the hood with the engine shut off and let the heat escape with the garage door open. |
05-08-2012, 01:36 PM | #8 |
Drives: 2011 2SS/RS LS3 Join Date: Nov 2011
If it were running hot for some reason, I would let it idle until it "cooled down", then garage it. Probably harder on the engine to re-start it, just for a few more feet.
