06-28-2014, 09:56 AM | #1 |
2G1FB1EV7A9100028
Drives: 2010 Jeep Wrangler Hemi Join Date: Mar 2009
Front Brake Rotors Question
So I've got two front rotors that were for my CTS-V and after looking the part number (25851237) up it says they'll fit 2012+ Camaro ZL1's also. I sold them on eBay and the buyer insists that the Camaro Rotors are two piece rotors and that they are directional. I would really appreciate it if someone could tell me they will work on a 2012 ZL1 or if should cancel the purchase for him. Thanks in advance!
# 28 - Victory Red 1LT/RS (SOLD)
06-28-2014, 10:30 AM | #2 |
Drives: ZL1, 2013, tri-coat-red, manual Join Date: Nov 2013
Looks like they changed with the intro of the Zl1, but are backward compatible.
2009-2013 CTS-V/Camaro ZL1 - GM/Brembo - Front 2-Piece Rotors Features Brembo 2-piece front rotor assemblies that incorporate an advanced high carbon alloy brake rotor material, combined with a billet aluminum bell and patented anti-rattle floating hardware. Their superior metallurgy and directional curved vane design significantly improves airflow and cooling, making these rotors highly effective at managing heat. Similar to the rotor hardware developed by Brembo for some of the worlds top supercars, the anti-rattle hardware design allows a floating rotor to be safely run on the street or track and eliminates excessive noise that is commonly associated with floating rotors. Brembo 2-piece rotors are fully assembled and pre-torqued prior to shipment.. The GM Brembo 2-piece floating brake rotors have been designed for performance on the street or on the track. This upgrade (2009-2011 Upgrade and Standard 2012+) adds more thermo-mechanical resistance, reduced unsprung mass and dissipates heat more efficiently. The anodized aluminum hat design and e-coated outer rotor protect against corrosion from the elements and ensures a more attractive look. Product Features:
06-28-2014, 10:48 AM | #3 |
The one pie e cts-v rotor and zl1 twompiece rotor are interchangable. The thw two piece costs more and is actually a little heaver butis said to cool better.
http://www.camaro5.com/forums/showthread.php?t=344754 Summit White 2014 2SS 1LE Recaros, NPP exhaust, Nav 2010 2SS A6 - sold. |
06-28-2014, 11:00 AM | #4 |
Drives: 14 1SS Camaro 1LE, NPP, Recaros Join Date: Nov 2013
06-28-2014, 11:11 AM | #5 |
2G1FB1EV7A9100028
So even though they're different they'll still work? I'm sorry but I feel like I'm missing something.
06-28-2014, 11:22 AM | #6 |
Parts Guru Extraordinair.
Drives: '02 SS 'Vert M6 Join Date: Mar 2011
From the CTS listings:
20795300 ,20795302 . ROTOR, FRT BRK (2 PIECE ROTOR, FOR 1 PIECE SEE 25851237)
Please check out my other hobby ; http://jetphotos.net/showphotos.php?userid=1008
06-28-2014, 02:06 PM | #7 |
06-28-2014, 03:50 PM | #8 |
Speed Freak
Drives: 2013 ZL1 Camaro, 2016 Camaro SS Join Date: Jun 2013
You need to ask him how he is planning to drive the car? The CTS-V one piece rotors will bolt onto a ZL1 Camaro just fine. The air passages on the center of those rotors are straight through with no built in sweep for added cooling (this is why they can mount either side). They will actually cool better on a ZL1 than they did on the CTS-V because the Camaro has cooling ducting to the front brakes and the caddy did not. But the reason that rotor was scrapped is because if you put it on a race track and drove the car hard the rotor would be red hot within 2 laps. Most pads and fluid could not take the heat and the brakes would fail.
If the owner plans on using ceramic pads and never tracking the car that rotor will be fine for street driving the ZL1. It works fine on a CTS-V with ceramic pads and no track duty and the V has more weight and no cooling ducts. If they plan on hot lapping the car....ever... they should spend the money for two piece rotors.
2016 SS -AGP twin Borg Warner 7163 EFR's, LT4 mechanical pump, LT4 injectors, Walbro 255 low side, Castrol SRF. 734whp/759 tq
2013 ZL1 -ADM - 427 LSX 6 bolt, O-ringed block built by LME. Twin PT6466 turbos. RPM custom manual trans, RPS Quad carbon clutch, 9" Hendrix rear diff & axles. ADM/squash fuel system, Ron Davis radiator, Spal fans, AGP air to air, turbo plumbing. LPE oil cooler, rear bushing upgrade, roll bar...etc. rwhp 1400+... 212.5mph, best Texas mile to date. |
06-30-2014, 03:55 PM | #9 |
Cartoon Maus
Drives: White ZL1, Chevroyota Prizolla Join Date: Aug 2013
^That.
