02-26-2012, 06:32 PM | #1 |
oldschool69
Drives: 2012 2SS/RS Join Date: Dec 2011
AIR COMPRESSOR IN TRUNK
Have any of you had trouble removing the air compressor from the trunk of the 2012 SS. What is the trick, or is it just me?
02-26-2012, 06:48 PM | #2 |
No trick, it should just pull out of the foam holder (assuming its the same as earlier models). Mine's a little easier, since its just sitting in a box in the trunk with some rags and a spacer for my spare.
02-26-2012, 08:15 PM | #3 |
Do somethin fun every day
I put my new spare tire kit in yesterday and pulled out the compressor and foam & the compressor was a little tough to separate from the foam but I pulled the small piece of foam on the outside then the compressor came right out.
02-27-2012, 08:11 AM | #4 |
oldschool69
Thanks for the tips.
02-27-2012, 10:27 AM | #5 |
Drives: 2017 Camaro SS Join Date: Oct 2009
Use a foam gun. I recommend .357 or .44 Magnum.
02-28-2012, 04:20 AM | #6 |
Drives: 2012 Camaro EU version (V8) Join Date: Sep 2011
Can somebody enlighten me?
What air compressor in the trunk? What it does? Is it stock or add-on? |
02-28-2012, 04:40 AM | #7 |
Drives: 2010 Camaro 1LT/RS M6 Join Date: Nov 2007
It's stock... if you didn't get a spare, which was not an option on the SS, you got the air compressor. It's where the spare tire would normally go... on top of the battery.
Trifecta tune, Vararam Intake, VMAX throttle body and manifold insulator, RxPerformance Catch Can, , MRT v1.0 and Louvers, Barton shifter, BMR strut tower brace, RED dome light and Plasma LED DRL's, fieldgoal00's Halo 1 harness, hood spears/side stripes, rain guards, custom bowtie, Team LLT badges, headlight and foglight covers, taillight and side marker covers, backup light covers, WeatherTech floormats
02-28-2012, 08:26 AM | #8 |
Master of All Things
Drives: '20 Corvette Stingray Join Date: Jul 2009
if ya want a REAL compressor.....ya could get one of these.....
then keep a small hose coiled up in the trunk adn drag it out when needed. it would be real handy at the track too.....let some out for racing.....then air them up to drive home with.
02-28-2012, 08:55 AM | #9 |
I removed the air compressor and bought a spare with spacer, jack, and lug wrench for mine. Compressor wasnt hard to remove at all.
Life is short, drive it like you stole it! |
02-28-2012, 11:02 AM | #10 |
in regards to the air compressor, does it charge automaticly? Or is it a plug in deal? Last night, and a couple of times backing out of my drive way, I hear a knocking sound coming from the trunk area. Last night I heard it sitting a traffic light when I left work.
02-28-2012, 11:11 AM | #11 |
Drives: 2012 2SS TF3, 1971 Chevelle Join Date: Feb 2012
It's a normal walmart quality 12 volt mini compressor that plugs into any car 12V outlet. What is unique about this one is that there is a replaceable bottle of tire sealant inserted into the pump housing and a switch on the pump that selects tire sealant, off, or air. So you would plug it in, select sealant and inject this slime into your tire and then select the air to complete the fill of the tire. Then, drive a directly as you can to a tire shop.
Sent from my Galaxy Nexus using Tapatalk |
02-28-2012, 11:32 AM | #12 |
02-28-2012, 12:19 PM | #13 |
Drives: 2016 2ss hyper blue auto Join Date: Sep 2009
Air comressor
Just a reminder if anyone has to use the sealant you have to get the tire dimounted and cleaned out as this will damage the pressor sensor and that is not covered under warrenty.
11-14-2012, 03:00 PM | #14 |
So, could I use the compressor part to air up my motorcycle tires with out injecting the slime into the tire??
2012 SS L99
Stainless Works Retro Chambered cat back CAI intake 22" Ruff Racing Rims MPD1 Cowl Induction Hood Arizona All Gens Camaro Club |
Similar Threads | ||||
Cold Air Inductions Intake System! ADM Performance Cold Air Scoop! & Packages! | AutoAgenda | V8 Bolt-Ons & Tunes | 438 | 11-23-2013 10:49 PM |
2012 V6 C.A.I. Inc. | Camaro 3.6L Cold Air Inductions Intake System! | Plus Packages! | AutoAgenda | V6 Bolt-Ons & Tunes | 87 | 08-25-2013 05:22 PM |
Cold Air Inductions (CAI, Inc.) | In Stock | FREE CLEANING KIT AND SHIPPING! | JDP Motorsports | V8 Bolt-Ons & Tunes | 41 | 03-29-2013 08:17 AM |
Acronyms at C5 | hokie2012 | 5th Gen Camaro SS LS LT General Discussions | 34 | 08-10-2011 03:56 PM |
Why RAM Air is a myth!!! Long Read (Wall of text) | live2well | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 80 | 11-02-2009 03:34 PM |
