Old 02-13-2014, 02:54 AM   #1
Sesiom Summers
Drives: 94 Z28 / 01 Z28 / 2015 50th GT
Send a message via MSN to Sesiom Summers
can I use a MS3 cam in a supercharged engine?
hello everyone, Im building my first Block ever and Im lost of what to do now...
as the title say I am building a chevy Ironblock bored to 392
and I have in the shop 2 cams, one is the MS3 cam with a 112 lope, the other one is a LS9 cam with 112.5 lope
wich cam could work better?
finally
as I want to use a LSA blower... what would be the Ideal head to go with the MS3 cam or the LS9 cam?
tanks for any help that you guys can give me!!
01 SOM A4 Z28 / 15 Mustang A6 50th anniversary
XXXhp 460hp
Sesiom Summers is offline   Reply With Quote
Old 02-13-2014, 04:02 AM   #2
dan0617
dan0617's Avatar
Drives: 2011 Inferno Orange SS Convertible
MS3 cam is a big cam. would need a high stall converter if auto. Might be ok with your cubes but LSA blower is not a very big blower to run with that cam and those cubes.
LS9 cam is good for boost and that blower but is a little small for those cubes. Would be a perfect daily driver or weekend cruiser that puts down gobs of torque.
Really depends on the rest of the setup and the use of the car but I think the MS3 cam would be more suited to a high rpm N/A or centri blower race type setup where some street manners can be sacrificed.
2011 SS IOM Vert. ECS Vortech 13+ psi, Water/Meth, ID850’s, ZL1 pump with MSD Voltage Booster, 2800 stall, LT headers, Drag radials, Drag alignment, Cradle Bushings. A million other supporting mods. Tuned by Ted.
dan0617 is offline   Reply With Quote
Old 02-13-2014, 10:38 AM   #3
2SS45th
2SS45th's Avatar
Drives: 11 Seconds or Faster
Custom spec cam if it's basically a one off motor.
I Ain't About That Stock Life.
2SS45th is offline   Reply With Quote
Old 02-13-2014, 12:58 PM   #4
Sesiom Summers
thanks, yeah this car is my DD, the transmission is a 4L80e with a 4200 Stall
thanks!
XXXhp 460hp
Old 02-14-2014, 09:56 AM   #5
Steve@SNL/Monster Clutch
Drives: 2014 SS
We just made 980 rwhp in a 6.0 LQ9 with a Texas Giant camshaft (248/254 on a 112) and twins... I'm not at all kidding. It's a 6 speed car of course but it drives like a big cam car, but with a ton more power.
The MS3 will need a 3200-3600 converter.
Considering you want to run that small of a blower my recommendation would be to contact us and get a custom grind setup done. Either of those will "work", I'm not a fan of the LS9 camshaft and the MS3 is a bit on the aggressive side.
When you call in ask for Chris, he'll get you taken care of. 817-750-2000
Steve@SNL/Monster Clutch is offline   Reply With Quote
